Fixed: Problem with libxenlight. Sys-firewall, sys-net, sys-usb
Tl:dr – you have to have correct date set in bios to proper install qubes OS. That happend to me, when I bought new laptop. (thank you @marmarek - I read that in other topic)
Errors I got:
At end of install of qubes I got:
[‘/usr/bin/qvm-start’,’sys-firewall’] failed:
stdout: ””
stderr: „Start failed: internal error: Creating new domain „sys-net” through libxenlight did not succeed, see *var* log/libvirt/libxl/libxl-driver.log for details”
At startup I got:
Failed to start qubes-vm@sys-firewall.service
Failed to start qubes-vm@sys-usb.service
sudo journalctl -u qubes-vm@sys-firewall.service (and sys-net, sys-usb)
Creating new domain „sys-” through libxenlight did not succeed
sudo less /var/log/libvirt/libxl/libxl-driver.log:
libxl_pci.c:1587:libxl__decive_pci_reset: the kernel doesnt support reset drom sysfs for PCI device 0000:00:14.0
sudo journalctl -p err:
tmpfs: Unsupported parameter ‘huge’
parport_pc parport_pc.956 (and 888,632): Unable to set coherent dma mask: disabling DMA
failed to start qubes-vm@sys-firewall.service – Start Qubes VM sys-firewall
internal error: Cannot return PCI device 0000:00:14.0: no FLR. Return of PM or bus is not avalible
vm.sys-usb: Start failed: internal error: Creating new domain „sys-usb” through libxenlight did not succeed
PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Failed to start qubes-vm@sys-whonix.service – Start Qubes VM sys-whonix
sudo journalctl -xe
qvm-start sys-net
UnicodeEncodeError: ‘ascii’ codec cant encode character ‘\u201e’ in position 47: ordinal not in range (128)
Dell Latitude E5470
Xeon E3 – 1200 Skylake
RAM 16gbs
BIOS: UEFI, TPM, Virtualisation – all on
Qubes OS 4.2.3
