You dont have any partitions. - Need Help ASAP!
I am willing to pay $50 + tip in BTC to anyone who can provide 1on1 support to solve this ASAP.
My other thread isn’t getting any user support.
I get the errors in shell after the gui boot screen:
“Warning: /dev/qubes_dom0/root does not exist”
“Warning: Not all disks have been found.”
“Warning: You might want to regenerate your initramfs”
/dev/qubes_dom0/swap does not exist
crypto LUKS UUID ****************** (long character string) not found
I loaded the hard drive with the qubes os installation onto a computer with gparted and here is the report:
/dev/sdc1 = EFI System partition Fat32 600mib (7.89 mib used) flags = boot; esp
/dev/sdc2 | file system: ext4 | 1 gib
/dev/sdc3 [Encrypted lvm2 pv | mount point = qubes_dom0 | 181.76 gib
unallocated | 1.00 mib
2 posts were merged into an existing topic: Emergency Dracut Shell errors. Boot Drive unable to login to Qubes OS
