Trouble installing Mirage Firewall
Check out Mirage Firewall, I have tried to get it to work but failed, but you might have more success, let me know if you do cause I would like to know how to get it to work
I have experience installing Mirage both via source and pre-built. What issues are you encountering?
Also, given how long it has been since the last update (Jul. 2020), I’m a little bit uneasy about its current state. But maybe Microkernels don’t really need updates.
Whenever I would build from the source, i would be asked to get opam repositories, everytime I would it would just get an error and crash, the pre-built worked but for some reason it ended up being about a 10gb qube. The opam repositories would crash and say that opam repositories cant be found etc. I dont have the specific error code cause it was a while ago.
Would be good to know about Microkernels updates
Did you check the firewall configuration of the VM you’re using to build it? It sounds like you have a firewall or connectivity issue.
You should try following the instructions for the pre-built microkernel, line by line, since it should work perfectly. You might have generated a 10gb VM by mistyping something, so be extra cautious.
thanks ill try again, but I might wait to see what people say about Microkernels updates cause that could cause a security flaw
@deeplow can you spit this topic from this (i think i used deeplow too much)
I split the topic–thanks for reminding me
i don’t know that trust level 3 user can do that
edit: that outdated, now he leader
I haven’t been participating lately so I haven’t had the chance to use my mod functions.
wait, i can modify this thread ?!?
No, I meant that I haven’t had an opportunity to use my newly-granted moderator abilities since I haven’t been active lately.
Summary
https://github.com/mirage/mirage/releases speaking of the devil :>
mistook the general devel of mirage with qubes mirage fw package… sorri
