Tuxedo Infinitybook S15 Gen. 7 / InfinityBook Pro 14 - Gen. 7 Compatibility?
Hi There,
I am looking for a lightweight portable notebook for q-os and stumbled upon the Tuxedo Infinitybook S15 Gen 7. & InfinityBook Pro 14 - Gen7 which both looks quite promising.
I could find the Gen 6. in the HCL which looked pretty good, unfortunately not available anymore.
Does anyone have any insights on compatibility?
Thank you very much!
You’re probably going to have a lot of pain with 12th gen intel chips. I am struggling to get suspend working as expected on a Lenovo X1 Carbon witth tthe 1260P chip
thanks for the reply.
Yeah, thats unfortunate.
I am just trying to find a decent solution.
Super unfortunate that compatability is such a big issue.
Done so much research and I cant seem to find anything that works well out of the box and is somewhat modern.
I keep coming back to the librem 14 which is very high priced for what it is.
Also reading so many bad things about customer service & built quality makes me not want to pull the rigger.
I will keep digging!
Thank you for your insight!
I am trying to standardize on Lenovo and am 40+ hours deep into getting it working flawlessly, there are a number of workarounds needed but I am automating them. Please check my posts and see if they’re helpful to you, I have suspend working now.
gotscha,
I would love to skip any automations and would still prefer a modern device mainly for portability.
I might end up going for a librem.
thank your for your time!
