Hi, from some days i have this problem with whonix qube. I think this problem was generated after the last update. I have also reinstalled the template, from dom0 and i have restarted the notebook but the problem persist.
Thank for the support.
Tommaso
I see in the whonix log files and found this error:
Nov 22 13:23:43 host vanguards[2340]: NOTICE[Tue Nov 22 13:23:43 2022]: Vanguards 0.3.1 connected to Tor 0.4.7.10 using stem 1.8.0
Nov 22 13:23:44 host vanguards[2340]: Traceback (most recent call last):
Nov 22 13:23:44 host vanguards[2340]: File “/usr/bin/vanguards”, line 11, in
Nov 22 13:23:44 host vanguards[2340]: load_entry_point(‘vanguards==0.3.1’, ‘console_scripts’, ‘vanguards’)()
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/main.py”, line 22, in main
Nov 22 13:23:44 host vanguards[2340]: run_main()
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/main.py”, line 61, in run_main
Nov 22 13:23:44 host vanguards[2340]: ret = control_loop(state)
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/main.py”, line 98, in control_loop
Nov 22 13:23:44 host vanguards[2340]: state.new_consensus_event(controller, None)
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/vanguards.py”, line 222, in new_consensus_event
Nov 22 13:23:44 host vanguards[2340]: self.consensus_update(routers, weights, exclude_nodes)
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/vanguards.py”, line 170, in consensus_update
Nov 22 13:23:44 host vanguards[2340]: weights, BwWeightedGenerator.POSITION_MIDDLE)
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/NodeSelection.py”, line 150, in init
Nov 22 13:23:44 host vanguards[2340]: NodeGenerator.init(self, sorted_r, rstr_list)
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/NodeSelection.py”, line 60, in init
Nov 22 13:23:44 host vanguards[2340]: self.rebuild(sorted_r)
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/NodeSelection.py”, line 142, in rebuild
Nov 22 13:23:44 host vanguards[2340]: self.node_weights.append(r.measured*self.flag_to_weight(r))
Nov 22 13:23:44 host vanguards[2340]: File “/usr/lib/pypy/dist-packages/vanguards/NodeSelection.py”, line 101, in flag_to_weight
Nov 22 13:23:44 host vanguards[2340]: return self.bw_weights[u’Wmm’]/self.WEIGHT_SCALE
Nov 22 13:23:44 host vanguards[2340]: KeyError: u’Wmm’
Hi, thank you for the support. I tryied to start qubes-dom0-update with action reinstall, but the problem was’n fixed. The solution that i found i to create other qube (sys-whonix-41) with network functionality and connect others vm to this. In this way work, but between the connected qube found also the template “fedora-32” and i received a warning for connecting a template to a qube. Now the notebook work fine. Do you think that this fix is fine or can be cause problems?
Hello Mila, thank you for your support.
The same situation happened yesterday also with the new qube/template. The pc had blocked (I have a few years old HP Elitebook) while it was or was going to sleep and I had to shut down the pc brutally by holding down the power button. This morning sys-whonix-41 (the new qube) behaved the same way. That process (Vanguards) kept restarting itself continuously. It had never happened to me with Qubes, until now (I’ve been using it for about a year) it’s always been very stable. From what I understand, there is some problem when the PC is suspended or restarted so that some persistent data (of qube sys-whonix) is damaged in that qube.
After redoing the original qube, it works fine. I made a backup and in case it gets damaged I’ll restore it. But this is new, I think (…), new updates.
Hi, i also think so.
But this situation beginning with latest upgrades.
Before never happen.
Other problem appened only one time, always whonix, when the notebook started, need to be killed (whonix) but after workwd fine.
But this situazione was solved.
Now when the notebook going in suspended mode the cpu stuck…
The problem is that the shutdown and start require a lot of time… and the suspension of the notebook is mandatori
Hi there.
I understand your needs, but keep in mind that qubes is more a bare metal hypervisor, then a standard linux distro, so try to avoid - at least until bug solved - the suspension mode…
If You think about it: each VMs have to be suspended to disk, before dom0 can hybernate its state…
Less or more, it’s a shutdown!
Cheers,
M.
for V in $(cat /tmp/vms)
do
if [ “x$V” = “x” ]
then
continue
fi
echo "Spengo $V"
qvm-shutdown --wait $V
if [ $? -ne 0 ]
then
echo "Fallimento nello shutdown di questa VM"
exit 1
fi
echo "Cambio rete per $V"
qvm-prefs $V netvm None
if [ $? -ne 0 ]
then
echo "Fallimento nella impostazione a None della rete per questa VM"
exit 2
fi
done
echo “Spengo Whonix”
qvm-shutdown --wait sys-whonix
if [ $? -ne 0 ]
then
echo “Impossibile fermare Whonix”
exit 3
fi
echo “Rimuovo Whonix”
qvm-remove --force sys-whonix
if [ $? -ne 0 ]
then
echo “Impossibile rimuovere Whonix”
exit 4
fi
echo “Reinstalo il nuovo template”
qubes-dom0-update --enablerepo=qubes-templates-community --action=reinstall qubes-template-whonix-gw-16
if [ $? -ne 0 ]
then
echo “Impossibile installare il nuovo template Whonix”
exit 4
fi
echo “Creo la nuova Whonix”
qvm-create
–class=AppVM
–template=whonix-gw-16
–label=black
–property autostart=True
–property provides_network=True
sys-whonix
if [ $? -ne 0 ]
then
echo “Impossibile creare Whonix”
exit 5
fi
echo “Avvio la nuova Whonix”
qvm-start-daemon sys-whonix
if [ $? -ne 0 ]
then
echo “Impossibile avvia Whonix”
exit 6
fi
do
echo “Reimposto la rete Whonix per $V”
qvm-prefs $V netvm sys-whonix
if [ $? -ne 0 ]
then
echo “Impossibile impostare a Whonix la rete per la VM $V”
exit 7
fi
done
Sorry… yes.
While waiting for the bug to be resolved, I added a widget in the upper right corner, next to the clock, which shuts down whonix and the vm behind it (the problem is that behind Whonix I have a mini-infrastructure, with vpn etc and every time it takes a long time to start). This way the suspension doesn’t hang and I don’t have to restart the notebook from scratch.
