Why doesn’t Qubes use minimal templates for sys-net, sys-usb and sys-firewall? Also is there a problem with lowering the max memory for these VMs?
The only issue is space consideration. On ISO, we would need to add both standard and minimal templates because minimal template are not usable as is for daily desktop qubes (AppVM).
6 posts were split to a new topic: Trouble installing Mirage Firewall
Not having the minimal templates by default makes the system simpler and easier to understand for beginners. If you know what you are doing, minimal templates are recommended basically for everything.
