Where do I diagnose when AppVM apps silently fail
Both AppVM and it’s TemplateVM are silently failing when I try to start apps from the menu. The console button in Qubes Manager works. It’s the same behavior described on [qubes-users] Can't start apps from menu/app finder but can from dom0?
What I want to know is what do I do to debug it, which commands and files should I look for to figure out what is going on
If buttons in manager works, then in right mouse button menu there is console to run.
Try it.
Yes the console works like i already stated. That was not my question
Then run something from Q menu and check journal if it appears there.
Also check dom0 journal.
You could also run some app from console to se it’s outup.
Maybe just menu is corrupted.
Before jumping in, it would be useful if you could clarify some points:
Is this specific to one template? If so, what is that template, how did
you get it, and what changes (if any) have you made to it?
Are you able to start any applications from the Q Menu for the
template? (Try moving applications from the LHS to the RHS in the
Settings.)
In dom0, try to run these commands, replacing TEMPLATE with the name of
your template:
qvm-run -p TEMPLATE qubes-run-terminal
qvm-run -p TEMPLATE xterm
qvm-run -p TEMPLATE uxterm
Start the template and open a console - log in, and try to run xterm,
uxterm.
Report back.
Without --no-gui it hangs forever, but with --no-gui it says can’t open the display.
My current theory is that I am able to “sucessfully” break my template when I install proprietary NVIDIA drivers from their own debian repository (regardless if it’s the open source or non-free ones), detach the GPU from the template settings, convert the template back to PVH and run it at least once (like from the Qubes Update). Then every NVIDIA command start to fail.
Even if I use the console to login, it says nvidia-persistenced.service failed to load at boot because there’s nothing on /dev/nvidia
Even attaching the GPU back to the template and using proper HVM doesn’t magically fix anything
It happened again, the thing that makes the TemplateVM wreck is using the qubes updater to update it.
AppVM:
May 28 01:55:05 localhost kernel: nvidia: loading out-of-tree module taints kernel.
May 28 01:55:05 localhost kernel: nvidia: module license 'NVIDIA' taints kernel.
May 28 01:55:05 localhost kernel: Disabling lock debugging due to kernel taint
May 28 01:55:05 localhost kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
May 28 01:55:05 localhost kernel: nvidia: module license taints kernel.
May 28 01:55:05 work-vhs systemd[1]: Started nvidia-cdi-refresh.path - Trigger CDI refresh on NVIDIA driver or toolkit install / upgrade events.
░░ Subject: A start job for unit nvidia-cdi-refresh.path has finished successfully
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ A start job for unit nvidia-cdi-refresh.path has finished successfully.
░░ The job identifier is 126.
May 28 01:55:05 work-vhs systemd[1]: Starting nvidia-cdi-refresh.service - Refresh NVIDIA CDI specification file...
░░ Subject: A start job for unit nvidia-cdi-refresh.service has begun execution
░░ A start job for unit nvidia-cdi-refresh.service has begun execution.
░░ The job identifier is 118.
May 28 01:55:05 work-vhs systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
░░ Subject: A start job for unit nvidia-persistenced.service has begun execution
░░ A start job for unit nvidia-persistenced.service has begun execution.
░░ The job identifier is 154.
May 28 01:55:05 work-vhs systemd[1]: Started nvidia-powerd.service - nvidia-powerd service.
░░ Subject: A start job for unit nvidia-powerd.service has finished successfully
░░ A start job for unit nvidia-powerd.service has finished successfully.
░░ The job identifier is 143.
May 28 01:55:05 work-vhs nvidia-persistenced[787]: Started (787)
May 28 01:55:06 work-vhs nvidia-powerd[770]: nvidia-powerd version:2.0 (build 1)
May 28 01:55:06 work-vhs kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
May 28 01:55:06 work-vhs kernel: nvidia 0000:00:07.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
May 28 01:55:06 work-vhs kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  610.43.02  Tue May 19 11:18:18 UTC 2026
May 28 01:55:06 work-vhs kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  610.43.02  Tue May 19 11:09:25 UTC 2026
May 28 01:55:08 work-vhs kernel: [drm] [nvidia-drm] [GPU ID 0x00000007] Loading driver
May 28 01:55:08 work-vhs nvidia-powerd[770]: DBus Connection is established
May 28 01:55:08 work-vhs nvidia-powerd[770]: ERROR! SBIOS support not found for NVPCF GET_SUPPORTED function, exiting !!
May 28 01:55:08 work-vhs nvidia-powerd[770]: ERROR! Error in getting the NvPCF static configuration
May 28 01:55:08 work-vhs nvidia-powerd[770]: Quit successfully
May 28 01:55:08 work-vhs systemd[1]: nvidia-powerd.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit nvidia-powerd.service has successfully entered the 'dead' state.
May 28 01:55:08 work-vhs systemd[1]: nvidia-powerd.service: Consumed 1.813s CPU time, 85.2M memory peak.
░░ Subject: Resources consumed by unit runtime
░░ The unit nvidia-powerd.service completed and consumed the indicated resources.
May 28 01:55:08 work-vhs kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
May 28 01:55:08 work-vhs kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:00:07.0 on minor 0
May 28 01:55:08 work-vhs kernel: nvidia 0000:00:07.0: [drm] Cannot find any crtc or sizes
May 28 01:55:08 work-vhs systemd[1]: Started nvidia-persistenced.service - NVIDIA Persistence Daemon.
░░ Subject: A start job for unit nvidia-persistenced.service has finished successfully
░░ A start job for unit nvidia-persistenced.service has finished successfully.
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Using /usr/lib/x86_64-linux-gnu/libnvidia-sandboxutils.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Using /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Auto-detected mode as 'nvml'"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Using driver version 610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /dev/nvidia-modeset as /dev/nvidia-modeset"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /dev/nvidia-uvm-tools as /dev/nvidia-uvm-tools"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /dev/nvidia-uvm as /dev/nvidia-uvm"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /dev/nvidiactl as /dev/nvidiactl"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-egl-gbm.so.1.1.3 as /usr/lib/x86_64-linux-gnu/libnvidia-egl-gbm.so.1.1.3"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate libnvidia-egl-wayland.so.*.*: libnvidia-egl-wayland.so.*.*: not found\nlibnvidia-egl-wayland.so.*.*: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-egl-wayland2.so.1.0.1 as /usr/lib/x86_64-linux-gnu/libnvidia-egl-wayland2.so.1.0.1"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-allocator.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate libnvidia-vulkan-producer.so.610.43.02: libnvidia-vulkan-producer.so.610.43.02: not found\nlibnvidia-vulkan-producer.so.610.43.02: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/xorg/modules/drivers/nvidia_drv.so as /usr/lib/xorg/modules/drivers/nvidia_drv.so"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.610.43.02 as /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/glvnd/egl_vendor.d/10_nvidia.json as /usr/share/glvnd/egl_vendor.d/10_nvidia.json"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/egl/egl_external_platform.d/15_nvidia_gbm.json as /usr/share/egl/egl_external_platform.d/15_nvidia_gbm.json"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate egl/egl_external_platform.d/10_nvidia_wayland.json: egl/egl_external_platform.d/10_nvidia_wayland.json: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/egl/egl_external_platform.d/09_nvidia_wayland2.json as /usr/share/egl/egl_external_platform.d/09_nvidia_wayland2.json"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/nvidia/nvoptix.bin as /usr/share/nvidia/nvoptix.bin"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate X11/xorg.conf.d/10-nvidia.conf: X11/xorg.conf.d/10-nvidia.conf: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/X11/xorg.conf.d/nvidia-drm-outputclass.conf as /usr/share/X11/xorg.conf.d/nvidia-drm-outputclass.conf"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/vulkan/icd.d/nvidia_icd.json as /etc/vulkan/icd.d/nvidia_icd.json"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate vulkan/icd.d/nvidia_layers.json: vulkan/icd.d/nvidia_layers.json: not found\nvulkan/icd.d/nvidia_layers.json: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/share/vulkan/implicit_layer.d/nvidia_layers.json as /etc/vulkan/implicit_layer.d/nvidia_layers.json"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate vulkan/icd.d/nvidia_icd.x86_64.json: vulkan/icd.d/nvidia_icd.x86_64.json: not found\nvulkan/icd.d/nvidia_icd.x86_64.json: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libEGL_nvidia.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libEGL_nvidia.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libGLESv1_CM_nvidia.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libGLESv1_CM_nvidia.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libGLESv2_nvidia.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libGLESv2_nvidia.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libGLX_nvidia.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libGLX_nvidia.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libcuda.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libcuda.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libcudadebugger.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libcudadebugger.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvcuvid.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvcuvid.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-cfg.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-fbc.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-glcore.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-glvkspirv.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-glvkspirv.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-gpucomp.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-gpucomp.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-gtk3.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-gtk3.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-ml.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-ngx.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-nvvm.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-opencl.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-opticalflow.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-pkcs11-openssl3.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-pkcs11-openssl3.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-present.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-present.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-ptxjitcompiler.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-rtcore.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-rtcore.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-sandboxutils.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-sandboxutils.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-tileiras.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-tileiras.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-tls.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-tls.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-vksc-core.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-vksc-core.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvidia-wayland-client.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvidia-wayland-client.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/libnvoptix.so.610.43.02 as /usr/lib/x86_64-linux-gnu/libnvoptix.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_nvidia.so.610.43.02 as /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_nvidia.so.610.43.02"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /run/nvidia-persistenced/socket as /run/nvidia-persistenced/socket"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate /nvidia-fabricmanager/socket: /nvidia-fabricmanager/socket: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate /tmp/nvidia-mps: /tmp/nvidia-mps: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /lib/firmware/nvidia/610.43.02/gsp_ga10x.bin as /lib/firmware/nvidia/610.43.02/gsp_ga10x.bin"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /lib/firmware/nvidia/610.43.02/gsp_tu10x.bin as /lib/firmware/nvidia/610.43.02/gsp_tu10x.bin"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/bin/nvidia-smi as /usr/bin/nvidia-smi"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/bin/nvidia-debugdump as /usr/bin/nvidia-debugdump"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/bin/nvidia-persistenced as /usr/bin/nvidia-persistenced"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/bin/nvidia-cuda-mps-control as /usr/bin/nvidia-cuda-mps-control"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Selecting /usr/sbin/nvidia-cuda-mps-server as /usr/sbin/nvidia-cuda-mps-server"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate nvidia-imex: nvidia-imex: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=warning msg="Could not locate nvidia-imex-ctl: nvidia-imex-ctl: not found"
May 28 01:55:08 work-vhs nvidia-ctk[1236]: time="2026-05-28T01:55:08-03:00" level=info msg="Generated CDI spec with version 0.7.0"
May 28 01:55:08 work-vhs systemd[1]: nvidia-cdi-refresh.service: Deactivated successfully.
░░ The unit nvidia-cdi-refresh.service has successfully entered the 'dead' state.
May 28 01:55:08 work-vhs systemd[1]: Finished nvidia-cdi-refresh.service - Refresh NVIDIA CDI specification file.
░░ Subject: A start job for unit nvidia-cdi-refresh.service has finished successfully
░░ A start job for unit nvidia-cdi-refresh.service has finished successfully.
I didn’t clarify when I wrote this: the updater is not the problem, the problem is starting the TemplateVM.
I attempted cloning the AppVM today and the symptom is the same: the new AppVM had no display, no nvidia service could start and I couldn’t launch anything requiring being drawn.
I still need to test connecting an external monitor in the HDMI slot which is phisically connected to the nvidia display (I configured Qubes to use the internal gpu).
When I install and configure all the nvidia things in the TemplateVM, the next time I start the AppVM it works normally and survive restarts. The first time I boot the TemplateVM, it’s gonna put both the AppVM and the TemplateVM in that state without display.
Cloning the AppVM (and keeping the same TemplateVM and config) will result in the clone being in that state, but the original AppVM remains unnafected.
