Since some weeks ago when I boot my laptop the wifi card is not detected. It happens randomly: sometimes I boot and everything is fine but sometimes the only way to connect to internet is via ethernet.
I’m running QubesOs R4.2.4 on HP Pavillion laptop. My sys-net qube is fedora-40-xfce based with 6.12.21 kernel.
When the problem appears I can see the following on sys-net qube:
- commands
$ iw listand$ iw devproduce no output - the kernel driver of the wifi card is not loaded:
$ lspci -v
00:06.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 16)
Subsystem: Hewlett-Packard Company Device 8742
Physical Slot: 6
Flags: bus master, fast devsel, latency 0, IRQ 40
I/O ports at c200 [size=256]
Memory at f2028000 (64-bit, non-prefetchable) [size=4K]
Memory at f2020000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: r8169
Kernel modules: r8169
00:07.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
Subsystem: Hewlett-Packard Company Device 85f7
Physical Slot: 7
Flags: fast devsel, IRQ 44
I/O ports at c300 [size=256]
Memory at f2010000 (64-bit, non-prefetchable) [size=64K]
Kernel modules: rtw88_8822ce
- errors in the
dmesgoutput:
$ sudo dmesg | grep rtw
[ 3.214569] rtw_8822ce 0000:00:07.0: failed to init rx buffer
[ 3.214575] rtw_8822ce 0000:00:07.0: failed to allocate pci resources
[ 3.214583] rtw_8822ce 0000:00:07.0: failed to setup pci resources
[ 3.230186] rtw_8822ce 0000:00:07.0: WOW Firmware version 9.9.4, H2C version 15
[ 3.232044] rtw_8822ce 0000:00:07.0: probe with driver rtw_8822ce failed with error -12
- passing kernel option
pci=nomsidoesn’t help - loaded modules are:
$ lsmod | grep rtw88_8822
rtw88_8822ce 12288 0
rtw88_8822c 512000 1 rtw88_8822ce
rtw88_pci 40960 1 rtw88_8822ce
rtw88_core 307200 2 rtw88_pci,rtw88_8822c
I’ve read posts about similar problems on the forum (like this or this one) but I’ve not been able to fix the problem.
TIA for your help.
