Unable to type luks password after fresh 4.3.0 install with detached header
Hi!
I followed the guide to install Qubes OS with detached LUKS header here: Install Qubes OS with boot partition and a detached LUKS header on USB
I had done it in the past without issue on another computer (with the same SD card to hold the header).
This time, at first boot (when I click “Reboot” at the end of installation), I am not able to type my LUKS passphrase. When I reached the dedicated screen, first there is no typing bar. If I type F2 or F8, the typing bar appears (so my keyboard is working), but no input is taken in the bar. There is no way to type it. If I type esc (or if I boot without the ‘rhgb’ parameter), I see that I am not asked to give the LUKS passphrase (it’s like I do not reach this step and the system hangs before it).
I have followed the guide from scratch 4 or 5 time so I think it is not an error I made while following the guide. I also tried with kernel-latest, so it is probably not a kernel issue. I also tried plugging in a USB keyboard without success (as expected, since my built-in keyboard seems to work when typing F2 and F8)
If I follow the normal installation (with attached LUKS header), I have no issue, so it is related to the detached header.
I have 2 NVMe and on the other one a Linux distro is already installed (in case it is noteworthy). I intend to dual-boot and this I why I want to have a detached header. I know the other security concerns and it is compliant with my threat model.
I have gathered the logs from the functional install (with attached header) and the dysfunctional install (with detached header). I looked through the differences without seeing something that I could identify as the problem.
Here is the error log (journalctl -b -p err) with the detached header:
Feb 05 10:34:05 dom0 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20240827/dswload2-162)
Feb 05 10:34:05 dom0 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
Feb 05 10:34:05 dom0 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP5.RTL8], AE_NOT_FOUND (20240827/dswload2-162)
Feb 05 10:34:05 dom0 kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
Feb 05 10:34:05 dom0 kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
Feb 05 10:34:05 dom0 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP7.DEV0], AE_NOT_FOUND (20240827/dswload2-162)
Feb 05 10:34:05 dom0 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20240827/psargs-332)
Feb 05 10:34:05 dom0 kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
Feb 05 10:34:05 dom0 kernel: amd_pstate: failed to enable driver mode(3)
Feb 05 10:34:05 dom0 kernel: ccp 0000:36:00.2: tee: ring init command failed (0x00000005)
Feb 05 10:34:05 dom0 kernel: ccp 0000:36:00.2: tee: failed to init ring buffer
Feb 05 10:34:07 dom0 kernel: nouveau 0000:01:00.0: gsp ctor failed: -2
Feb 05 10:34:07 dom0 kernel: nouveau 0000:01:00.0: probe with driver nouveau failed with error -2
Feb 05 10:49:29 dom0 kernel: EXT4-fs (sda): VFS: Can't find ext4 filesystem
Here is the error log with the attached header:
févr. 05 12:18:24 localhost kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20240827/dswload2-162)
févr. 05 12:18:24 localhost kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
févr. 05 12:18:24 localhost kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP5.RTL8], AE_NOT_FOUND (20240827/dswload2-162)
févr. 05 12:18:24 localhost kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP6.WLAN._S0W], AE_ALREADY_EXISTS (20240827/dswload2-326)
févr. 05 12:18:24 localhost kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
févr. 05 12:18:24 localhost kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP7.DEV0], AE_NOT_FOUND (20240827/dswload2-162)
févr. 05 12:18:24 localhost kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20240827/psargs-332)
févr. 05 12:18:24 localhost kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
févr. 05 12:18:24 localhost kernel: amd_pstate: failed to enable driver mode(3)
févr. 05 12:18:24 localhost kernel: ccp 0000:36:00.2: tee: ring init command failed (0x00000005)
févr. 05 12:18:24 localhost kernel: ccp 0000:36:00.2: tee: failed to init ring buffer
févr. 05 12:18:26 localhost kernel: nouveau 0000:01:00.0: gsp ctor failed: -2
févr. 05 12:18:26 localhost kernel: nouveau 0000:01:00.0: probe with driver nouveau failed with error -2
févr. 05 12:19:24 dom0 kernel: Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8852bu_fw not found
févr. 05 12:19:25 dom0 alsactl[3678]: /usr/sbin/alsactl: load_state:1715: Cannot open /var/lib/alsa/asound.state for reading: No such file or directory
févr. 05 12:19:25 dom0 xenstored[3702]: Checking store ...
févr. 05 12:19:25 dom0 xenstored[3702]: Checking store complete.
févr. 05 12:19:33 dom0 anaconda[4684]: anaconda: ui.gui.hubs: Initialization controller for hub InitialSetupMainHub expected but missing.
févr. 05 12:39:54 dom0 lightdm[21832]: gkr-pam: unable to locate daemon control file
I also attach the full journalctl output of both attached header install and detached header version in case someone is able to find something.
Thank you very much in advance for your time!
Of course, do not hesitate to ask for more information.
journalctl_6.12_all_attached.log (931.7 KB)
journalctl_6.12_all_detached.log (180.0 KB)
I’m not sure if your issue is the same as mine, but here’s what I’m facing: after rebooting my system, I’m stuck at the LUKS passphrase screen, and there’s no typing bar. This screen stays visible for about five minutes before showing an error.
This response helped me: Install Qubes OS with boot partition and a detached LUKS header on USB - #67 by tonicnapkin
For Qubes 4.3:
add_dracutmodules+=" systemd-cryptsetup "
install_items+=" /root/header.img "
