no changes
Edit:
AH! It works, but I lower the MTU to 1280
Why so low? Because of some QubesOS specials?
no changes
Edit:
Where did you lower the MTU? For what interface in what qube?
Maybe you have another VPN before sys-vpn?
in sys-vpn, in the networkmanger.
ahhmm… suppose not ![]()
anyway, thanks a lot, it works!
this is curious as this firewall rule should fix the MTU problems dynamically, without having to modify your VPN MTU. ![]()
hmm… the rule is still there, I even restarted the sys-vpn
If I set MTU in the network-manager, in the special VPN-connection to automatic instead of 1280, the connection is dead.
If I turn off the VPN connection, I even can ping jumbo packets with 9000
MTU=1376 is the highest possibility
Get also a problem with another wireguard connection to another network (here with OPNsense WG-server).
It seems to have no matter what MTU I set on the client. If I connect, I can ping exactly for times with very bad speed (about 200ms) and then connection dies. If I just reconnect, I can send again 4 pings.
not sure, if it has something to do with the OPNsense
Edit:
false key setting was the problem on the laptop and not MTU:
