qun
July 27, 2024, 7:36am
1
Hey,
I try to get wireguard working and I used this setup: Wireguard VPN setup
So far I get connection to the external network, can ping the server there, but can not resolve websites, or connect with remmina. I tried different DNS servers and tried different MTU size with no success.
Somebody an idea?
Cheers
qun
Do you have Qubes OS 4.1 or Qubes OS 4.2?
Are you unable to ping domain names (e.g. ping debian.org) in both sys-vpn and in app qubes connected to sys-vpn?
qun
July 27, 2024, 7:06pm
3
Qubes 4.2
I can ping debian.org , so it seem not to be a problem with DNS as I understand.
sys-vpn to sys-vpn??
no, sys-vpn is connected to sys-firewall and app vm is connected to sys-vpn
qun
July 27, 2024, 7:22pm
5
yes, that works, both.
by the way, where can I set allowed IPs in the network-manager? Can not see this setting
qun:
Then DNS is working properly.
Maybe it’s an issue with MTU. Did you try to add this firewall rule?
NetworkManager supports Wireguard out of the box! The only thing required are extra firewall rules in the VPN qube, as explained in Configuring a ProxyVM VPN Gateway .
What you’ll need
This guide assumes you are using a VPN service that has wireguard support, most of them do, but you can also add your own if you have a server.
ProtonVPN has a free plan, it has limits but gives you a fully working VPN and they support WireGuard. This provider is recommended on privacyguide…
qun
July 27, 2024, 7:35pm
7
no, I wanted to get it work first and then set this fw rule. Now its just opened for everything out.
I tried different MTU, but without success.
The connection seems to be ok, because of the ping within and outside the vpn-network.
Allowed IPs are all zeroed, so it shouldn’t be a problem.
qun
July 27, 2024, 8:31pm
9
curl doesn’t work in both
What if you try this?
curl https://9.9.9.9
What if you ping quad9.net in both qubes?
qun
July 27, 2024, 8:39pm
13
it takes rather long (250ms), but it works
Try to add that firewall rule.
UPD:
On second thought, since you have the same issue in sys-vpn then it won’t help.
qun
July 27, 2024, 9:26pm
15
it doesn’t make sense for this problem, because it’s just the rule, to avoid leaks beside the vpn tunnel.
It’s not a rule to allow/block packets, it’s a rule to modify MTU of a forwarded packets.
qun
July 27, 2024, 9:30pm
17
ah, so this rule in sys-vpn?
nft add rule ip qubes custom-forward tcp flags syn / syn,rst tcp option maxseg size set rt mtu
qun
July 27, 2024, 9:31pm
19
I suppose in the templateVM of the sys-vpn, isn’t it?
