Anybody doing it? I am talking about using guix for installing packages on a debian-12, whonix-17, etc qube (appVM). The discussion on the forum so far seems to have been around using guix inside standaloneVMs.
As far as I understand from watching a few guix package manager videos on youtube, guix creates a directory under /gnu/store/. Since this is outside the /home/user/ directory, I am assuming that this is a problem for using guix as a package manager inside a qube.
Long story short, since it seems like guix package manager writes to /gnu/store/ directory, in normal qubes, the changes in there don’t survive a reboot. But, turning that dir in a bind-dir seems to make it survive a reboot, and enable using guix inside a qube.
You might also want to look into the guix pack command. The --relocatable flag will let you install Guix packages to your home directory (though I’m not sure if substitutes will work with this). -f squashfs will save the packages to a disk image and you should be able to automatically mount it in your /rw/config/rc.local (in theory, I haven’t tested this).
necroing this thread. I am looking specifically for using guix package manager that I install from debian-12 apt repos for the purpose of deterministically compiling monero binaries from the monero source code.
Afaik, guix uses /gnu/store directory to store packages, etc., which is not feasible to use in an appVM (aka, qube). I don’t want to use guix package manager in my debian templates either (I don’t want the changes done by guix to propagate to other qubes, nor do I want to add one more template to my templates).
Anybody have any ideas? With flatpak, for example, I can use flatpak --user install to install the packages to my /home/user/ directory, and confine its efects to a single qube of mine. I wish guix package manager also allowed something similar.
FWIW, some time ago I played around Guix package management inside a Fedora template and this is my current setup yet. I have Guix (daemon) installed in TemplateVM and its packages persisted in AppVMs via bind-dirs. I wrote the steps in my blog for reference Guix/Nix in a Fedora Minimal TemplateVM
However I don’t recommend since bind-dirs in whole Guix store puts all the persistence to AppVMs, making disk usage get very high across multiple AppVMs, and it also loses the advantages of TemplateVMs (reuse the setup without letting AppVMs mutate the packages). I’m still playing around to realize the ideal setup for Guix in QubesOS, but I think its packages should persist in TemplateVM.
I played only with Guix foreign, so the data is stored in the system it was installed. In my case, installed in a Fedora TemplateVM.
Because I wanted to install packages from AppVM, I used bind-dirs to persist Guix dirs.
I think an better scenario for Guix in Qubes would replicate Qubes intended flow:
TemplateVM holds the binaries. In Qubes, intended to be installed using distro’s package manager (dnf, apt, etc).
AppVM uses the binaries without persistence, persisting only user data/config.
Guix can replace dnf and apt in TemplateVM with ordinary guix install calls, but since Guix is intended to build declarative systems, and I think some of Guix features/design won’t apply.
I’m interested in using Guix declarative definition to declare workspaces to can be used in non-Qubes OSes as well (ie, GuixOS), but still figuring out. My next try would be having Guix foreign in a TemplateVM without bind-dirs in AppVM, and apply the system setup from the AppVM. If this work well the next step can be the integration with Qubes Updater.
persist Guix dirs.
Yes, that’s how I am modeling in my mind, how I would use Guix package
manager on a debian qube, as well.
Does this mean, whatever Guix packages you install on the AppVM get
persistence on the TemplateVM, and therefore will be reflected on the
other AppVMs that share this same TemplateVM?
intended flow:
data/config.
Yes, that would be better. Can you instruct Guix package manager to use
someplace in /home/user/ instead of the /gnu/store/? That way, we
could get AppVM-based persistence, without
reflecting/mirroring/persisting back the AppVM’s changes to the
TemplateVM.
[… 7 lines elided]
Hello, sorry the delay (was migrating to 4.3.1 :))
No, the approach I don’t recommend using bind-dirs which I used in my previous setup was: Each AppVM has its own /gnu/store, no contamination. bind-dirs basically configures a path that AppVM can persist, but it’s not shared to anything else.
This is not optimal because one of the main goals of TemplateVMs is provide the binaries for the AppVMs based on it.
The bind-dirs setup works exactly this way (however store remains in default path). The link I provided instructs this approach, you’ll have a /gnu/store for each AppVM, however the AppVM disk usage will be high (all binaries from Guix will be stored on it) and TemplateVM wouldn’t provide the Guix packages, as now AppVM would have its own store. This is what bind-dirs does.
By design QubesOS doesn’t lets AppVM contaminate the TemplateVM, so it’s not possible for a change in AppVM reflect to another AppVMs.
In my recent Qubes upgrade I did a migration from scratch and this setup is way better. Now I have:
TemplateVM providing Guix and its packages.
I can run guix install or guix shell at TemplateVM to fetch the package.
/gnu/store is ephemeral for AppVMs (installed packages on it is lost at reboot)
This is good to me, now I can experiment packages in AppVM and in reboot the store is cleaned back to TemplateVM state. If the changes are good, I do it in TemplateVM.
It means that all packages from TemplateVM are inherited by all AppVMs based on it, which is fine. If I want a AppVM having a different set of packages (ie, have no browser ever fetched), I can setup a different TemplateVM. I think this aligns well with Qubes original design.
My next steps will be migrate my chezmoi setup to Guix home for AppVM management. This would take me some time and chezmoi is working great, but my final goal is have a full IaC concentrating in Guix so I can replicate in a GuixOS and Qubes management via SaltStack. Still learning though.
This sounds good. Thanks for correcting my misunderstanding aobut
bind-dirs.
I think I would be OK with each AppVM having its own, isolated,
/gnu/store/ directory. Since with Guix, all one hsa to do is copy the
guix config file to replicate his package installations, this isolated
/gnu/store/ situation shouldn’t be a problem. I can copy the guix
config to each appvm and install my package there (yes this replicates
package installs, but, that is something I am willing to do, at least
for now, when thinking about the guix system on qubes os).
Yes, sounds good to me.
the package.
lost at reboot)
This workflow sounds good and attractive as well. How’s templateVM able
to connect to guix package repositories? I thought the templateVM is
only able to connect to debian/fedora package repositories and otherwise
is offline.
Yes, this way you can re-fetch the packages in a AppVM and it will persist, the problem would be disk usage (Guix store duplicated on each AppVM) and TemplateVM not being used. Another option for this approach is configuring Guix to save store in user’s home as @skyvine mentioned. AppVMs persists home by default so no Qubes-level setup needed for this.
If the need is building a package locally and reusing it in many AppVMs I’d not set /gnu/store as persistent to avoid building it from scratch in every AppVM. However if only one AppVM is using the built package and you want to have the Guix store persisted in the AppVM, the two raised options are applicable:
/gnu/store in TemplateVM with bind-dirs
/gnu/store in AppVM’s home
Second option I didn’t tried, I assume it would be a rootless daemon setup (which seems to be supported now Build daemon drops its privileges).
Yea, I think it’s a good idea to give a try. Would bring a clearer direction, it did to me
There’s a proxy in Templates routing to the UpdateVM and by default only the package managers goes through proxy.
You can configure for other apps use it as well, this direction is a step away from Qubes design, the network is disabled in TemplateVM because it should be trusty as possible as AppVMs inherit it, but you can either:
Use HTTP_PROXY/HTTPS_PROXY/ALL_PROXY envs in the daemon service setting proxy to http://localhost:8082 (doc). Likely added in /etc/systemd/system/guix-daemon.service.
Connect TemplateVM to a qube providing network. I was lazy and did this way but this is not recommended.
each AppVM)
Oh, that’s a legit problem, thanks for raising this to my attention.
[… 19 lines elided]
design
but you can: - Use HTTP_PROXY/HTTPS_PROXY/ALL_PROXY envs in the
daemon env to set proxy to http://localhost:8082
(doc). Likely
add in your /etc/systemd/system/guix-daemon.service. - Connect
but this is not
recommended.
