USB Device (Auto attach to Qube)
Hello,
Is there a way to attach a particular USB device (by Vendor ID/Product ID) to a Qube automatically on connect? I have a sys-usb to manage USB devices.
The USB device I am using frequently becomes disconnected (and reconnected) during use and it only needs to be connected to one particular Qube.
Thanks,
N
I don’t know of an easy solution to this.
Using the qvm-usb tool you can attach a connected device to another VM persistently, but the device id is unreliable and may change if you reconnect devices in a different order.
Since sys-usb cannot escape virtualization and connect a device to another VM, what you could do is write udev rules in sys-usb to trigger an RPC call to dom0 which would attach the device to another VM (after a confirmation popup, if you want).
You might try enabling no-strict-reset on your USB controller attached to sys-usb
This weekend was a long weekend and I had some time to try out the idea that I had mentioned in in a comment above. The whole process was relatively straightforward and there were very few surprises :slightly_smiling_face:
Here is a blog post I wrote documenting my experience: USB auto-attach in Qubes » Saswat Padhi
Comments / suggestion are most welcome.
Cheers.
Very nice write up padhi.
Thank you,
N
I recently did the same sort of thing as padhi, except my goal was for a prompt to open up in dom0 asking which qube a USB device should be attached to upon being plugged in. Unfortunately, when Qubes wakes up from standby, the sys-usb qube acts as if all USB devices were re-plugged in. I couldn’t figure out a way to differentiate that event versus the device actually being plugged in, so I ended up getting rid of it.
Here’s some details, if it helps anyone.
I was using the stdin/stdout way of communicating, with the following udev rule for not just block devices :
ACTION=="add", SUBSYSTEM=="usb", DRIVER=="usb", RUN+="/usr/lib/qubes/qrexec-client-vm dom0 custom.AskAboutAttachingUsbDevice /home/user/send-usb-device.sh $devpath"
Contents of /home/user/send-usb-device.sh:
#!/bin/bash
# used by /etc/udev/rules.d/90-qubes-usb-device-plugged-in.rules
echo $1 | rev | cut -d'/' -f 1 | rev
Script that eventually gets executed on dom0 (needs some hardening if using stdin/stdout):
#!/bin/bash
read usb_device
qubes=$(qvm-ls --raw-data --fields=NAME,CLASS | egrep "AppVM|DispVM|StandaloneVM" | egrep -v "sys|mgmt|dvm" | cut -f 1 -d "|" | sort);
qube=$(zenity --display=:0.0 --list --radiolist --text="Select a Qube to attach the USB device ${usb_device} to:" --column="Selection" $qubes --column="Qube" $qubes --width=250 --height=350)
if [ -n "$qube" ]; then
        qvm-device usb attach $qube sys-usb:$usb_device
fi
Have you tried parsing the logs (like syslog) seeking for that event ?
Yes. I could find the event. But there is no way of differentiating it from the same events that fire when sys-usb resumes from standby.
Sorry, bad wording, I didn’t mean the USB attach event itself, I meant its time relation with the wake-up-from-standby event.
  • if an USB attach occurs “close” to a wake-up event, it’s a resume from standby.
  • if an USB attach is more than (let’s say) 1 minute after the last wake up, it’s a normal plug event
That’s why I wrote “parsing”, you would have to parse date/time of events, and determine what is a reasonable timing between them.
