Not sure if the category is good, feel free to reassign where it belongs.
Maintaining OEM disk image, which is standard ISO installation + additional packages + updates + tweaks to provide up to date templates, is not an easy task.
Doing so comes with a lot of valid questions from end users on integrity, and providing proof/auditability is also not so easy, but interesting in itself and a filed of needed improvements.
I’m posting here to try to get an understanding of what touches what after deployment. From Qubes, I understand that sometimes, its done post-install by salt recipes, but I cannot really get my head over some of the changes, so here i’m posting the whole list of files changed after package installation to launch discussion.
dom0 (Fedora) currently relies on RPM databases. RPM provides some interesting tools.
Installed package list: rpm -qa
Integrity validation checks of package files: rpm -V package_name.
To see if a file was deployed by a package and which package: rpm -q --whatprovides /path/to/file
rpm -V will report a ‘5’ (..5...... ) when integrity digest of a certain file is different from what is expected in rpm database.
With the above commands, we can do some interesting checks.
The following takes the list of packages installed, verifies integrity against digest and keep the filenames that were reported to differ from digests.
It then take each of the individual files reported to be different from the digest (ownership, timestamp etc combined) and filter the output only to keep checksum differences (“5”, not optimal, I know, and then needs to be curated).
It then keeps in bad_check the package names that contained files that were modified (checksum different).
[user@dom0 ~]$ bad_check=$(rpm -qa | while read package; do sudo rpm -V $package; done | grep "5"| grep -o '/[^"]*'| while read file; do sudo rpm -q --whatprovides $file; done| uniq|sort)
The following package list contains packages that also contained files having a “5” in their filenames.
[user@dom0 ~]$ echo $bad_check
anaconda-core-32.24.5-5.fc32.x86_64 anaconda-gui-32.24.5-5.fc32.x86_64 dnf-data-4.6.0-1.fc32.noarch kernel-5.10.104-3.fc32.qubes.x86_64 kernel-5.10.109-1.fc32.qubes.x86_64 kernel-5.10.112-1.fc32.qubes.x86_64 kernel-qubes-vm-5.10.104-3.fc32.qubes.x86_64 kernel-qubes-vm-5.10.109-1.fc32.qubes.x86_64 kernel-qubes-vm-5.10.112-1.fc32.qubes.x86_64 libxfce4ui-4.14.1-4.fc32.x86_64 plymouth-0.9.4-14.20200325gite31c81f.fc32.x86_64 python3-blivet-3.2.1-2.fc32.noarch python3-kickstart-3.24-2.fc32.noarch python3-libvirt-6.6.0-5.fc32.x86_64 python3-qubesadmin-4.1.22-1.fc32.noarch qubes-audio-dom0-4.1.21-1.fc32.x86_64 qubes-core-dom0-4.1.26-1.fc32.noarch qubes-core-qrexec-4.1.18-1.fc32.x86_64 qubes-input-proxy-1.0.26-1.fc32.x86_64 qubes-mgmt-salt-admin-tools-4.1.13-1.fc32.noarch qubes-usb-proxy-dom0-1.1.1-1.fc32.noarch selinux-policy-minimum-3.14.5-46.fc32.noarch xen-runtime-4.14.4-4.fc32.x86_64 xfce4-panel-4.14.4-1.fc32.x86_64 xfce4-power-manager-1.6.6-1.fc32.x86_64 xfce4-session-4.14.2-1.fc32.x86_64 xfce4-settings-4.14.3-1.fc32.x86_64 xscreensaver-base-5.45-5.fc32.x86_64
The curated package list (without kernels, which contained filenames containing “5”):
sudo rpm -V anaconda-core-32.24.5-5.fc32.x86_64 anaconda-gui-32.24.5-5.fc32.x86_64 dnf-data-4.6.0-1.fc32.noarch libxfce4ui-4.14.1-4.fc32.x86_64 plymouth-0.9.4-14.20200325gite31c81f.fc32.x86_64 python3-blivet-3.2.1-2.fc32.noarch python3-kickstart-3.24-2.fc32.noarch python3-libvirt-6.6.0-5.fc32.x86_64 python3-qubesadmin-4.1.22-1.fc32.noarch qubes-audio-dom0-4.1.21-1.fc32.x86_64 qubes-core-dom0-4.1.26-1.fc32.noarch qubes-core-qrexec-4.1.18-1.fc32.x86_64 qubes-input-proxy-1.0.26-1.fc32.x86_64 qubes-mgmt-salt-admin-tools-4.1.13-1.fc32.noarch qubes-usb-proxy-dom0-1.1.1-1.fc32.noarch selinux-policy-minimum-3.14.5-46.fc32.noarch xen-runtime-4.14.4-4.fc32.x86_64 xfce4-panel-4.14.4-1.fc32.x86_64 xfce4-power-manager-1.6.6-1.fc32.x86_64 xfce4-session-4.14.2-1.fc32.x86_64 xfce4-settings-4.14.3-1.fc32.x86_64 xscreensaver-base-5.45-5.fc32.x86_64
provides the following output:
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/__pycache__/network.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/core/__pycache__/constants.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/core/__pycache__/users.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/core/__pycache__/util.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/core/configuration/__pycache__/storage.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/modules/common/structures/__pycache__/partitioning.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/modules/network/__pycache__/network.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/payload/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/payload/__pycache__/utils.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/storage/__pycache__/partspec.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/ui/lib/__pycache__/space.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/ui/gui/spokes/__pycache__/datetime_spoke.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/ui/gui/spokes/__pycache__/root_password.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/pyanaconda/ui/gui/spokes/__pycache__/user.cpython-38.pyc
S.5....T. c /etc/dnf/dnf.conf
S.5....T. c /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xml
S.5....T. c /etc/plymouth/plymouthd.conf
.M....... g /var/lib/plymouth/boot-duration
..5....T. /usr/lib/python3.8/site-packages/blivet/devices/__pycache__/lvm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/pykickstart/commands/__pycache__/partition.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/pykickstart/commands/__pycache__/repo.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/__pycache__/libvirt.cpython-38.pyc
..5....T. /usr/lib64/python3.8/site-packages/__pycache__/libvirtaio.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/app.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/base.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/config.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/devices.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/exc.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/features.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/firewall.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/label.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/log.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/spinner.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/storage.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/tags.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/__pycache__/utils.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/events/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/events/__pycache__/utils.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qubes_prefs.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_check.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_features.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_kill.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_ls.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_prefs.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_remove.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_run.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_shutdown.cpython-38.pyc
..5...GT. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_start.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/tools/__pycache__/qvm_template.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesadmin/vm/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesguidaemon/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesguidaemon/__pycache__/mic.cpython-38.pyc
S.5....T. c /etc/qubes/qmemman.conf
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/app.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/backup.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/config.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/devices.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/events.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/exc.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/features.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/firewall.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/log.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/__pycache__/utils.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/api/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/api/__pycache__/admin.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/api/__pycache__/internal.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/api/__pycache__/misc.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/admin.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/audio.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/backup_restore.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/block.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/core_features.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/gui.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/pci.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/r3compatibility.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/services.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/supported_features.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/ext/__pycache__/windows.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/qmemman/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/qmemman/__pycache__/algo.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/qmemman/__pycache__/client.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/storage/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/storage/__pycache__/file.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/storage/__pycache__/kernels.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/storage/__pycache__/lvm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/storage/__pycache__/reflink.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/tests/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/tests/__pycache__/devices.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/tests/__pycache__/never_awaited.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/tools/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/tools/__pycache__/qmemmand.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/tools/__pycache__/qubesd.cpython-38.pyc
..5...GT. /usr/lib/python3.8/site-packages/qubes/tools/__pycache__/qubesd_query.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/adminvm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/appvm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/dispvm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/qubesvm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/standalonevm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/__pycache__/templatevm.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/mix/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/mix/__pycache__/dvmtemplate.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubes/vm/mix/__pycache__/net.cpython-38.pyc
.M....... /var/run/qubes
..5....T. /usr/lib/python3.8/site-packages/qrexec/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/__pycache__/client.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/__pycache__/exc.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/__pycache__/server.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/__pycache__/utils.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/policy/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/policy/__pycache__/parser.cpython-38.pyc
.M5...GT. /usr/lib/python3.8/site-packages/qrexec/policy/__pycache__/parser_compat.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/policy/__pycache__/utils.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/tools/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/tools/__pycache__/qrexec_policy_daemon.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qrexec/tools/__pycache__/qrexec_policy_exec.cpython-38.pyc
S.5....T. c /etc/qubes-rpc/policy/qubes.InputMouse
..5....T. /usr/lib/python3.8/site-packages/qubessalt/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesusbproxy/__pycache__/__init__.cpython-38.pyc
..5....T. /usr/lib/python3.8/site-packages/qubesusbproxy/__pycache__/core3ext.cpython-38.pyc
..5....T. /var/lib/selinux/minimum/active/commit_num
S.5....T. /var/lib/selinux/minimum/active/file_contexts
S.5....T. /var/lib/selinux/minimum/active/homedir_template
S.5....T. /var/lib/selinux/minimum/active/policy.kern
.M....... g /var/lib/selinux/minimum/active/policy.linked
S.5....T. /var/lib/selinux/minimum/active/seusers
.M....... g /var/lib/selinux/minimum/active/seusers.linked
.......T. /var/lib/selinux/minimum/active/users_extra
.M....... g /var/lib/selinux/minimum/active/users_extra.linked
.M....G.. /etc/xen
S.5....T. c /etc/xen/xl.conf
.M....G.. /var/lib/xen
.M....G.. /var/log/xen
.M....G.. /var/log/xen/console
S.5....T. c /etc/xdg/xfce4/panel/default.xml
S.5....T. /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml
S.5....T. /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-session.xml
S.5....T. c /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xsettings.xml
S.5....T. c /etc/xscreensaver/XScreenSaver.ad.tail
Looking at files having ..5...... above gives a list of all files that were modified since package installation (which files are tracked by the package database). See man rpm and check “Verify” section for more information:
The following curated list without kernel packages:
sudo rpm -V anaconda-core-32.24.5-5.fc32.x86_64 anaconda-gui-32.24.5-5.fc32.x86_64 dnf-data-4.6.0-1.fc32.noarch libxfce4ui-4.14.1-4.fc32.x86_64 plymouth-0.9.4-14.20200325gite31c81f.fc32.x86_64 python3-blivet-3.2.1-2.fc32.noarch python3-kickstart-3.24-2.fc32.noarch python3-libvirt-6.6.0-5.fc32.x86_64 python3-qubesadmin-4.1.22-1.fc32.noarch qubes-audio-dom0-4.1.21-1.fc32.x86_64 qubes-core-dom0-4.1.26-1.fc32.noarch qubes-core-qrexec-4.1.18-1.fc32.x86_64 qubes-input-proxy-1.0.26-1.fc32.x86_64 qubes-mgmt-salt-admin-tools-4.1.13-1.fc32.noarch qubes-usb-proxy-dom0-1.1.1-1.fc32.noarch selinux-policy-minimum-3.14.5-46.fc32.noarch xen-runtime-4.14.4-4.fc32.x86_64 xfce4-panel-4.14.4-1.fc32.x86_64 xfce4-power-manager-1.6.6-1.fc32.x86_64 xfce4-session-4.14.2-1.fc32.x86_64 xfce4-settings-4.14.3-1.fc32.x86_64 xscreensaver-base-5.45-5.fc32.x86_64 | grep "5"
Outputs:
@marmarek @fepitre @Demi : do we have a way to validate from where those files were modified from and why? (same would apply for the fedora template).
