It has happened a few times now when resuming Qubes, that the “Wi-Fi Networks” disappear on resume. I still see the ethernet networks but that’s it. Any ideas how to troubleshoot? I wind up having to reboot. I tried this but it did not help.
Do you mean the little (network manager) icon in the system tray?
Yes but the internet at the same time fails to work/connect.
Then we’re experiencing the same bug probably. We should report it.
As a quick fix for now, instead of having to reboot the whole system you can just run on a dom0 terminal (XFCE Terminal).
qvm-run sys-net "pkill nm-applet; nm-applet"
The above will run pkill nm-applet; nm-applet on sys-net. Essentially killing the the network manager applet and restarting it.
Just to see if it happens on a specific environment:
- are you running on i3wm? (If you have no idea, then you’re probably on XFCE – the default)
I will try this next time it happens!
It happened for me on both, XFCE and i3. So probably independent of the environment.
Did you try ‘sudo systemctl wpa_supplicant.service restart’ ?
That has worked for me on a couple occasions. You could also try it with
‘NetworkManager.service’.
If the above doesn’t work, another work-around to save you from
rebooting your whole machine is to ‘sudo halt’ in the sys-net vm. You
can then start it again from dom0 with ‘qvm-start sys-net’ and Qubes
will automatically link it back up with any dependent vms.
I have the same issue where network icons are disappearing at one point, but the wifi and ethernet connection will still work even without icons,
and like @deeplow said before, it will be back when I apply the following command :
Thanks it worked for me too
