When I run * xfce4-panel --restart I get the message:
Failed to restart the panel
GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown
The name is not activatable
What to do to restore the panel?
Please help.
Please help.
Without providing a context, I can only guess this question is about this issue.
If I’m right, then press Alt + F4 on the desktop, logout and login back. It should reappear, although there may be some glitches related to icons - instead of those colorful sanitized application icons, generic colorful qube icons may be appearing.
If I’m wrong, then please, shed some more light on the matter.
Have you tried this:
and this:
Thank you friends.
The panel appeared back on its own. ![]()
Right click anywhere on the desktop, then open a terminal.
Run this:
xfce-panel &
This starts the panel and detaches it from the terminal. Without the &, it will crash when you close the terminal.
