What’s your hardware?
Do you have 4 GB RAM?
Minimum
CPU: 64-bit Intel or AMD processor (also known as x86_64, x64, and AMD64)
Memory: 6 GB RAM
Storage: 32 GB free space
System requirements | Qubes OS
poah
November 11, 2024, 2:27am
22
My 2nd ram slot appears to have taken a crap
Only 4 is registering
Child this cause all these programs to not start?
Yes, dom0 is using 4 GB of memory by default and if you have only 4 GB or RAM then there is no memory available to start the qubes.
poah
November 21, 2024, 6:01pm
24
I got 8 gb of ram installed, did a fresh install and same issue
This is the error msg I get after installing
These logs are empty as well
arkfox
November 21, 2024, 10:22pm
25
Make sure you have virtualization enabled in your BIOS.
arkfox
November 23, 2024, 2:44am
27
I don’t remember the name of the settings but on some motherboards there are more than one setting related to virtualization that need to be enabled. I have seen errors like that when those settings are not enabled.
poah
November 23, 2024, 2:58am
28
I’ll comb through the bios and report back thanks
arkfox
November 23, 2024, 5:25am
29
Think it may be called IOMMU.
poah
November 24, 2024, 12:25am
30
arkfox:
IOMMU
Apparently dells IOMMU is vt for direct io, which was enabled, as well as virtualization.
But trusted execution to be enabled needs the other two to be enabled also
But it’s grayed out. So maybe this is some issue with virtualization?
I defaulted the bios out but it’s still grayed out
Tpm is turned off
