Fresh install with a USB mouse and keyboard ( seperate dongles) neither work
New to qubes andout of my element,
it showed my mouse on the devices list during install so not sure where to go from here
Do you have other keyboard/mouse/touchpad that works (PS/2, wired USB or something else)?
Yes the touchpad on the laptop works and the keyboard
The USB mouse worked during install
Did you create sys-usb during Initial Setup?
Do you have sys-usb qube?
Is sys-usb qube running?
Do you see this window appearing if you disconnect/reconnect both your keyboard and mouse USB dongles?
In qubes manager I don’t see sys-usb running
Try to manually start sys-usb (from Qubes manager, right click, start)
Click on a Qubes Domains widget in system tray (blue cube) and check if the sys-usb is listed there.
If it’s not listed there then try to start it from the Qubes Application Menu: Q → SERVICE → sys-usb → Start qube.
Maybe there is some problem with PCI devices attached to sys-net.
You need to check the logs in dom0 to see why it failed to start.
Check these files in dom0:
/var/log/libvirt/libxl/libxl-driver.log
/var/log/xen/console/guest-sys-net.log
/var/log/xen/console/guest-sys-net-dm.log
And you can also run this command in dom0 terminal:
journalctl -f -n0
Keep it running and try to start sys-net, and after sys-net fails to start check the output of this command to see if there are any errors related to it.
You can stop the command using Ctrl+C.
Press on the Q icon in the top left corner.
Oh, I didn’t notice that you configured sys-net for both USB and networking:
That’s why you don’t have a separate sys-usb qube.
You can open dom0 terminal using Qubes Application Menu:
Q → Gear icon → Other → Xfce terminal
These two logs looks ok, need to check other logs as well.
Also check this log file:
/var/log/xen/console/hypervisor.log
Is this file empty? I’m not sure from looking at your photo.
You can print the content of the file using this command:
sudo cat /var/log/xen/console/guest-sys-net-dm.log
You can edit your post to add more information in it.
