I’m using 4.2.3 on an Rog Strix and everthing seems to work fine.
Here, the internet over Wifi is between 200-300Mbs
I just received a new laptop (Thinkpad E16 Gen 2) and even if it has support for WiFi 6 the speed, same location, same SSID, the internet speed doesn’t go above 60Mbs (max, usually below 40Mbs)
Why is that and how can I investigate as I’m pretty sure is Qubes related
(I’ll create an USB Bootable Stick with Ubuntu and try with that as well to see if the speed will go higher …)
Just tried from an USB stick with Ubuntu and worked perfectly fine on Thinkpad as well.
On the rog strix I have a Wi-Fi 6(802.11ax) (here the internet is working good)
On Thinkpad E16 Gen 2 I have 802.11 ax 2x2 (here the internet from Qubes OS is extremely slow)
I’ll try reinstalling the Qubes OS w/o using latest kernel
I did so as I had an issue with sys-net and wasn’t able to login but I know how to solve it now
I’ll came back later if this will solve the problem as the gui - browsers, vscode … - is slower as well and don’t like that at all while working)
There is no need to reinstall the Qubes OS just to use different kernel.
You can install the stable kernel packages in dom0 if you don’t have them available:
Install the stable kernel for qubes:
sudo qubes-dom0-update kernel-qubes-vm
To change the default kernel for all qubes you can set it in Qubes Global Settings.
Or you can just change it in the sys-net Settings.
Install the stable kernel for dom0:
To boot dom0 with stable kernel you need to select the GRUB boot menu entry with this kernel at Qubes OS boot.
So if I’ll change the kernel from grub to 6.6.48 it will freeze at plymouth-quit-wait with an error some lines above that sys-usb failed to start
Changing the kernel on sys-net its better but it will not go above 100Mbs so I guess changing the kernel to stable for dom0 is needed as well but can’t do so
Check CPU and memory usage in sys-net during high load.
Maybe try to increase initial memory and VCPUs assigned to sys-net.
Also check the /var/log/xen/console/guest-sys-net-dm.log log in dom0, maybe there will be some related messages. Maybe some issue with interrupts (MSI).
There is no high-load yet, I’m just migrating data from one laptop to another via external HDD (looked into sys-net anyway and looks perfectly fine)
I’m just running fast.com on both laptops to test the speed and on thinkpad is extremely slow.
There is nothing into the log file (this message only: _msi_msix_update: Updatinting MSI-X with pirq <number> qvec ...)
Today when I run it I observed that the laptop may want to increase the speed, it reached 80Mbs and then just started to drop the speed below 40Mbs - with Ubuntu USB and on the thinkpad I’m between 200-300Mbs)
