USB of 4.2RC3 does not start on Librem 13 V2
Should I say, it dumps out to console.
Formatted on USB with 2.0, FAT 32, with Balena Etcher on Windows 10.
I guess I can get a Qubes 4.2 from the end of July 2023. Then let it Update.
I thought someone would recognize the symptom.
If you installed on multiple SSDs that is a symptom. I can fill this forum with bugs from ipv6 to trying secure boot (Signature not found in secure database ‘db’). Take a deep breath and watch Flashdance 7:47. It helps me deal with this type of things…
My current solution was to use the Qubes 4.2 from August 8, 2023, which the computer recognizes and installs. Then I ran update. Although, still. I ran an up of dom0. Downloaded a bunch, went off to think about it. Seemed to install something. Then said it did not install anything. Update would not find anything else for dom0 to install. ??? Fedora 38 did an update. Whonix would not start Tor, or update.
Updating is a bit of difficulty for me. I have to go to the public library for internet connection, as the only internet I have at home is from my phone’s hotspot. So I have not tried everything. I can install the Qubes 4.2RC3 on some other computers. Guessing it has something to do with the USB key being written to GUID instead of MBR. or is it, UEFI instead of MBR.
I can’t afford to pay for Flash Dance. Good age for Jennifer Beals.
