I got a new keyboard which is advertised as ‘plug and play’ with Linux. When plugged in via USB, this is what I get in dom0 /var/log/Xorg.0.log , which shows that it is being tagged as a mouse. Not sure what a next step would be… any help very appreciated!
I use a sys-usb Qube…
[ 184.888] (II) config/udev: Adding input device sys-usb: Kinesis Freestyle Edge RGB Keyboard (/dev/input/mouse3)
[ 184.888] (II) No input driver specified, ignoring this device.
[ 184.888] (II) This device may have been added with another device file.
[ 184.901] (II) config/udev: Adding input device sys-usb: Kinesis Freestyle Edge RGB Keyboard (/dev/input/event17)
[ 184.901] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: Applying InputClass "evdev pointer catchall"
[ 184.901] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: Applying InputClass "libinput pointer catchall"
[ 184.901] (II) Using input driver 'libinput' for 'sys-usb: Kinesis Freestyle Edge RGB Keyboard'
[ 184.901] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: always reports core events
[ 184.901] (**) Option "Device" "/dev/input/event17"
[ 184.901] (**) Option "_source" "server/udev"
[ 184.902] (II) input device 'sys-usb: Kinesis Freestyle Edge RGB Keyboard', /dev/input/event17 is tagged by udev as: Mouse
[ 184.902] (II) input device 'sys-usb: Kinesis Freestyle Edge RGB Keyboard', /dev/input/event17 is a pointer caps
[ 184.916] (**) Option "config_info" "udev:/sys/devices/virtual/input/input18/event17"
[ 184.916] (II) XINPUT: Adding extended input device "sys-usb: Kinesis Freestyle Edge RGB Keyboard" (type: MOUSE, id 14)
[ 184.919] (**) Option "AccelerationScheme" "none"
[ 184.922] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: (accel) selected scheme none/0
[ 184.922] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: (accel) acceleration factor: 2.000
[ 184.922] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: (accel) acceleration threshold: 4
[ 184.924] (II) input device 'sys-usb: Kinesis Freestyle Edge RGB Keyboard', /dev/input/event17 is tagged by udev as: Mouse
[ 184.924] (II) input device 'sys-usb: Kinesis Freestyle Edge RGB Keyboard', /dev/input/event17 is a pointer caps
[ 973.898] (II) config/udev: removing device sys-usb: Kinesis Freestyle Edge RGB Keyboard
[ 973.903] (II) UnloadModule: "libinput"
[ 982.176] (II) config/udev: Adding input device sys-usb: Kinesis Freestyle Edge RGB Keyboard (/dev/input/mouse3)
[ 982.176] (II) No input driver specified, ignoring this device.
[ 982.176] (II) This device may have been added with another device file.
[ 982.190] (II) config/udev: Adding input device sys-usb: Kinesis Freestyle Edge RGB Keyboard (/dev/input/event17)
[ 982.190] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: Applying InputClass "evdev pointer catchall"
[ 982.190] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: Applying InputClass "libinput pointer catchall"
[ 982.190] (II) Using input driver 'libinput' for 'sys-usb: Kinesis Freestyle Edge RGB Keyboard'
[ 982.190] (**) sys-usb: Kinesis Freestyle Edge RGB Keyboard: always reports core events
Snazzy, just what all the cool kids are asking their parents for, this week. I notice a few things on the manufacturer’s webpage which could possibly explain a great deal though.
Convenient Onboard Programming
100% plug-and-play, 4MB onboard memory, and 9 Profiles
On-the-fly macros with playback up to 250 actions per second!
Remap any key in either layer with the touch of a button
One-touch Game Mode, NKRO, Profile Switching, and more
Smartset App (Windows & Mac)
No special drivers required, just download to your desktop
Customize RGB Lighting Effects (Color, Speed, Direction, Zone)
Macro Delays, Tap-and-Hold Actions, Mouse Clicks, and more
Everything you need, without the bloatware!
hi! So i noticed that the keyboard works fine in sys-usb, just no other qube. @alzer89 mentioned connecting directly to dom0 for troubleshooting - how would I go about doing that?
Following that stackexchange link, in sys-usb I made /etc/X11/xorg.conf.d/00-keyboard.conf with the contents:
Unfortunately this is my first USB keyboard so I can’t say
sys-usb is based on fedora-33 - it was based on Fedora when created during the original install, and I haven’t managed to go through the process of eliminating Fedora yet qubes-input-proxy-sender is installed in the Fedora-33 template (1.0.25-1).
I should add that the keyboard works in sys-usb even without the /etc/X11/xorg.conf.d/00-keyboard.conf file I had added as described above, so I removed it. In the equivalent file in dom0 I appended (to no effect as of yet):
In sys-usb, I have the following:
/dev/input/by-id/usb-Kinesis_Freestyle_Edge_RGB_Keyboard_264575131106-event-if02
/dev/input/by-id/usb-Kinesis_Freestyle_Edge_RGB_Keyboard_264575131106-event-mouse
/dev/input/by-id/usb-Kinesis_Freestyle_Edge_RGB_Keyboard_264575131106-if01-event-kbd
/dev/input/by-id/usb-Kinesis_Freestyle_Edge_RGB_Keyboard_264575131106-mouse
It is the last entry that symlinks to …/mouse3, which shows up in the logs from dom0 in the original post.
My theory is that since the keyboard works in sys-usb, we should look at the input sender (which makes the keyboard available to dom0 and hence the entire system)
Your answer to 3 is not the file I’ve asked for. You forgot the /policy/ part of the path. Please re-check if you are on R4.0
If you are on R4.1 please locate the policy file (all in one) and check for the InputKeyboard policy.
