Hey everyone! As the title would suggest it isn’t working as intended. The Wacom touchscreen/stylus work perfectly when the USB controller isn’t attached to sys-usb and running but immediately stops when it is.
I should note that sys-usb fails with an error upon starting and immediately shuts down even after I applied the needed strict-no-reset=true flag to my single usb controller. Also, My USB qube is disposable, based on Fedora 41 xfce, and this PC passes the Qubes OS Security report.
I’ve tried to refrain from asking questions as I know from experience how frustrating it can be to deal with some of them, but I’m at the end of the rope here and would really like to utilize Qubes OS effectively and (ironically enough) utilize the USB device isolation feature especially
I’d greatly appreciate any help and would like to thank you in advance for your time. ![]()
What I’ve tried:
- Updating to the latest dom0 and templates (on R4.2.4).
- Reinstalling (I verified the ISO was properly signed and had the correct hash).
- Reinstalling with the current time set in the BIOS as suggested in another thread.
- Reinstalling like above, without sys-usb, making it following the docs, and adding no strict-reset=true or permissive=true individually and together.
qvm-pci attach --persistant --option no-strict-reset=true permissive=true sys-usb dom0:00_14.0 - Stopping all VM launches on startup and starting them manually in all orders as suggested on Reddit.
- Running the sys-usb qube without the USB controller attached (it works).
- Running sys-usb under Debian 12 xfce.
- Enabling Touchscreen/Tablet and Mouse in the Qubes OS Global Config menu.
- Everything possible in the xfce 'Mouse and Touchpad" menu.
- Disabling USB 3.0 in the BIOS as suggested here.
plz no, I have a need for speed! - Various small things from the Internet and this forum that I can’t remember.
Here’s some relevant information I’ve gathered that might be useful to you guys:
The error upon starting sys-usb:
Start failed: internal error: libxenlight failed to create new domain 'sys-usb', see /var/log/libvirt/libxl/libxl-driver.log for details
libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn't support reset from sysfs for PCI device 0000:00:14.0
libxl: libxl_pci.c:1492:pci_add_dm_done: Domain 6:xc_physdev_map_pirq irq=-2147483648 (error=-1): Invalid argument
libxl: libxl_pci.c:1864:device_pci_add_done: Domain 7:libxl__device_pci_add failed for PCI device 0:0:14.0 (rc -3)
libxl: libxl_dm.c:2523:spawn_stub_launch_dm: Domain 6:error connecting pci devices
libxl: libxl_dm.c:2808:stubdom_pvqemu_cb: Domain 6:error connecting nics devices: Invalid argument
libxl: libxl_create.c:1975:domcreate_devmodel_started: Domain 6:device model did not start: -3
libxl: libxl_aoutils.c:638:libxl__kill_xs_path: unable to find QMP Proxy pid in /local/domain/7/image/qmp-proxy-pid
/var/log/xen/console/guest-sys-usb.log and guest-sys-usb.log-dm (Logs option from Qubes Manager)
Empty | Doesn't exist
lspci -k
DEVID DESCRIPTION USED BY
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03) sys-usb (no-strict-reset=true)
Subsystem: x
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
Subsystem: x
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
Subsystem: x
Kernel driver in use: pcieport
00:1c.3 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3)
Subsystem: x
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
Subsystem: x
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
sudo libinput --list-devices
Device: Wacom MultiTouch Sensor Finger
Kernel: /dev/input/event4
Group: 6
Seat: seat0, default
Capabilities: touch
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Middle emulation: n/a
Calibration: identity matrix
Scroll methods: none
Click methods: none
Disable-w-typing: n/a
Disable-w-trackpointing: n/a
Accel profiles: n/a
Rotation: n/a
Device: Wacom MultiTouch Sensor Pen
Kernel: /dev/input/event5
Group: 6
Capabilities: tablet
Tap-to-click: n/a
Tap-and-drag: n/a
Tap drag lock: n/a
Left-handed: n/a
Nat.scrolling: n/a
Click methods: none
Accel profiles: none
Rotation: n/a
lsusb
Bus 002 Device 001: ID x:x Linux Foundation 3.0 root hub
Bus 001 Device 003: ID x:x Cypress Semiconductor Corp. Unprogrammed hub
Bus 001 Device 002: ID x:x Wacom Co., Ltd MultiTouch Sensor
Bus 001 Device 001: ID x:x Linux Foundation 2.0 root hub
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/11p, 480M
|__ Port 4: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
journalctl -b | grep -i touch
dom0 kernel: usb 1-4: Product: MultiTouch Sensor
dom0 kernel: input: Wacom Co.,Ltd. MultiTouch Sensor Touchscreen as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:056A:5019.0001/input/input11
dom0 kernel: hid-generic 0003:056A:5019.0001: input,hiddev96,hidraw0: USB HID v1.11 Device [Wacom Co.,Ltd. MultiTouch Sensor ] on usb-0000:00:14.0-4/input0
dom0 kernel: input: Wacom Co.,Ltd. MultiTouch Sensor Stylus as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:056A:5019.0002/input/input13
dom0 kernel: hid-generic 0003:056A:5019.0002: input,hiddev97,hidraw1: USB HID v1.11 Device [Wacom Co.,Ltd. MultiTouch Sensor ] on usb-0000:00:14.0-4/input1
dom0 kernel: wacom 0003:056A:5019.0001: hidraw0: USB HID v1.11 Device [Wacom Co.,Ltd. MultiTouch Sensor ] on usb-0000:00:14.0-4/input0
dom0 kernel: input: Wacom MultiTouch Sensor Finger as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:056A:5019.0001/input/input17
dom0 kernel: wacom 0003:056A:5019.0002: hidraw1: USB HID v1.11 Device [Wacom Co.,Ltd. MultiTouch Sensor ] on usb-0000:00:14.0-4/input1
dom0 kernel: input: Wacom MultiTouch Sensor Pen as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.1/0003:056A:5019.0002/input/input19
dom0 systemd[1]: Started qubes-input-sender-tablet@event4.service - Qubes input proxy sender (tablet/touchscreen).
dom0 systemd[1]: Started qubes-input-sender-tablet@event5.service - Qubes input proxy sender (tablet/touchscreen).
dom0 systemd[1]: Started qubes-input-sender-tablet@event3.service - Qubes input proxy sender (tablet/touchscreen).
xl dmesg
Might be of interest (for your convenience):
(XEN) [VT-D] RMRR [cd800000,cfffffff] not in reserved memory; need "iommu_inclusive_mapping=1"?
(XEN) PCI: Not using MCFG for segment 0000 bus 00-3f
(XEN) Not enabling x2APIC (upon firmware request)
(XEN) Built-in command line: ept=exec-sp spec-ctrl=unpriv-mmio
Xen 4.17.5
(XEN) Xen version 4.17.5 (mockbuild@[unknown]) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1)) debug=n Sun Feb 16 03:41:49 GMT 2025
(XEN) Latest ChangeSet:
(XEN) Bootloader: GRUB 2.06
(XEN) Command line: placeholder console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096 no-real-mode edd=off
(XEN) Xen image load base address: 0xc1600000
(XEN) Video information:
(XEN) VGA is graphics mode x, x bpp
(XEN) Disc information:
(XEN) Found 0 MBR signatures
(XEN) Found 1 EDD information structures
(XEN) EFI RAM map:
(XEN) [0000000000000000, 0000000000057fff] (usable)
(XEN) [0000000000058000, 0000000000058fff] (reserved)
(XEN) [0000000000059000, 0000000000068fff] (usable)
(XEN) [0000000000069000, 000000000006bfff] (reserved)
(XEN) [000000000006c000, 000000000008bfff] (usable)
(XEN) [000000000008c000, 000000000009ffff] (reserved)
(XEN) [0000000000100000, 00000000b5087fff] (usable)
(XEN) [00000000b5088000, 00000000b508efff] (reserved)
(XEN) [00000000b508f000, 00000000ca44efff] (usable)
(XEN) [00000000ca44f000, 00000000ccc3efff] (reserved)
(XEN) [00000000ccc3f000, 00000000ccd9efff] (ACPI NVS)
(XEN) [00000000ccd9f000, 00000000ccdfefff] (ACPI data)
(XEN) [00000000ccdff000, 00000000ccdfffff] (usable)
(XEN) [00000000f80f8000, 00000000f80f8fff] (reserved)
(XEN) [00000000fed1c000, 00000000fed1ffff] (reserved)
(XEN) [0000000100000000, 000000022dffffff] (usable)
(XEN) System RAM: x
(XEN) Domain heap initialised
(XEN) ACPI: 32/64X FACS address mismatch in FADT - ccd9a000/0000000000000000, using 32
(XEN) IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-39
(XEN) xstate: size: 0x340 and states: 0x7
(XEN) Speculative mitigation facilities:
(XEN) Hardware hints:
(XEN) Hardware features: IBPB IBRS STIBP SSBD L1D_FLUSH MD_CLEAR SRBDS_CTRL
(XEN) Compiled-in support: INDIRECT_THUNK HARDEN_ARRAY HARDEN_BRANCH HARDEN_GUEST_ACCESS HARDEN_LOCK
(XEN) Xen settings: BTI-Thunk: RETPOLINE, SPEC_CTRL: IBRS- STIBP- SSBD-, Other: SRB_LOCK+ IBPB-ctxt L1D_FLUSH VERW BRANCH_HARDEN
(XEN) L1TF: believed vulnerable, maxphysaddr L1D 46, CPUID 39, Safe address 8000000000
(XEN) Support for HVM VMs: MSR_SPEC_CTRL MSR_VIRT_SPEC_CTRL RSB EAGER_FPU
(XEN) Support for PV VMs: MSR_SPEC_CTRL EAGER_FPU VERW
(XEN) XPTI (64-bit PV only): Dom0 enabled, DomU enabled (with PCID)
(XEN) PV L1TF shadowing: Dom0 disabled, DomU enabled
(XEN) Using scheduler: SMP Credit Scheduler rev2 (credit2)
(XEN) Initializing Credit2 scheduler
(XEN) Platform timer is 14.318MHz HPET
(XEN) Detected 2593.992 MHz processor.
(XEN) Intel VT-d iommu 0 supported page sizes: 4kB, 2MB, 1GB
(XEN) Intel VT-d iommu 1 supported page sizes: 4kB, 2MB, 1GB
(XEN) Intel VT-d Snoop Control not enabled.
(XEN) Intel VT-d Dom0 DMA Passthrough not enabled.
(XEN) Intel VT-d Queued Invalidation enabled.
(XEN) Intel VT-d Interrupt Remapping enabled.
(XEN) Intel VT-d Posted Interrupt not enabled.
(XEN) Intel VT-d Shared EPT tables enabled.
(XEN) I/O virtualisation enabled
(XEN) - Dom0 mode: Relaxed
(XEN) Interrupt remapping enabled
(XEN) Enabled directed EOI with ioapic_ack_old on!
(XEN) Enabling APIC mode. Using 1 I/O APICs
(XEN) ENABLING IO-APIC IRQs
(XEN) -> Using old ACK method
(XEN) Allocated console ring of 16 KiB.
(XEN) VMX: Supported advanced features:
(XEN) - APIC MMIO access virtualisation
(XEN) - APIC TPR shadow
(XEN) - Extended Page Tables (EPT)
(XEN) - Virtual-Processor Identifiers (VPID)
(XEN) - Virtual NMI
(XEN) - MSR direct-access bitmap
(XEN) - Unrestricted Guest
(XEN) - VMCS shadowing
(XEN) - VM Functions
(XEN) - Virtualisation Exceptions
(XEN) HVM: ASIDs enabled.
(XEN) HVM: VMX enabled
(XEN) HVM: Hardware Assisted Paging (HAP) detected
(XEN) HVM: HAP page sizes: 4kB, 2MB, 1GB
(XEN) Brought up 2 CPUs
(XEN) Scheduling granularity: cpu, 1 CPU per sched-resource
(XEN) d0 has maximum 456 PIRQs
(XEN) Xen kernel: 64-bit, lsb
(XEN) Dom0 kernel: 64-bit, PAE, lsb, paddr 0x200000 -> 0x3800000
(XEN) PHYSICAL MEMORY ARRANGEMENT:
(XEN) Dom0 alloc.: 000000021c000000->0000000220000000 (1022671 pages to be allocated)
(XEN) Init. ramdisk: 000000022bacf000->000000022dfffbae
(XEN) VIRTUAL MEMORY ARRANGEMENT:
(XEN) Loaded kernel: ffffffff80200000->ffffffff83800000
(XEN) Phys-Mach map: 0000008000000000->0000008000800000
(XEN) Start info: ffffffff83800000->ffffffff838004b8
(XEN) Page tables: ffffffff83801000->ffffffff83822000
(XEN) Boot stack: ffffffff83822000->ffffffff83823000
(XEN) TOTAL: ffffffff80000000->ffffffff83c00000
(XEN) ENTRY ADDRESS: ffffffff82745cb0
(XEN) Dom0 has maximum 2 VCPUs
(XEN) Bogus DMIBAR 0xfed18001 on 0000:00:00.0
(XEN) Initial low memory virq threshold set at 0x4000 pages.
(XEN) Scrubbing Free RAM in background
(XEN) Std. Loglevel: Errors and warnings
(XEN) Guest Loglevel: Nothing (Rate-limited: Errors and warnings)
(XEN) *** Serial input to DOM0 (type 'CTRL-a' three times to switch input)
(XEN) Freed 664kB init memory
Special thanks to:
@alzer89 for their great redaction guide which helped me write this and my other post!
