Hello. I am having a problem with the network connection on my laptop.
This Tuesday, shortly after some near-daily updates to templates and dom0, the WiFi stopped working on ‘sys-net’ and I can no longer see the option to connect to WiFi networks. It had been working fine for the about 3 weeks prior, when I did a fresh install of Qubes. Any suggestions would be very appreciated, as I am at a loss.
I am using:
Qubes 4.2 RC4
Lenovo X1 Gen 10
All VMs are using Debian 12 template
Looking at the devices tab for sys-net from Qubes manager, I can see the network card and it is set to “always connected to this qube”. It also shows up running lspci in terminal of sys-net.
Opening a terminal on sys-net and running ‘ip a’ the WiFi interface does not show up, only lo and vif5.0
I am altogether unable to connect to the internet unless I connect with an Ethernet USB dongle.
Things I have tried:
Rebooting
Running sudo systemctl restart NetworkManager’ in sys-net terminal
I changed sys-net to use the Fedora38 template (I use Debian by default) but the problem persisted.
Trying older kernels for the Qubes Global Config
Thank you!
DVM
November 3, 2023, 11:50pm
2
Can you check what’s going on in dmesg?
In sys-net:
sudo dmesg | grep iwlwifi
Hello. Thanks for your response! It returned an empty output.
DVM
November 4, 2023, 12:01am
4
Is the driver loaded?
lsmod | grep iwlwifi
If not, what happens when you try to load it?:
sudo modprobe iwlwifi
Your wifi chip is supported since kernel 5.14 so it should work. You said that it was working before, but you did a fresh install. Did you switch from 4.1 to 4.2-rc4?
I just restarted my computer and reran the command. This is the output of your first:
user@sys-net:~$ sudo dmesg | grep iwlwifi
[ 2.275149] iwlwifi 0000:00:06.0: api flags index 2 larger than supported by driver
[ 2.275169] iwlwifi 0000:00:06.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 2.275447] iwlwifi 0000:00:06.0: loaded firmware version 72.daa05125.0 so-a0-gf-a0-72.ucode op_mode iwlmvm
[ 2.448899] iwlwifi 0000:00:06.0: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 3.503970] iwlwifi 0000:00:06.0: SecBoot CPU1 Status: 0x7f38, CPU2 Status: 0xb03
[ 3.504109] iwlwifi 0000:00:06.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 3.504213] iwlwifi 0000:00:06.0: HPM_SECONDARY_DEVICE_STATE: 0x742
[ 3.504317] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 3.504423] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 3.504528] iwlwifi 0000:00:06.0: UMAC PC: 0xc008228c
[ 3.504682] iwlwifi 0000:00:06.0: LMAC PC: 0x4d0c26
[ 3.504726] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 3.505891] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 3.505937] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 6
[ 3.505982] iwlwifi 0000:00:06.0: Loaded firmware version: 72.daa05125.0 so-a0-gf-a0-72.ucode
[ 3.506040] iwlwifi 0000:00:06.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 3.506082] iwlwifi 0000:00:06.0: 0x000002F0 | trm_hw_status0
[ 3.506123] iwlwifi 0000:00:06.0: 0x00000000 | trm_hw_status1
[ 3.506165] iwlwifi 0000:00:06.0: 0x004DAAEE | branchlink2
[ 3.506199] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink1
[ 3.506239] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink2
[ 3.506279] iwlwifi 0000:00:06.0: 0x004BD066 | data1
[ 3.506312] iwlwifi 0000:00:06.0: 0x01000000 | data2
[ 3.506346] iwlwifi 0000:00:06.0: 0x00000000 | data3
[ 3.506379] iwlwifi 0000:00:06.0: 0x00000000 | beacon time
[ 3.506412] iwlwifi 0000:00:06.0: 0x000EB176 | tsf low
[ 3.506446] iwlwifi 0000:00:06.0: 0x00000000 | tsf hi
[ 3.506480] iwlwifi 0000:00:06.0: 0x00000000 | time gp1
[ 3.506514] iwlwifi 0000:00:06.0: 0x000FF2D3 | time gp2
[ 3.506547] iwlwifi 0000:00:06.0: 0x00000001 | uCode revision type
[ 3.506617] iwlwifi 0000:00:06.0: 0x00000048 | uCode version major
[ 3.506666] iwlwifi 0000:00:06.0: 0xDAA05125 | uCode version minor
[ 3.506704] iwlwifi 0000:00:06.0: 0x00000370 | hw version
[ 3.506736] iwlwifi 0000:00:06.0: 0x10489002 | board version
[ 3.506773] iwlwifi 0000:00:06.0: 0x8001FF03 | hcmd
[ 3.506804] iwlwifi 0000:00:06.0: 0x00020000 | isr0
[ 3.506835] iwlwifi 0000:00:06.0: 0x00000000 | isr1
[ 3.506866] iwlwifi 0000:00:06.0: 0x00F00002 | isr2
[ 3.506896] iwlwifi 0000:00:06.0: 0x00C0000C | isr3
[ 3.506926] iwlwifi 0000:00:06.0: 0x00000000 | isr4
[ 3.506957] iwlwifi 0000:00:06.0: 0x00000000 | last cmd Id
[ 3.506989] iwlwifi 0000:00:06.0: 0x004BD066 | wait_event
[ 3.507019] iwlwifi 0000:00:06.0: 0x00000000 | l2p_control
[ 3.507050] iwlwifi 0000:00:06.0: 0x00000000 | l2p_duration
[ 3.507082] iwlwifi 0000:00:06.0: 0x00000000 | l2p_mhvalid
[ 3.507112] iwlwifi 0000:00:06.0: 0x00000000 | l2p_addr_match
[ 3.507149] iwlwifi 0000:00:06.0: 0x0000000B | lmpm_pmg_sel
[ 3.507180] iwlwifi 0000:00:06.0: 0x00000000 | timestamp
[ 3.507211] iwlwifi 0000:00:06.0: 0x002C0000 | flow_handler
[ 3.507319] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 3.507354] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 7
[ 3.507394] iwlwifi 0000:00:06.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 3.507433] iwlwifi 0000:00:06.0: 0x00000000 | umac branchlink1
[ 3.507470] iwlwifi 0000:00:06.0: 0x8045FDF8 | umac branchlink2
[ 3.507507] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink1
[ 3.507545] iwlwifi 0000:00:06.0: 0xC00846C2 | umac interruptlink2
[ 3.507603] iwlwifi 0000:00:06.0: 0x01000000 | umac data1
[ 3.507637] iwlwifi 0000:00:06.0: 0xC00846C2 | umac data2
[ 3.507668] iwlwifi 0000:00:06.0: 0x00000000 | umac data3
[ 3.507699] iwlwifi 0000:00:06.0: 0x00000048 | umac major
[ 3.507731] iwlwifi 0000:00:06.0: 0xDAA05125 | umac minor
[ 3.507761] iwlwifi 0000:00:06.0: 0x000FF549 | frame pointer
[ 3.507799] iwlwifi 0000:00:06.0: 0xC0887F14 | stack pointer
[ 3.507837] iwlwifi 0000:00:06.0: 0x00000000 | last host cmd
[ 3.507871] iwlwifi 0000:00:06.0: 0x00000400 | isr status reg
[ 3.507964] iwlwifi 0000:00:06.0: IML/ROM dump:
[ 3.507993] iwlwifi 0000:00:06.0: 0x00000B03 | IML/ROM error/state
[ 3.508089] iwlwifi 0000:00:06.0: 0x00007F38 | IML/ROM data1
[ 3.508180] iwlwifi 0000:00:06.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 3.508271] iwlwifi 0000:00:06.0: Fseq Registers:
[ 3.508351] iwlwifi 0000:00:06.0: 0x20000000 | FSEQ_ERROR_CODE
[ 3.508439] iwlwifi 0000:00:06.0: 0x803E0001 | FSEQ_TOP_INIT_VERSION
[ 3.508524] iwlwifi 0000:00:06.0: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 3.508630] iwlwifi 0000:00:06.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 3.508716] iwlwifi 0000:00:06.0: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 3.508797] iwlwifi 0000:00:06.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 3.508879] iwlwifi 0000:00:06.0: 0x00080400 | FSEQ_CNVI_ID
[ 3.508956] iwlwifi 0000:00:06.0: 0x00400410 | FSEQ_CNVR_ID
[ 3.509033] iwlwifi 0000:00:06.0: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 3.509117] iwlwifi 0000:00:06.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 3.509200] iwlwifi 0000:00:06.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 3.509288] iwlwifi 0000:00:06.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 3.509376] iwlwifi 0000:00:06.0: Failed to start RT ucode: -110
[ 3.509410] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 4.531291] iwlwifi 0000:00:06.0: Failed to run INIT ucode: -110
[ 4.544784] iwlwifi 0000:00:06.0: retry init count 0
[ 4.546772] iwlwifi 0000:00:06.0: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 5.615762] iwlwifi 0000:00:06.0: SecBoot CPU1 Status: 0x7f38, CPU2 Status: 0xb03
[ 5.615854] iwlwifi 0000:00:06.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 5.615925] iwlwifi 0000:00:06.0: HPM_SECONDARY_DEVICE_STATE: 0x742
[ 5.616047] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 5.616170] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 5.616242] iwlwifi 0000:00:06.0: UMAC PC: 0xc00809ea
[ 5.616313] iwlwifi 0000:00:06.0: LMAC PC: 0x4d0c26
[ 5.616329] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 5.616861] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 5.616880] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 6
[ 5.616898] iwlwifi 0000:00:06.0: Loaded firmware version: 72.daa05125.0 so-a0-gf-a0-72.ucode
[ 5.616920] iwlwifi 0000:00:06.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 5.616936] iwlwifi 0000:00:06.0: 0x000002F0 | trm_hw_status0
[ 5.616952] iwlwifi 0000:00:06.0: 0x00000000 | trm_hw_status1
[ 5.616968] iwlwifi 0000:00:06.0: 0x004DAAEE | branchlink2
[ 5.616981] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink1
[ 5.616997] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink2
[ 5.617012] iwlwifi 0000:00:06.0: 0x004BD066 | data1
[ 5.617024] iwlwifi 0000:00:06.0: 0x01000000 | data2
[ 5.617037] iwlwifi 0000:00:06.0: 0x00000000 | data3
[ 5.617050] iwlwifi 0000:00:06.0: 0x00000000 | beacon time
[ 5.617062] iwlwifi 0000:00:06.0: 0x000EE7C7 | tsf low
[ 5.617075] iwlwifi 0000:00:06.0: 0x00000000 | tsf hi
[ 5.617087] iwlwifi 0000:00:06.0: 0x00000000 | time gp1
[ 5.617100] iwlwifi 0000:00:06.0: 0x00102839 | time gp2
[ 5.617113] iwlwifi 0000:00:06.0: 0x00000001 | uCode revision type
[ 5.617128] iwlwifi 0000:00:06.0: 0x00000048 | uCode version major
[ 5.617143] iwlwifi 0000:00:06.0: 0xDAA05125 | uCode version minor
[ 5.617159] iwlwifi 0000:00:06.0: 0x00000370 | hw version
[ 5.617172] iwlwifi 0000:00:06.0: 0x18489002 | board version
[ 5.617187] iwlwifi 0000:00:06.0: 0x8001FF03 | hcmd
[ 5.617200] iwlwifi 0000:00:06.0: 0x00020000 | isr0
[ 5.617213] iwlwifi 0000:00:06.0: 0x00000000 | isr1
[ 5.617225] iwlwifi 0000:00:06.0: 0x00F00002 | isr2
[ 5.617238] iwlwifi 0000:00:06.0: 0x00C0000C | isr3
[ 5.617250] iwlwifi 0000:00:06.0: 0x00000000 | isr4
[ 5.617263] iwlwifi 0000:00:06.0: 0x00000000 | last cmd Id
[ 5.617275] iwlwifi 0000:00:06.0: 0x004BD066 | wait_event
[ 5.617288] iwlwifi 0000:00:06.0: 0x00000000 | l2p_control
[ 5.617300] iwlwifi 0000:00:06.0: 0x00000000 | l2p_duration
[ 5.617313] iwlwifi 0000:00:06.0: 0x00000000 | l2p_mhvalid
[ 5.617326] iwlwifi 0000:00:06.0: 0x00000000 | l2p_addr_match
[ 5.617341] iwlwifi 0000:00:06.0: 0x0000000B | lmpm_pmg_sel
[ 5.617354] iwlwifi 0000:00:06.0: 0x00000000 | timestamp
[ 5.617366] iwlwifi 0000:00:06.0: 0x002C0000 | flow_handler
[ 5.617553] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 5.617583] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 7
[ 5.617606] iwlwifi 0000:00:06.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 5.617622] iwlwifi 0000:00:06.0: 0x00000000 | umac branchlink1
[ 5.617637] iwlwifi 0000:00:06.0: 0x8045FDF8 | umac branchlink2
[ 5.617653] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink1
[ 5.617669] iwlwifi 0000:00:06.0: 0xC008228A | umac interruptlink2
[ 5.617684] iwlwifi 0000:00:06.0: 0x01000000 | umac data1
[ 5.617697] iwlwifi 0000:00:06.0: 0xC008228A | umac data2
[ 5.617709] iwlwifi 0000:00:06.0: 0x00000000 | umac data3
[ 5.617722] iwlwifi 0000:00:06.0: 0x00000048 | umac major
[ 5.617735] iwlwifi 0000:00:06.0: 0xDAA05125 | umac minor
[ 5.617747] iwlwifi 0000:00:06.0: 0x00102AAF | frame pointer
[ 5.617763] iwlwifi 0000:00:06.0: 0xC0887EF4 | stack pointer
[ 5.617778] iwlwifi 0000:00:06.0: 0x00000000 | last host cmd
[ 5.617793] iwlwifi 0000:00:06.0: 0x00000404 | isr status reg
[ 5.617863] iwlwifi 0000:00:06.0: IML/ROM dump:
[ 5.617875] iwlwifi 0000:00:06.0: 0x00000B03 | IML/ROM error/state
[ 5.617947] iwlwifi 0000:00:06.0: 0x00007F38 | IML/ROM data1
[ 5.618017] iwlwifi 0000:00:06.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 5.618088] iwlwifi 0000:00:06.0: Fseq Registers:
[ 5.618149] iwlwifi 0000:00:06.0: 0x60000000 | FSEQ_ERROR_CODE
[ 5.618214] iwlwifi 0000:00:06.0: 0x803E0001 | FSEQ_TOP_INIT_VERSION
[ 5.618281] iwlwifi 0000:00:06.0: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 5.618347] iwlwifi 0000:00:06.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 5.618414] iwlwifi 0000:00:06.0: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 5.618475] iwlwifi 0000:00:06.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 5.618521] iwlwifi 0000:00:06.0: 0x00080400 | FSEQ_CNVI_ID
[ 5.618594] iwlwifi 0000:00:06.0: 0x00400410 | FSEQ_CNVR_ID
[ 5.618658] iwlwifi 0000:00:06.0: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 5.618727] iwlwifi 0000:00:06.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 5.618796] iwlwifi 0000:00:06.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 5.618867] iwlwifi 0000:00:06.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 5.618934] iwlwifi 0000:00:06.0: Failed to start RT ucode: -110
[ 5.618951] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.683078] iwlwifi 0000:00:06.0: Failed to run INIT ucode: -110
[ 6.696002] iwlwifi 0000:00:06.0: retry init count 1
[ 6.698184] iwlwifi 0000:00:06.0: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 7.727807] iwlwifi 0000:00:06.0: SecBoot CPU1 Status: 0x7f7b, CPU2 Status: 0xb03
[ 7.727935] iwlwifi 0000:00:06.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 7.728036] iwlwifi 0000:00:06.0: HPM_SECONDARY_DEVICE_STATE: 0x742
[ 7.728138] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 7.728231] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 7.728336] iwlwifi 0000:00:06.0: UMAC PC: 0xc008228a
[ 7.728433] iwlwifi 0000:00:06.0: LMAC PC: 0x4d0c26
[ 7.728476] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 7.729781] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 7.729835] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 6
[ 7.729895] iwlwifi 0000:00:06.0: Loaded firmware version: 72.daa05125.0 so-a0-gf-a0-72.ucode
[ 7.729965] iwlwifi 0000:00:06.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7.730020] iwlwifi 0000:00:06.0: 0x000002F0 | trm_hw_status0
[ 7.730070] iwlwifi 0000:00:06.0: 0x00000000 | trm_hw_status1
[ 7.730119] iwlwifi 0000:00:06.0: 0x004DAAEE | branchlink2
[ 7.730157] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink1
[ 7.730203] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink2
[ 7.730248] iwlwifi 0000:00:06.0: 0x004BD066 | data1
[ 7.730285] iwlwifi 0000:00:06.0: 0x01000000 | data2
[ 7.730323] iwlwifi 0000:00:06.0: 0x00000000 | data3
[ 7.730360] iwlwifi 0000:00:06.0: 0x00000000 | beacon time
[ 7.730397] iwlwifi 0000:00:06.0: 0x000E5171 | tsf low
[ 7.730436] iwlwifi 0000:00:06.0: 0x00000000 | tsf hi
[ 7.730482] iwlwifi 0000:00:06.0: 0x00000000 | time gp1
[ 7.730519] iwlwifi 0000:00:06.0: 0x000F91F9 | time gp2
[ 7.730557] iwlwifi 0000:00:06.0: 0x00000001 | uCode revision type
[ 7.730633] iwlwifi 0000:00:06.0: 0x00000048 | uCode version major
[ 7.730680] iwlwifi 0000:00:06.0: 0xDAA05125 | uCode version minor
[ 7.730726] iwlwifi 0000:00:06.0: 0x00000370 | hw version
[ 7.730763] iwlwifi 0000:00:06.0: 0x18489002 | board version
[ 7.730809] iwlwifi 0000:00:06.0: 0x8001FF03 | hcmd
[ 7.730845] iwlwifi 0000:00:06.0: 0x00020000 | isr0
[ 7.730879] iwlwifi 0000:00:06.0: 0x00000000 | isr1
[ 7.730913] iwlwifi 0000:00:06.0: 0x00F00002 | isr2
[ 7.730949] iwlwifi 0000:00:06.0: 0x00C0000C | isr3
[ 7.730983] iwlwifi 0000:00:06.0: 0x00000000 | isr4
[ 7.731016] iwlwifi 0000:00:06.0: 0x00000000 | last cmd Id
[ 7.731050] iwlwifi 0000:00:06.0: 0x004BD066 | wait_event
[ 7.731085] iwlwifi 0000:00:06.0: 0x00000000 | l2p_control
[ 7.731118] iwlwifi 0000:00:06.0: 0x00000000 | l2p_duration
[ 7.731152] iwlwifi 0000:00:06.0: 0x00000000 | l2p_mhvalid
[ 7.731186] iwlwifi 0000:00:06.0: 0x00000000 | l2p_addr_match
[ 7.731227] iwlwifi 0000:00:06.0: 0x0000000B | lmpm_pmg_sel
[ 7.731261] iwlwifi 0000:00:06.0: 0x00000000 | timestamp
[ 7.731294] iwlwifi 0000:00:06.0: 0x002C0000 | flow_handler
[ 7.731407] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 7.731442] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 7
[ 7.731484] iwlwifi 0000:00:06.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 7.731526] iwlwifi 0000:00:06.0: 0x00000000 | umac branchlink1
[ 7.731604] iwlwifi 0000:00:06.0: 0x8045FDF8 | umac branchlink2
[ 7.731648] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink1
[ 7.731689] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink2
[ 7.731731] iwlwifi 0000:00:06.0: 0x01000000 | umac data1
[ 7.731766] iwlwifi 0000:00:06.0: 0x804805CE | umac data2
[ 7.731800] iwlwifi 0000:00:06.0: 0x00000000 | umac data3
[ 7.731832] iwlwifi 0000:00:06.0: 0x00000048 | umac major
[ 7.731865] iwlwifi 0000:00:06.0: 0xDAA05125 | umac minor
[ 7.731895] iwlwifi 0000:00:06.0: 0x000F9480 | frame pointer
[ 7.731934] iwlwifi 0000:00:06.0: 0xC088625C | stack pointer
[ 7.731971] iwlwifi 0000:00:06.0: 0x00000000 | last host cmd
[ 7.732009] iwlwifi 0000:00:06.0: 0x00000400 | isr status reg
[ 7.732103] iwlwifi 0000:00:06.0: IML/ROM dump:
[ 7.732134] iwlwifi 0000:00:06.0: 0x00000B03 | IML/ROM error/state
[ 7.732228] iwlwifi 0000:00:06.0: 0x00007F7B | IML/ROM data1
[ 7.732310] iwlwifi 0000:00:06.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 7.732401] iwlwifi 0000:00:06.0: Fseq Registers:
[ 7.732471] iwlwifi 0000:00:06.0: 0x60000000 | FSEQ_ERROR_CODE
[ 7.732546] iwlwifi 0000:00:06.0: 0x803E0001 | FSEQ_TOP_INIT_VERSION
[ 7.732661] iwlwifi 0000:00:06.0: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 7.732747] iwlwifi 0000:00:06.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 7.732834] iwlwifi 0000:00:06.0: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 7.732913] iwlwifi 0000:00:06.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7.732980] iwlwifi 0000:00:06.0: 0x00080400 | FSEQ_CNVI_ID
[ 7.733049] iwlwifi 0000:00:06.0: 0x00400410 | FSEQ_CNVR_ID
[ 7.733126] iwlwifi 0000:00:06.0: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 7.733214] iwlwifi 0000:00:06.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 7.733300] iwlwifi 0000:00:06.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7.733391] iwlwifi 0000:00:06.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7.733478] iwlwifi 0000:00:06.0: Failed to start RT ucode: -110
[ 7.733516] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 8.789532] iwlwifi 0000:00:06.0: Failed to run INIT ucode: -110
[ 8.802638] iwlwifi 0000:00:06.0: retry init count 2
As for your second question: I installed with 4.2-rc4 fresh. I had not used Qubes before this.
While troubleshooting I also switched from Debian to Fedora with no change in results.
(Edited for clarity)
DVM
November 4, 2023, 12:21am
7
It was working on 4.2-rc4 when you first installed it?
What’s the current kernel running in sys-net (uname -r)?
Also, can you share the output from this command in sys-net (with fedora template):
rpm -qa | grep firmware
Yes, my internet worked for about three weeks after installation, totally without incident. To my knowledge, I did not tinker with anything to make it stop working.
Current kernel: 6.1.57-1.qubes.fc37.x86_64
Output:
ii amd64-microcode 3.20230808.1.1~deb12u1 amd64 Processor microcode firmware for AMD CPUs
ii atmel-firmware 1.3-7 all Firmware for Atmel at76c50x wireless networking chips.
ii firmware-amd-graphics 20230210-5 all Binary firmware for AMD/ATI graphics chips
ii firmware-ath9k-htc 1.4.0-108-gd856466+dfsg1-1.3+deb12u1 all firmware for AR7010 and AR9271 USB wireless adapters
ii firmware-atheros 20230210-5 all Binary firmware for Qualcomm Atheros wireless cards
ii firmware-brcm80211 20230210-5 all Binary firmware for Broadcom/Cypress 802.11 wireless cards
ii firmware-ipw2x00 20230210-5 all Binary firmware for Intel Pro Wireless 2100, 2200 and 2915
ii firmware-iwlwifi 20230210-5 all Binary firmware for Intel Wireless cards
ii firmware-linux 20230210-5 all Binary firmware for various drivers in the Linux kernel (metapackage)
ii firmware-linux-free 20200122-1 all Binary firmware for various drivers in the Linux kernel
ii firmware-linux-nonfree 20230210-5 all Binary firmware for various drivers in the Linux kernel (metapackage)
ii firmware-misc-nonfree 20230210-5 all Binary firmware for various drivers in the Linux kernel
ii firmware-realtek 20230210-5 all Binary firmware for Realtek wired/wifi/BT adapters
ii firmware-zd1211 1:1.5-10 all binary firmware for the zd1211rw wireless driver
ii intel-microcode 3.20230808.1~deb12u1 amd64 Processor microcode firmware for Intel CPUs
ii ipxe-qemu 1.0.0+git-20190125.36a4c85-5.1 all PXE boot firmware - ROM images for qemu
ii ovmf 2022.11-6 all UEFI firmware for 64-bit x86 virtual machines
DVM
November 4, 2023, 12:28am
9
This look like a debian dpkg -l command output. Can you switch to Fedora instead?
Ok, here is the current kernel: 6.1.57-1.qubes.fc37.x86_64
Fedora output:
user@sys-net:~$ rpm -qa | grep firmware
linux-firmware-whence-20231030-1.fc38.noarch
amd-ucode-firmware-20231030-1.fc38.noarch
amd-gpu-firmware-20231030-1.fc38.noarch
atheros-firmware-20231030-1.fc38.noarch
brcmfmac-firmware-20231030-1.fc38.noarch
intel-gpu-firmware-20231030-1.fc38.noarch
mt7xxx-firmware-20231030-1.fc38.noarch
nvidia-gpu-firmware-20231030-1.fc38.noarch
realtek-firmware-20231030-1.fc38.noarch
linux-firmware-20231030-1.fc38.noarch
iwlegacy-firmware-20231030-1.fc38.noarch
iwlwifi-dvm-firmware-20231030-1.fc38.noarch
iwlwifi-mvm-firmware-20231030-1.fc38.noarch
libertas-firmware-20231030-1.fc38.noarch
alsa-sof-firmware-2023.09-1.fc38.noarch
DVM
November 4, 2023, 12:41am
11
The firmware packages are updated to latest so it seems good here.
Can you check dmesg again and see what’s going on with the same command I provided earlier?
Here is the dmesg. Is this what you mean?
[ 2.809591] iwlwifi 0000:00:06.0: api flags index 2 larger than supported by driver
[ 2.809604] iwlwifi 0000:00:06.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 2.809855] iwlwifi 0000:00:06.0: loaded firmware version 72.a764baac.0 so-a0-gf-a0-72.ucode op_mode iwlmvm
[ 2.943230] iwlwifi 0000:00:06.0: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 4.007790] iwlwifi 0000:00:06.0: SecBoot CPU1 Status: 0x8066, CPU2 Status: 0xb03
[ 4.008185] iwlwifi 0000:00:06.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 4.008323] iwlwifi 0000:00:06.0: HPM_SECONDARY_DEVICE_STATE: 0x742
[ 4.008595] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 4.008724] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 4.008849] iwlwifi 0000:00:06.0: UMAC PC: 0xc00818f0
[ 4.009168] iwlwifi 0000:00:06.0: LMAC PC: 0x4d0c26
[ 4.009226] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 4.010395] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 4.010462] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 6
[ 4.010517] iwlwifi 0000:00:06.0: Loaded firmware version: 72.a764baac.0 so-a0-gf-a0-72.ucode
[ 4.010588] iwlwifi 0000:00:06.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 4.010641] iwlwifi 0000:00:06.0: 0x000002F0 | trm_hw_status0
[ 4.010693] iwlwifi 0000:00:06.0: 0x00000000 | trm_hw_status1
[ 4.010744] iwlwifi 0000:00:06.0: 0x004DAAEE | branchlink2
[ 4.010786] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink1
[ 4.010837] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink2
[ 4.010887] iwlwifi 0000:00:06.0: 0x004BD066 | data1
[ 4.010928] iwlwifi 0000:00:06.0: 0x01000000 | data2
[ 4.011033] iwlwifi 0000:00:06.0: 0x00000000 | data3
[ 4.011073] iwlwifi 0000:00:06.0: 0x00000000 | beacon time
[ 4.011110] iwlwifi 0000:00:06.0: 0x000ED413 | tsf low
[ 4.011148] iwlwifi 0000:00:06.0: 0x00000000 | tsf hi
[ 4.011185] iwlwifi 0000:00:06.0: 0x00000000 | time gp1
[ 4.011230] iwlwifi 0000:00:06.0: 0x001015DD | time gp2
[ 4.011267] iwlwifi 0000:00:06.0: 0x00000001 | uCode revision type
[ 4.011312] iwlwifi 0000:00:06.0: 0x00000048 | uCode version major
[ 4.011358] iwlwifi 0000:00:06.0: 0xA764BAAC | uCode version minor
[ 4.011404] iwlwifi 0000:00:06.0: 0x00000370 | hw version
[ 4.011441] iwlwifi 0000:00:06.0: 0x18489002 | board version
[ 4.011486] iwlwifi 0000:00:06.0: 0x8001FF03 | hcmd
[ 4.011523] iwlwifi 0000:00:06.0: 0x00020000 | isr0
[ 4.011560] iwlwifi 0000:00:06.0: 0x00000000 | isr1
[ 4.011597] iwlwifi 0000:00:06.0: 0x00F00002 | isr2
[ 4.011634] iwlwifi 0000:00:06.0: 0x00C0000C | isr3
[ 4.011671] iwlwifi 0000:00:06.0: 0x00000000 | isr4
[ 4.011709] iwlwifi 0000:00:06.0: 0x00000000 | last cmd Id
[ 4.011745] iwlwifi 0000:00:06.0: 0x004BD066 | wait_event
[ 4.011783] iwlwifi 0000:00:06.0: 0x00000000 | l2p_control
[ 4.011821] iwlwifi 0000:00:06.0: 0x00000000 | l2p_duration
[ 4.011858] iwlwifi 0000:00:06.0: 0x00000000 | l2p_mhvalid
[ 4.011894] iwlwifi 0000:00:06.0: 0x00000000 | l2p_addr_match
[ 4.011961] iwlwifi 0000:00:06.0: 0x0000000B | lmpm_pmg_sel
[ 4.011996] iwlwifi 0000:00:06.0: 0x00000000 | timestamp
[ 4.012030] iwlwifi 0000:00:06.0: 0x002C0000 | flow_handler
[ 4.012145] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 4.012182] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 7
[ 4.012224] iwlwifi 0000:00:06.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 4.012266] iwlwifi 0000:00:06.0: 0x00000000 | umac branchlink1
[ 4.012307] iwlwifi 0000:00:06.0: 0x8045FDF8 | umac branchlink2
[ 4.012349] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink1
[ 4.012390] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink2
[ 4.012431] iwlwifi 0000:00:06.0: 0x01000000 | umac data1
[ 4.012464] iwlwifi 0000:00:06.0: 0x804805CE | umac data2
[ 4.012499] iwlwifi 0000:00:06.0: 0x00000000 | umac data3
[ 4.012532] iwlwifi 0000:00:06.0: 0x00000048 | umac major
[ 4.012566] iwlwifi 0000:00:06.0: 0xA764BAAC | umac minor
[ 4.012600] iwlwifi 0000:00:06.0: 0x00101855 | frame pointer
[ 4.012640] iwlwifi 0000:00:06.0: 0xC088625C | stack pointer
[ 4.012680] iwlwifi 0000:00:06.0: 0x00000000 | last host cmd
[ 4.012721] iwlwifi 0000:00:06.0: 0x00000400 | isr status reg
[ 4.012819] iwlwifi 0000:00:06.0: IML/ROM dump:
[ 4.012853] iwlwifi 0000:00:06.0: 0x00000B03 | IML/ROM error/state
[ 4.013073] iwlwifi 0000:00:06.0: 0x00008066 | IML/ROM data1
[ 4.013168] iwlwifi 0000:00:06.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 4.013258] iwlwifi 0000:00:06.0: Fseq Registers:
[ 4.013339] iwlwifi 0000:00:06.0: 0x60000100 | FSEQ_ERROR_CODE
[ 4.013426] iwlwifi 0000:00:06.0: 0x003E0003 | FSEQ_TOP_INIT_VERSION
[ 4.013514] iwlwifi 0000:00:06.0: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 4.013602] iwlwifi 0000:00:06.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 4.013691] iwlwifi 0000:00:06.0: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 4.013777] iwlwifi 0000:00:06.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4.013863] iwlwifi 0000:00:06.0: 0x00080400 | FSEQ_CNVI_ID
[ 4.013961] iwlwifi 0000:00:06.0: 0x00400410 | FSEQ_CNVR_ID
[ 4.014040] iwlwifi 0000:00:06.0: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 4.014126] iwlwifi 0000:00:06.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 4.014212] iwlwifi 0000:00:06.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4.014291] iwlwifi 0000:00:06.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4.014360] iwlwifi 0000:00:06.0: Failed to start RT ucode: -110
[ 4.014377] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 5.422146] iwlwifi 0000:00:06.0: Failed to run INIT ucode: -110
[ 5.437201] iwlwifi 0000:00:06.0: retry init count 0
[ 5.438559] iwlwifi 0000:00:06.0: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 6.503194] iwlwifi 0000:00:06.0: SecBoot CPU1 Status: 0x80cc, CPU2 Status: 0xb03
[ 6.503294] iwlwifi 0000:00:06.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 6.503373] iwlwifi 0000:00:06.0: HPM_SECONDARY_DEVICE_STATE: 0x742
[ 6.503452] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 6.503531] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 6.503610] iwlwifi 0000:00:06.0: UMAC PC: 0xc008228a
[ 6.503686] iwlwifi 0000:00:06.0: LMAC PC: 0x4d0c26
[ 6.503707] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.504489] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 6.504521] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 6
[ 6.504547] iwlwifi 0000:00:06.0: Loaded firmware version: 72.a764baac.0 so-a0-gf-a0-72.ucode
[ 6.504578] iwlwifi 0000:00:06.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 6.504602] iwlwifi 0000:00:06.0: 0x000002F0 | trm_hw_status0
[ 6.504624] iwlwifi 0000:00:06.0: 0x00000000 | trm_hw_status1
[ 6.504647] iwlwifi 0000:00:06.0: 0x004DAAEE | branchlink2
[ 6.504665] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink1
[ 6.504688] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink2
[ 6.504710] iwlwifi 0000:00:06.0: 0x004BD066 | data1
[ 6.504728] iwlwifi 0000:00:06.0: 0x01000000 | data2
[ 6.504747] iwlwifi 0000:00:06.0: 0x00000000 | data3
[ 6.504765] iwlwifi 0000:00:06.0: 0x00000000 | beacon time
[ 6.504783] iwlwifi 0000:00:06.0: 0x000EAE6E | tsf low
[ 6.504801] iwlwifi 0000:00:06.0: 0x00000000 | tsf hi
[ 6.504820] iwlwifi 0000:00:06.0: 0x00000000 | time gp1
[ 6.504838] iwlwifi 0000:00:06.0: 0x000FF0D6 | time gp2
[ 6.504856] iwlwifi 0000:00:06.0: 0x00000001 | uCode revision type
[ 6.504879] iwlwifi 0000:00:06.0: 0x00000048 | uCode version major
[ 6.504902] iwlwifi 0000:00:06.0: 0xA764BAAC | uCode version minor
[ 6.504925] iwlwifi 0000:00:06.0: 0x00000370 | hw version
[ 6.504977] iwlwifi 0000:00:06.0: 0x18489002 | board version
[ 6.505000] iwlwifi 0000:00:06.0: 0x8001FF03 | hcmd
[ 6.505018] iwlwifi 0000:00:06.0: 0x00020000 | isr0
[ 6.505036] iwlwifi 0000:00:06.0: 0x00000000 | isr1
[ 6.505055] iwlwifi 0000:00:06.0: 0x00F00002 | isr2
[ 6.505073] iwlwifi 0000:00:06.0: 0x00C0000C | isr3
[ 6.505091] iwlwifi 0000:00:06.0: 0x00000000 | isr4
[ 6.505110] iwlwifi 0000:00:06.0: 0x00000000 | last cmd Id
[ 6.505128] iwlwifi 0000:00:06.0: 0x004BD066 | wait_event
[ 6.505147] iwlwifi 0000:00:06.0: 0x00000000 | l2p_control
[ 6.505165] iwlwifi 0000:00:06.0: 0x00000000 | l2p_duration
[ 6.505183] iwlwifi 0000:00:06.0: 0x00000000 | l2p_mhvalid
[ 6.505202] iwlwifi 0000:00:06.0: 0x00000000 | l2p_addr_match
[ 6.505224] iwlwifi 0000:00:06.0: 0x0000000B | lmpm_pmg_sel
[ 6.505242] iwlwifi 0000:00:06.0: 0x00000000 | timestamp
[ 6.505260] iwlwifi 0000:00:06.0: 0x002C0000 | flow_handler
[ 6.505354] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 6.505373] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 7
[ 6.505396] iwlwifi 0000:00:06.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 6.505419] iwlwifi 0000:00:06.0: 0x00000000 | umac branchlink1
[ 6.505441] iwlwifi 0000:00:06.0: 0x8045FDF8 | umac branchlink2
[ 6.505464] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink1
[ 6.505488] iwlwifi 0000:00:06.0: 0x8047A9AE | umac interruptlink2
[ 6.505510] iwlwifi 0000:00:06.0: 0x01000000 | umac data1
[ 6.505529] iwlwifi 0000:00:06.0: 0x8047A9AE | umac data2
[ 6.505547] iwlwifi 0000:00:06.0: 0x00000000 | umac data3
[ 6.505565] iwlwifi 0000:00:06.0: 0x00000048 | umac major
[ 6.505583] iwlwifi 0000:00:06.0: 0xA764BAAC | umac minor
[ 6.505602] iwlwifi 0000:00:06.0: 0x000FF34D | frame pointer
[ 6.505624] iwlwifi 0000:00:06.0: 0xC0887EF4 | stack pointer
[ 6.505646] iwlwifi 0000:00:06.0: 0x00000000 | last host cmd
[ 6.505668] iwlwifi 0000:00:06.0: 0x00000404 | isr status reg
[ 6.505748] iwlwifi 0000:00:06.0: IML/ROM dump:
[ 6.505766] iwlwifi 0000:00:06.0: 0x00000B03 | IML/ROM error/state
[ 6.505844] iwlwifi 0000:00:06.0: 0x000080CC | IML/ROM data1
[ 6.505921] iwlwifi 0000:00:06.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 6.506012] iwlwifi 0000:00:06.0: Fseq Registers:
[ 6.506080] iwlwifi 0000:00:06.0: 0x60000100 | FSEQ_ERROR_CODE
[ 6.506150] iwlwifi 0000:00:06.0: 0x003E0003 | FSEQ_TOP_INIT_VERSION
[ 6.506221] iwlwifi 0000:00:06.0: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 6.506295] iwlwifi 0000:00:06.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 6.506368] iwlwifi 0000:00:06.0: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 6.506439] iwlwifi 0000:00:06.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 6.506510] iwlwifi 0000:00:06.0: 0x00080400 | FSEQ_CNVI_ID
[ 6.506575] iwlwifi 0000:00:06.0: 0x00400410 | FSEQ_CNVR_ID
[ 6.506641] iwlwifi 0000:00:06.0: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 6.506712] iwlwifi 0000:00:06.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 6.506783] iwlwifi 0000:00:06.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 6.506859] iwlwifi 0000:00:06.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 6.506927] iwlwifi 0000:00:06.0: Failed to start RT ucode: -110
[ 6.506978] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 7.481167] iwlwifi 0000:00:06.0: Failed to run INIT ucode: -110
[ 7.495349] iwlwifi 0000:00:06.0: retry init count 1
[ 7.497532] iwlwifi 0000:00:06.0: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x370
[ 8.551261] iwlwifi 0000:00:06.0: SecBoot CPU1 Status: 0x8066, CPU2 Status: 0xb03
[ 8.551385] iwlwifi 0000:00:06.0: WFPM_LMAC1_PD_NOTIFICATION: 0x0
[ 8.551533] iwlwifi 0000:00:06.0: HPM_SECONDARY_DEVICE_STATE: 0x742
[ 8.551626] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_ADDR: 0x0
[ 8.551719] iwlwifi 0000:00:06.0: WFPM_MAC_OTP_CFG7_DATA: 0x0
[ 8.551810] iwlwifi 0000:00:06.0: UMAC PC: 0x8047a9a0
[ 8.551896] iwlwifi 0000:00:06.0: LMAC PC: 0x4d0c26
[ 8.551929] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 8.553102] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 8.553148] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 6
[ 8.553188] iwlwifi 0000:00:06.0: Loaded firmware version: 72.a764baac.0 so-a0-gf-a0-72.ucode
[ 8.553239] iwlwifi 0000:00:06.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 8.553277] iwlwifi 0000:00:06.0: 0x000002F0 | trm_hw_status0
[ 8.553311] iwlwifi 0000:00:06.0: 0x00000000 | trm_hw_status1
[ 8.553342] iwlwifi 0000:00:06.0: 0x004DAAEE | branchlink2
[ 8.553370] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink1
[ 8.553401] iwlwifi 0000:00:06.0: 0x004D0C26 | interruptlink2
[ 8.553432] iwlwifi 0000:00:06.0: 0x004BD066 | data1
[ 8.553458] iwlwifi 0000:00:06.0: 0x01000000 | data2
[ 8.553484] iwlwifi 0000:00:06.0: 0x00000000 | data3
[ 8.553511] iwlwifi 0000:00:06.0: 0x00000000 | beacon time
[ 8.553537] iwlwifi 0000:00:06.0: 0x000E9C91 | tsf low
[ 8.553562] iwlwifi 0000:00:06.0: 0x00000000 | tsf hi
[ 8.553591] iwlwifi 0000:00:06.0: 0x00000000 | time gp1
[ 8.553618] iwlwifi 0000:00:06.0: 0x000FDE92 | time gp2
[ 8.553645] iwlwifi 0000:00:06.0: 0x00000001 | uCode revision type
[ 8.553676] iwlwifi 0000:00:06.0: 0x00000048 | uCode version major
[ 8.553708] iwlwifi 0000:00:06.0: 0xA764BAAC | uCode version minor
[ 8.553740] iwlwifi 0000:00:06.0: 0x00000370 | hw version
[ 8.553765] iwlwifi 0000:00:06.0: 0x18489002 | board version
[ 8.553797] iwlwifi 0000:00:06.0: 0x8001FF03 | hcmd
[ 8.553822] iwlwifi 0000:00:06.0: 0x00020000 | isr0
[ 8.553849] iwlwifi 0000:00:06.0: 0x00000000 | isr1
[ 8.553876] iwlwifi 0000:00:06.0: 0x00F00002 | isr2
[ 8.553902] iwlwifi 0000:00:06.0: 0x00C0000C | isr3
[ 8.553927] iwlwifi 0000:00:06.0: 0x00000000 | isr4
[ 8.553977] iwlwifi 0000:00:06.0: 0x00000000 | last cmd Id
[ 8.554003] iwlwifi 0000:00:06.0: 0x004BD066 | wait_event
[ 8.554030] iwlwifi 0000:00:06.0: 0x00000000 | l2p_control
[ 8.554056] iwlwifi 0000:00:06.0: 0x00000000 | l2p_duration
[ 8.554083] iwlwifi 0000:00:06.0: 0x00000000 | l2p_mhvalid
[ 8.554108] iwlwifi 0000:00:06.0: 0x00000000 | l2p_addr_match
[ 8.554139] iwlwifi 0000:00:06.0: 0x0000000B | lmpm_pmg_sel
[ 8.554165] iwlwifi 0000:00:06.0: 0x00000000 | timestamp
[ 8.554190] iwlwifi 0000:00:06.0: 0x002C0000 | flow_handler
[ 8.554297] iwlwifi 0000:00:06.0: Start IWL Error Log Dump:
[ 8.554325] iwlwifi 0000:00:06.0: Transport status: 0x00000042, valid: 7
[ 8.554355] iwlwifi 0000:00:06.0: 0x20000066 | NMI_INTERRUPT_HOST
[ 8.554385] iwlwifi 0000:00:06.0: 0x00000000 | umac branchlink1
[ 8.554413] iwlwifi 0000:00:06.0: 0x8045FDF8 | umac branchlink2
[ 8.554444] iwlwifi 0000:00:06.0: 0x804805CE | umac interruptlink1
[ 8.554473] iwlwifi 0000:00:06.0: 0xC00819B0 | umac interruptlink2
[ 8.554502] iwlwifi 0000:00:06.0: 0x01000000 | umac data1
[ 8.554525] iwlwifi 0000:00:06.0: 0xC00819B0 | umac data2
[ 8.554549] iwlwifi 0000:00:06.0: 0x00000000 | umac data3
[ 8.554574] iwlwifi 0000:00:06.0: 0x00000048 | umac major
[ 8.554597] iwlwifi 0000:00:06.0: 0xA764BAAC | umac minor
[ 8.554620] iwlwifi 0000:00:06.0: 0x000FE109 | frame pointer
[ 8.554649] iwlwifi 0000:00:06.0: 0xC0887EFC | stack pointer
[ 8.554677] iwlwifi 0000:00:06.0: 0x00000000 | last host cmd
[ 8.554707] iwlwifi 0000:00:06.0: 0x00000400 | isr status reg
[ 8.554793] iwlwifi 0000:00:06.0: IML/ROM dump:
[ 8.554817] iwlwifi 0000:00:06.0: 0x00000B03 | IML/ROM error/state
[ 8.554903] iwlwifi 0000:00:06.0: 0x00008066 | IML/ROM data1
[ 8.555018] iwlwifi 0000:00:06.0: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[ 8.555094] iwlwifi 0000:00:06.0: Fseq Registers:
[ 8.555166] iwlwifi 0000:00:06.0: 0x60000100 | FSEQ_ERROR_CODE
[ 8.555250] iwlwifi 0000:00:06.0: 0x003E0003 | FSEQ_TOP_INIT_VERSION
[ 8.555329] iwlwifi 0000:00:06.0: 0x00190002 | FSEQ_CNVIO_INIT_VERSION
[ 8.555406] iwlwifi 0000:00:06.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 8.555481] iwlwifi 0000:00:06.0: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 8.555556] iwlwifi 0000:00:06.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 8.555636] iwlwifi 0000:00:06.0: 0x00080400 | FSEQ_CNVI_ID
[ 8.555709] iwlwifi 0000:00:06.0: 0x00400410 | FSEQ_CNVR_ID
[ 8.555782] iwlwifi 0000:00:06.0: 0x00080400 | CNVI_AUX_MISC_CHIP
[ 8.555863] iwlwifi 0000:00:06.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 8.555955] iwlwifi 0000:00:06.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 8.556051] iwlwifi 0000:00:06.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 8.556132] iwlwifi 0000:00:06.0: Failed to start RT ucode: -110
[ 8.556161] iwlwifi 0000:00:06.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 9.654698] iwlwifi 0000:00:06.0: Failed to run INIT ucode: -110
[ 9.668238] iwlwifi 0000:00:06.0: retry init count 2
DVM
November 4, 2023, 12:54am
13
For some reason the driver try to load but can’t work properly so it keep loading it in loop.
You can try to use a newer kernel and see if it changes anything.
In a dom0 terminal:
sudo qubes-dom0-update kernel-latest kernel-latest-qubes-vm
It will install kernel 6.4.8 for both dom0 and all qubes (VMs).
Once done, reboot sys-net. It should run on the new kernel.
Ran the update command in dom0 but I already have the latest kernel
DVM
November 4, 2023, 1:26am
15
If you have it, check if you can set it to sys-net in the VM settings. It’s in the “Advanced” tab in the kernel section.
Sorry for the newbie question: by “it” are you referring to dom0, which I just updated?
DVM
November 4, 2023, 1:50am
17
You have a kernel for both dom0 and VMs.
For each VMs, you have a settings menu where you can change the base template and more stuff. It’s in there that you can change the kernel (in “Advanced”).
I was also having WiFi issues this week, though thankfully milder.
On a thinkpad p15 g2 I was trying to connect to a new network and it would only give me a really short time window after sys-net booted up and I got a pop up about available networks to select to connect to a network. After that it would show no networks available at all. This has not happened before as I usually can see all the available networks at any time. I had to reboot/reset sys-net a few times but after a few tries I was able to connect to a network, and autoconnect seemed to work after that.
You can try to attach your network card with permissive=True option.
Get your network card DEVID from the output of this command in dom0 terminal:
qvm-pci ls | grep sys-net
Then run the commands below in dom0 terminal but replace xx_xx.x with DEVID of your network card:
qvm-pci detach sys-net dom0:xx_xx.x
qvm-pci attach -o permissive=True --persistent sys-net dom0:xx_xx.x
But be aware that:
NOTE: The permissive flag increases attack surface and possibility of side channel attacks. While using the no-strict-reset flag, do not require PCI device to be reset before attaching it to another VM. This may leak usage data even without malicious intent. Both permissive and no-strict-reset options may not be necessary and you should try one first, then the other, before using both.
DMA errors VMs with attached PCI devices in Qubes have allocated a small buffer for DMA operations (called swiotlb). By default, it is 2MB, but some devices (such as the Realtek RTL8111DL Gigabit Ethernet Controller) need a larger DMA buffer size....
If it’ll work with permissive=True then you can open an issue on github and report this regression, maybe it’s a bug and could be fixed.
You can also try to add pci=nomsi to the qube’s kernelopts with qvm-prefs in dom0 terminal instead of permissive=True option.
Hello, DVM. Thank you again for your help. I have just set my sys-net kernel to 6.4.8 (as I understand, that is what you last suggested) and rebooted the VM. Unfortunately I don’t see any changes.
I’m considering a fresh install of Qubes. Thoughts?
