I’m having trouble connecting my kindle to an appvm using USB. When I connect the kindle to the laptop, it recognizes the kindle and I can select it from the USB toolbar applet. But when I try and connect it to my appvm, it disconnects and doesn’t reconnect. It works fine within my sys-usb but I can’t connect it to the appvm I need. I’m using 4.2 RC4. Any suggestions? Thank you.
Workaround: You can try to attach the whole USB controller to your AppVM, then it will behave like sys-usb, i.e., should work.
Related issue:
opened 10:34PM - 05 Jan 21 UTC
T: bug
P: default
hardware support
C: usb proxy
needs diagnosis
affects-4.1
<!-- IMPORTANT: Please read our issue tracker guidelines before submitting this … issue:
https://www.qubes-os.org/doc/reporting-bugs/
Please do not delete or remove any part of this issue template. -->
### Qubes OS version:
R4.0 up to date current, Android 11 (Pixel phone up to date 5 dec 20 - reference platform)
f32 target Qube, f32-min sys-usb
### Affected component(s) or functionality:
USB handling - dom0
### Steps to reproduce the behavior:
Attach Android 11 device with file transfer enabled to a Qube running Nautilus.
### Expected or desired behavior:
Entry for device appears in menu in Nautilus and I can select that item to browse the filesystem on the Android device.
### Actual behavior:
Menu item appears as expected, however selection goes away for 5-10 sec then gives a popup "Unable to connect to MTP device 00n,00n" and deletes the Nautilus menu item.
### General notes:
Please see forum thread for more details:
https://qubes-os.discourse.group/t/how-can-i-connect-to-android-via-usb/2101
An older v8 Android does partially work: same error popup in Nautilus, dismiss that, detach and reattach, then works as expected.
If looking into this I did notice another bug in the device widget communication - if Android file transfer is enabled or disabled while attached to a Qube the attachment is dropped in dom0, however the widget is not notified. Attempting detach in the widget gives a not attached error popup.
### I have consulted the following relevant [documentation](https://www.qubes-os.org/doc/):
### I am aware of the following related, [non-duplicate](https://www.qubes-os.org/doc/reporting-bugs/#new-issues-should-not-be-duplicates-of-existing-issues) issues:
Thanks - that did work. It’s not an ideal solution because a lot of other USB devices get disconnected from the sys-usb when I do this. But it was a successful workaround. Thanks again.
