The purpose of having a detached LUKS header and boot partition on a separate external disk is to achieve a deniable encryption:
The encrypted disk will look like an unused/empty unpartitioned disk.
This guide assumes the following:
/dev/sda - disk where you want to install Qubes OS
/dev/sdb - USB disk where you want to install Qubes OS boot partition
Step 1: Create LUKS Container and Create Filesystem
Boot into Qubes OS installer and on GUI screen switch to shell on another TTY by pressing Ctrl+Alt+F2. In this shell run these commands:
# List your disks. You should find and identify the disks you want to use for your
# detached /boot and header and main Qubes install. SATA disks and USB drives will
# show up as /dev/sdX, e.g. /dev/sda. NVME drives will show up as /dev/nvmeXn1,
# e.g. /dev/nvme0n1
fdisk -l
# Create an empty placeholder file for the LUKS header
dd if=/dev/zero of=header.img bs=16M count=1
# Format LUKS container. You will be prompted for the password you want to use to decrypt the disk.
cryptsetup luksFormat /dev/sda -c aes-xts-plain64 --key-size 512 --pbkdf argon2id --iter-time 10000 --use-random --force-password --verify-passphrase --header header.img
# Unlock the LUKS container for formatting
cryptsetup open --header header.img /dev/sda luks
# Format container as BTRFS
mkfs.btrfs --csum xxhash -L qubes_dom0 -d single /dev/mapper/luks
Step 2: Add Qubes Partitions
Return to Qubes OS installer GUI by pressing Ctrl+Alt+F6.
Configure the installation as normal except for Installation Destination:
At the Installation Destination screen click on “Refresh…” at the bottom right corner and in the opened window press on “Disk rescan” button and then OK.
At the Device Selection choose your Qubes OS installation destination and boot partition destination disks /dev/sda and /dev/sdb.
At the Storage Configuration select “Advanced Custom (Blivet-GUI)”.
Press Done.
In the “BLIVET GUI PARTITIONING” screen select “sdb” disk.
Delete the old partitions on the disk if needed.
Add new partition using “+” button:
Device type: Partition
Filesystem: EFI System
Mountpoint: /boot/efi
Press OK button.
Filesystem: ext4
Mountpoint: /boot
Press OK button.
In the “BLIVET GUI PARTITIONING” screen select “qubes_dom0” Btrfs Volume.
Add new subvolume using “+” button:
Mountpoint: /
Press OK button.
Press on Done button in “BLIVET GUI PARTITIONING” and then “Accept Changes” button in “SUMMARY OF CHANGES” window.
Press “Begin Installation” button.
After installation is completed don’t press “Reboot System” button.
Step 3: Configure Install to use Detached Header and /boot, and Configure System
Switch to shell on another TTY by pressing Ctrl+Alt+F2.
Run these commands in the installer shell:
# Copy LUKS header to dom0 /root of newly installed system
cp header.img /mnt/sysroot/root/
# Do a CHROOT in preparation for configuring system
cd /mnt/sysroot && chroot /mnt/sysroot
# Make a swapfile. This is highly recommended to prevent critical failures in edge cases where dom0 runs out of memory.
btrfs subvolume create /swap
btrfs filesystem mkswapfile --size=4g --uuid clear /swap/swapfile
Edit /etc/fstab file using nano or any other text editor:
nano /etc/fstab
Add noauto option to the /boot and /boot/efi mounts like this:
UUID=XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX /boot ext4 defaults,discard,noauto 1 2
UUID=XXXX-XXXX /boot/efi vfat umask=0077,shortname=winnt,discard,noauto 0 2
And add this line at the end:
/swap/swapfile none swap defaults,discard=once 0 0
Save and close /etc/fstab file.
Edit /etc/default/grub file using nano or any other text editor:
nano /etc/default/grub
Remove rd.luks.uuid=XXXXX option and add rd.driver.pre=btrfs option to the GRUB_CMDLINE_LINUX variable. It should look like this:
GRUB_CMDLINE_LINUX="rd.driver.pre=btrfs plymouth.ignore-serial-consoles 6.7.7-1.qubes.fc37.x86_64 x86_64 rhgb quiet"
Save and close /etc/default/grub file.
Create new /etc/dracut.conf.d/crypt.conf file using nano or any other text editor:
nano /etc/dracut.conf.d/crypt.conf
Add this text inside:
add_dracutmodules+=" crypt systemd-cryptsetup "
install_items+=" /root/header.img "
Save and close /etc/dracut.conf.d/crypt.conf file.
Find out the ID of your Qubes OS destination disk /dev/sda:
ls -la /dev/disk/by-id/ | grep /sda
For example it’ll look like this:
lrwxrwxrwx 1 root root 9 May 10 20:15 ata-YOUR_DISK_ID -> ../../sda
Here ata-YOUR_DISK_ID is your disk ID.
Append the disk ID to the /etc/crypttab file to not type it by hand there:
ls /dev/disk/by-id/ | grep ANY_UNIQUE_PART_OF_YOUR_DISK_ID >> /etc/crypttab
Edit /etc/crypttab file using nano or any other text editor:
nano /etc/crypttab
luks /dev/disk/by-id/ata-YOUR_DISK_ID none header=/root/header.img,force,discard
Save and close /etc/crypttab file.
Run these commands:
grub2-mkconfig -o /boot/grub2/grub.cfg
dracut -f --regenerate-all
exit
Press on “Reboot System” button.
After this proceed with normal Qubes OS post-installation process:
Step 4: Use and Updating
Since /boot and /boot/efi partitions are stored on USB disk then you’ll need to attach this disk to your dom0 when doing dom0 updates so the files there will be updated.
It’s better to use disposable sys-usb for this setup.
When you want to update your dom0 you can follow these steps:
Disconnect all your USB devices.
Restart sys-usb to clear it’s state.
Connect your USB disk with Qubes OS /boot partition.
Run this command in dom0 to mount the /boot and /boot/efi partitions in dom0 assuming that /dev/sda is the name of your USB disk with Qubes OS /boot partition in sys-usb:
qvm-block attach dom0 sys-usb:sda1 && qvm-block attach dom0 sys-usb:sda2 && sudo mount /boot && sudo mount /boot/efi
Run dom0 update.
After dom0 update is finished run this command in dom0 to unmount and remove /boot and /boot/efi partitions from dom0:
sudo umount /boot/efi /boot && qvm-block d dom0 sys-usb:sda1 && qvm-block d dom0 sys-usb:sda2
At this point you can disconnect the USB disk with Qubes OS /boot partition from your machine and continue to use sys-usb with other USB devices as normal.
Note on Plausible Deniability and TRIM
Since TRIM is enabled by default:
This could indicate that this disk is not unused and this could break the plausible deniability:
So you may want to disable the TRIM, but this will reduce the disk performance.
