I’ve been having a look through the documentation around the usb qube and assorted vectors of attack. Device handling security | Qubes OS
I have a few questions.
Why are PS/2 devices recommend? What makes a PS/2 device secure and a USB device insecure? I get the impression USB devices in general have more vectors for exploitation.
The main emphasis seems to be on protecting against untrusted USB devices, which makes sense. Then the thought arises what makes a device trusted. I’d say a completely trusted device is one that has only ever been used on a given device from the factory (if a middle man has fiddled with it). Then there would be varying degrees of trust from there, i.e a USB which has been used on another device but formatted, or a mouse you’ve never lent to anyone but used on other devices etc…
Are there concerns around other USB device, say a DVD drive? which obviously isn’t an input device, like a keyboard or mouse.
I’m under the impression qubes is built in such a way that if someone gets your device, plugs a usb device in that usb device is completely blocked from interacting with the device unless you log in and “attach” the usb device to a qube, is that correct?
I guess at the end of the day, you are still plugging a USB device in and whatever that device is, I guess, could be malicious, if it’s just an adapter cable one would think that’s less likely to be malicious. If you’re going from USB to Ps/2 and back again that could potentially introduce two malicious devices in theory.
) should stand where I am, because that is not necessarily so (or were you meaning something else with the acquiescence
). Not to mention that some might take this as an endorsement of products which would not suit as I can not support these products which others might feel that I had endorsed. I periodically peruse the offerings of Asus, Gigabyte, Asrock, MSI, et al for motherboards so I have some experience here (building personal-use systems for something like 20+ years).
