Wi-Fi hotspot from Qubes OS using udev
This guide is for configuring Wi-Fi hotspot disposable qube using udev rules.
You can refer to this guide as a base:
But compared to it, this guide will allow you to dynamically attach/detach USB Wi-Fi adapter to the Wi-Fi hotspot qube.
Follow the base guide linked above, but instead of editing the /rw/config/rc.local script, run the following commands in the terminal of Wi-Fi hotspot disposable template qube.
Run these commands to set SSID and password, but change “your_ssid_name_here” and “the_PSK_password” to your own:
WIFI_SSID="your_ssid_name_here"
WIFI_PASSWORD="the_PSK_password"
Then run these commands in the same terminal to create the configuration files:
sudo mkdir -p /rw/config/qubes-bind-dirs.d/
cat << 'EOF' | sudo tee /rw/config/qubes-bind-dirs.d/50_hotspot.conf > /dev/null
binds+=( '/etc/udev/rules.d/99-wireless-detect.rules' )
EOF
sudo mkdir -p /rw/bind-dirs/etc/udev/rules.d/
cat << 'EOF' | sudo tee /rw/bind-dirs/etc/udev/rules.d/99-wireless-detect.rules > /dev/null
SUBSYSTEM=="net", ENV{DEVTYPE}=="wlan", ACTION=="move", RUN+="/rw/config/wifi-hotspot-add.sh '%E{INTERFACE}'"
SUBSYSTEM=="net", ENV{DEVTYPE}=="wlan", ACTION=="remove", RUN+="/rw/config/wifi-hotspot-remove.sh '%E{INTERFACE}'"
EOF
cat << 'EOF' | sudo tee /rw/config/wifi-hotspot-add.sh > /dev/null
#!/bin/sh
if [ "$(qubesdb-read /qubes-vm-persistence)" = "none" ]
then
    WIFI_INTERFACE=$1
    sed -i "s/^interface-name=.*/interface-name=$WIFI_INTERFACE/g" /rw/config/NM-system-connections/Hotspot.nmconnection
    nmcli conn reload
    if nft create chain ip qubes hotspot-input-$WIFI_INTERFACE >/dev/null 2>&1; then
        nft add rule ip qubes custom-input jump hotspot-input-$WIFI_INTERFACE
    fi
    nft add rule ip qubes hotspot-input-$WIFI_INTERFACE iifname $WIFI_INTERFACE meta l4proto udp udp dport 67 accept
    nft add chain ip qubes hotspot-dnat-dns-$WIFI_INTERFACE '{ type nat hook prerouting priority dstnat - 1; policy accept; }' >/dev/null 2>&1
    nft add rule ip qubes hotspot-dnat-dns-$WIFI_INTERFACE iifname $WIFI_INTERFACE ip daddr 10.42.0.1 udp dport 53 dnat to 10.139.1.1
    nft add rule ip qubes hotspot-dnat-dns-$WIFI_INTERFACE iifname $WIFI_INTERFACE ip daddr 10.42.0.1 tcp dport 53 dnat to 10.139.1.1
fi
EOF
sudo chmod +x /rw/config/wifi-hotspot-add.sh
cat << 'EOF' | sudo tee /rw/config/wifi-hotspot-remove.sh > /dev/null
#!/bin/sh
then
    WIFI_INTERFACE=$1
    nft flush chain ip qubes hotspot-input-$WIFI_INTERFACE >/dev/null 2>&1
    nft flush chain ip qubes hotspot-dnat-dns-$WIFI_INTERFACE >/dev/null 2>&1
fi
EOF
sudo chmod +x /rw/config/wifi-hotspot-remove.sh
sudo mkdir -p /rw/config/NM-system-connections
cat << EOF | sudo tee /rw/config/NM-system-connections/Hotspot.nmconnection > /dev/null
[connection]
id=Hotspot
type=wifi
autoconnect=true
interface-name=
[wifi]
mode=ap
ssid=$WIFI_SSID
[wifi-security]
group=ccmp;
key-mgmt=wpa-psk
pairwise=ccmp;
proto=rsn;
psk=$WIFI_PASSWORD
[ipv4]
method=shared
[ipv6]
addr-gen-mode=default
method=ignore
[proxy]
EOF
sudo chmod 600 /rw/config/NM-system-connections/Hotspot.nmconnection
sudo mkdir -p /rw/config/rc.local.d/
cat << 'EOF' | sudo tee /rw/config/rc.local.d/udev.rc > /dev/null
#!/bin/sh
udevadm trigger --subsystem-match=net --action=move --property-match=DEVTYPE=wlan
EOF
sudo chmod +x /rw/config/rc.local.d/udev.rc
I started from scratch, in the current state this does not support starting with a PCI Wi-Fi interface.
This did not help:
mkdir -p /rw/config/rc.local-early.d/
cat << 'EOF' | tee /rw/config/rc.local-early.d/udev.rc > /dev/null
#!/bin/sh
ln -s /rw/bind-dirs/etc/udev/rules.d/99-wireless-detect.rules /etc/udev/rules.d/99-wireless-detect.rules
udevadm control --reload-rules
udevadm trigger
EOF
I’m not sure what’s wrong here.
Yes, rc.local-early doesn’t work:
The PCI network interface is added before rc.local-early scripts are started.
So I’ve end up running /rw/config/wifi-hotspot-add.sh in rc.local:
I’ll try this, thanks :slight_smile:
Maybe in WIFI_INTERFACES you should add head -n 1 at the end in case there are multiple wifi devices (an usb in auto attach and a pci)
It’s getting only first interface with sed -n 3p. First 2 lines are headers and 3rd line is the first interface.
My PCI interface does not show up in /proc/net/wireless, so the script does not start the hotspot.
[root@sys-net-wifi-hotspot-dvm ~]# cat /proc/net/wireless
Inter-| sta-|   Quality        |   Discarded packets               | Missed | WE
 face | tus | link level noise |  nwid  crypt   frag  retry   misc | beacon | 22
iw dev output shows there is an interface
# iw dev
phy#0
	Unnamed/non-netdev interface
		wdev 0x2
		addr XXX
		type P2P-device
	Interface wls7f0
		ifindex 3
		wdev 0x1
		addr 0XXX
		type managed
		multicast TXQ:
			qsz-byt	qsz-pkt	flows	drops	marks	overlmt	hashcol	tx-bytes	tx-packets
			0	0	0	0	0	0	0	0		0
I’ll look int o it.
I wanted to avoid using iw so I wouldn’t need to install it in a minimal template, but if I won’t find another way to get the list of wireless interfaces, then I’ll change it to use iw.
I’m surprised iw is not pulled in by Network manager.
Maybe if you want to go minimal, there is hostapd I think that could be used instead of Network Manager.
I found a better way to do this - you can just trigger the udev manually for all wireless devices from rc.local like this:
#!/bin/sh
EOF
I’ll consider writing a minimal setup guide, since Network Manager is not really needed in this case.
Just to note, /proc/net/wireless seems to be deprecated:
2334171 – Missing /proc/net/wireless in 6.13.0-0-*
And if someone wants to check the device type without iw, then instead of checking /proc/net/wireless, it’s possible to get the list of all interfaces from /proc/net/dev and then for each of them check the DEVTYPE= value from /sys/class/net/$INTERFACE_NAME/uevent.
This reports wireless interfaces
awk -F ':' 'NR > 2 { print $1 }' /proc/net/dev | while read interface ; do if grep DEVTYPE=wlan /sys/class/net/$interface/uevent >/dev/null ; then echo $interface ; fi ; done
Or on multiple lines
do
    if grep "^DEVTYPE=wlan$" "/sys/class/net/${interface}/uevent" >/dev/null
    then
        echo "$interface"
    fi
done
