Hi there i have installed qubes. But wifi doesnt work. On my first install i have not seperated usb and net qubes and wifi card was giving a lot of issues. like freezing sys-net, kernel driver fails and i need to plug out and in again etc…
so i decided to reinstall and seperate it. now when i share the device to sys-net either it crashes or doesnt connect to any wifi. it shows them but doesnt conmect. checked journalctl and the disconnect reason is literally None. i tried to install 8822bu driver but when i first did it it freezed the whole system and i couldnt even login after i installed the driver on the fedora template.
i really dont have any other option to connect to a network
Did you check if your WiFi adapter works in general Linux systems? Need to know if it’s an issue specific to Qubes OS or to Linux in general.
You can try to boot from some Linux Live USB (e.g. latest Fedora Live) and check if your WiFi adapter will work there.
Did you try to use newer kernel version for your sys-net qube?
You can install latest kernel version from current-testing repository for you qubes in dom0:
its already latest kernel. thanks for the help. as i said this is taking so much of my time with no way to debug or fix so i will sadly stop using qubes from now. tried every possible scenario and fix but still the same
