Hi all,
Recently all Updates fail when using the Updater (debian11, fedora34, whonix16). Any idea how I can remediate it for each OS?
Log:
Updating debian-11
Error on updating debian-11: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=debian-11’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20
debian-11:ID: update Function: pkg.uptodate Result: False Comment: Problem encountered upgrading packages. Additional info follows: result: ---------- pid: 1213 retcode: 100 stderr: Running scope as unit: run-r270790599f5d43baa3e9d3c7c02ffbfd.scope E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux/linux-headers-5.10.0-13-common_5.10.106-1_all.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux/linux-kbuild-5.10_5.10.106-1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux/linux-headers-5.10.0-13-amd64_5.10.106-1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux-signed-amd64/linux-headers-amd64_5.10.106-1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-5.10.0-13-amd64_5.10.106-1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/l/linux-signed-amd64/linux-image-amd64_5.10.106-1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/g/glibc/locales-all_2.31-13%2bdeb11u3_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/o/openssl/openssl_1.1.1n-0%2bdeb11u1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/u/usb.ids/usb.ids_2022.02.15-0%2bdeb11u1_all.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/x/xserver-xorg-video-intel/xserver-xorg-video-intel_2.99.917%2bgit20200714-1%2bdeb11u1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.debian.org/debian/pool/main/x/xterm/xterm_366-1%2bdeb11u1_amd64.deb Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? stdout: Reading package lists... Building dependency tree... Reading state information... Calculating upgrade... The following packages were automatically installed and are no longer required: linux-headers-5.10.0-10-amd64 linux-headers-5.10.0-10-common linux-headers-5.10.0-8-amd64 linux-headers-5.10.0-8-common linux-image-5.10.0-10-amd64 linux-image-5.10.0-8-amd64 Use 'apt autoremove' to remove them. The following NEW packages will be installed: linux-headers-5.10.0-13-amd64 linux-headers-5.10.0-13-common linux-image-5.10.0-13-amd64 The following packages will be upgraded: base-files brave-browser chromium chromium-common chromium-sandbox cups-browsed cups-filters cups-filters-core-drivers dirmngr gir1.2-gtk-3.0 gnupg gnupg-l10n gnupg-utils gnupg2 gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv gtk-update-icon-cache intel-microcode libarchive13 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dev libcupsfilters1 libflac8 libfontembed1 libgtk-3-0 libgtk-3-bin libgtk-3-common liblog4j1.2-java libmariadb3 libnss-systemd libpam-systemd libssl1.1 libsystemd0 libudev1 libxml2 linux-compiler-gcc-10-x86 linux-headers-amd64 linux-image-amd64 linux-kbuild-5.10 linux-libc-dev locales locales-all mariadb-common openssl systemd systemd-sysv systemd-timesyncd sysvinit-utils tasksel tasksel-data udev usb.ids xserver-xorg-video-intel xterm 63 upgraded, 3 newly installed, 0 to remove and 0 not upgraded. Need to get 78.8 MB/281 MB of archives. After this operation, 360 MB of additional disk space will be used. Err:1 https://deb.debian.org/debian bullseye/main amd64 linux-headers-5.10.0-13-common all 5.10.106-1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:2 https://deb.debian.org/debian bullseye/main amd64 linux-kbuild-5.10 amd64 5.10.106-1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:3 https://deb.debian.org/debian bullseye/main amd64 linux-headers-5.10.0-13-amd64 amd64 5.10.106-1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:4 https://deb.debian.org/debian bullseye/main amd64 linux-headers-amd64 amd64 5.10.106-1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:5 https://deb.debian.org/debian bullseye/main amd64 linux-image-5.10.0-13-amd64 amd64 5.10.106-1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:6 https://deb.debian.org/debian bullseye/main amd64 linux-image-amd64 amd64 5.10.106-1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:7 https://deb.debian.org/debian bullseye/main amd64 locales-all amd64 2.31-13+deb11u3 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:8 https://deb.debian.org/debian bullseye/main amd64 openssl amd64 1.1.1n-0+deb11u1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:9 https://deb.debian.org/debian bullseye/main amd64 usb.ids all 2022.02.15-0+deb11u1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:10 https://deb.debian.org/debian bullseye/main amd64 xserver-xorg-video-intel amd64 2:2.99.917+git20200714-1+deb11u1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Err:11 https://deb.debian.org/debian bullseye/main amd64 xterm amd64 366-1+deb11u1 Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] Started: 13:06:48.806518 Duration: 157312.082 ms Changes:
ID: notify-updates Function: cmd.run Name: /usr/lib/qubes/upgrades-status-notify Result: True Comment: Command "/usr/lib/qubes/upgrades-status-notify" run Started: 13:09:26.138595 Duration: 23538.86 ms Changes: ---------- pid: 1252 retcode: 0 stderr: stdout:Summary for debian-11
Succeeded: 1 (changed=1)
Failed: 1Total states run: 2
Total run time: 180.851 s
Updating fedora-34
Error on updating fedora-34: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=fedora-34’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20
fedora-34:ID: dnf-and-rpm Function: pkg.installed Result: True Comment: All specified packages are already installed and are at the desired version Started: 13:10:46.561353 Duration: 4664.788 ms Changes:
ID: /usr/lib/rpm/macros.d/macros.qubes Function: file.absent Result: True Comment: File /usr/lib/rpm/macros.d/macros.qubes is not present Started: 13:10:51.231757 Duration: 0.77 ms Changes:
ID: dnf-makecache Function: cmd.script Result: False Comment: Could not create DNF metadata cache Started: 13:10:51.234143 Duration: 124455.032 ms Changes:
ID: update Function: pkg.uptodate Result: False Comment: One or more requisite failed: update.qubes-vm.dnf-makecache Started: 13:12:55.691464 Duration: 0.02 ms Changes:
ID: notify-updates Function: cmd.run Name: /usr/lib/qubes/upgrades-status-notify Result: False Comment: Command "/usr/lib/qubes/upgrades-status-notify" run Started: 13:12:55.691711 Duration: 125554.592 ms Changes: ---------- pid: 1136 retcode: 1 stderr: Error: Failed to download metadata for repo 'fedora': Cannot prepare internal mirrorlist: Curl error (56): Failure when receiving data from the peer for https://mirrors.fedoraproject.org/metalink?repo=fedora-34&arch=x86_64 [Received HTTP code 500 from proxy after CONNECT] stdout:Summary for fedora-34
Succeeded: 2 (changed=1)
Failed: 3Total states run: 5
Total run time: 254.675 s
Updating whonix-gw-16
Error on updating whonix-gw-16: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=whonix-gw-16’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20
whonix-gw-16:ID: update Function: pkg.uptodate Result: False Comment: E: Failed to fetch tor+https://deb.debian.org/debian/dists/bullseye/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.debian.org/debian/dists/bullseye-updates/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.debian.org/debian-security/dists/bullseye-security/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.debian.org/debian/dists/bullseye-backports/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://fasttrack.debian.net/debian/dists/bullseye-fasttrack/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.whonix.org/dists/bullseye/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.qubes-os.org/r4.0/vm/dists/bullseye/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Some index files failed to download. They have been ignored, or old ones used instead. Started: 11:14:21.495490 Duration: 164365.055 ms Changes:
ID: notify-updates Function: cmd.run Name: /usr/lib/qubes/upgrades-status-notify Result: False Comment: Command "/usr/lib/qubes/upgrades-status-notify" run Started: 11:17:05.907389 Duration: 164227.464 ms Changes: ---------- pid: 1262 retcode: 100 stderr: stdout:Summary for whonix-gw-16
Succeeded: 0 (changed=1)
Failed: 2Total states run: 2
Total run time: 328.593 s
Updating whonix-ws-16
Error on updating whonix-ws-16: Command ‘[‘sudo’, ‘qubesctl’, ‘–skip-dom0’, ‘–targets=whonix-ws-16’, ‘–show-output’, ‘state.sls’, ‘update.qubes-vm’]’ returned non-zero exit status 20
whonix-ws-16:ID: update Function: pkg.uptodate Result: False Comment: E: Failed to fetch tor+https://deb.debian.org/debian/dists/bullseye/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.debian.org/debian/dists/bullseye-updates/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.debian.org/debian-security/dists/bullseye-security/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.debian.org/debian/dists/bullseye-backports/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://fasttrack.debian.net/debian/dists/bullseye-fasttrack/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch tor+https://deb.whonix.org/dists/bullseye/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Failed to fetch https://deb.qubes-os.org/r4.0/vm/dists/bullseye/InRelease Invalid response from proxy: HTTP/1.0 500 Unable to connect Server: tinyproxy/1.10.0 Content-Type: text/html Connection: close [IP: 127.0.0.1 8082] E: Some index files failed to download. They have been ignored, or old ones used instead. Started: 11:24:45.391081 Duration: 164518.341 ms Changes:
ID: notify-updates Function: cmd.run Name: /usr/lib/qubes/upgrades-status-notify Result: False Comment: Command "/usr/lib/qubes/upgrades-status-notify" run Started: 11:27:29.913416 Duration: 164361.262 ms Changes: ---------- pid: 1534 retcode: 100 stderr: stdout:Summary for whonix-ws-16
Total run time: 328.880 s
