Another random guess is maybe you need to import the keys locally and not to download them from the internet in repo file like this:
https://qubes.3isec.org/tasks.html
You can try to download and import the key in dom0 and then change the gpgkey to local file in repos e.g.:
gpgkey=https://download.copr.fedorainfracloud.org/results/kallepm/tuxedo-keyboard/pubkey.gpg
to
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-tuxedo-keyboard
qun
December 26, 2023, 4:16pm
42
how can I download the key in dom0? I have no wget.
Follow the steps described here:
You can download the keys in AppVM and copy them to dom0.
Trying it out
To test the water, we are making available a test repository, and a simple tool to access it.
The repository definition is:
[3isec-dom0-current] name = 3isec Qubes Dom0 Repository (updates) baseurl = https://qubes.3isec.org/rpm/r$releasever/current/dom0/fc32 skip_if_unavailable=False enabled = 1 metadata_expire = 6h gpgcheck = 1 gpgkey = file:///etc/pki/rpm-gpg/RPM-GPG-KEY-unman
Create a file in dom0 with this content at /etc/yum.repos.d/3isec-dom0.repo
All packages are signed with my Qubes OS Signing key.
You’ll need to get this from a keyserver, or two, to make sure all is fine:
keyserver.ubuntu.com or pgp.mit.edu
You can also check the Qubes users mailing list or look on github .
Once you have copies of the key, check the fingerprint:
gpg -n --import --import-options import-show unman.pub
replacing unman.pub with the path to the key.
The output should look similar to this:
pub rsa4096 2016-06-25 [SC] 4B1F 400D F256 51B5 3C41 41B3 8B3F 30F9 C8C0 C2EF uid [ unknown] unman (Qubes OS signing key) sub rsa4096 2016-06-27 [S] [expires: 2024-06-30] sub rsa4096 2016-06-25 [E]
In particular, check that the output from your command contains the fingerprint 4B1F 400D F256 51B5 3C41 41B3 8B3F 30F9 C8C0 C2EF
When you are happy, copy the key in to dom0:
qvm-run -p QUBE_WHERE_YOU_DOWNLOADED_KEY ‘cat PATH_TO_KEY’ > RPM-GPG-KEY-unman sudo mv RPM-GPG-KEY-unman /etc/pki/rpm-gpg/
Add the key to the rpm keyring:
sudo rpm --import /etc/pki/rpm-gpg/RPM-GPG-KEY-unman
qun
December 26, 2023, 4:34pm
44
ok, crazy! as it seems, I could install it after importing the gpg key manually. Thanks!
It works even without reboot!
So I have the icon of Tuxedo Control Center and it seems to control the fans! So will see, how good it works after some time.
Thanks a lot!!!
qun
December 27, 2023, 8:06pm
45
just a feedback.
The fans are significantly quieter! With “cool and breezy” profile, I get really silent laptop and see no real performance losses.
So if somebody has Tuxedo and uses QubesOS, it makes sense to install the Tuxedo Control Center!
Could you make a short guide out of it. This would be great for the tux-community.
qun
July 9, 2024, 8:36am
47
Hey, I just followed the official tutorial, nothing special.
