Terminal in the same disposable
When I open firefox in the disposable I get an appvm with a number something like disp-5697, but then when I try to open a terminal to do something inside that disposable, I get another disposable number like disp-8635…
How do I open terminal inside the same disposable???
In dom0 tray open “Qubes Domains” widget → disp5697 → Run Terminal.
If you’re using Qubes OS 4.2 then you can run apps for specific disposable using Qubes App Menu Q → APPS → disp5697 → Xfce terminal
Cool, thanks.
But what if I wanna use a minimal appvm and run terminal there? The way you described it it’s only for the user and not the root, but I can’t start it with the command line on dom0 because it opens another completely different disposable
You mean you want to run root terminal in disposable qube based on minimal template without passwordless sudo package?
You can run root terminal from dom0 terminal:
qvm-run -u root disp5697 uxterm &
You rock man! Much appreciate it!
You can fairly easily have keyboard shortcuts which will run such
commands in the qube that has focus.
(easily in KDE - I assume somewhat easily in Xfce.)
I can post examples later if interest.
Yes, please!
In the morning
Better late than never:
  1. Create a script at /home/user/bin/open_terminal.sh
#!/bin/bash
ID=`xdotool getwindowfocus`
QUBE=`xprop _QUBES_VMNAME -id $ID|cut -f2 -d\" `
if [[ "$QUBE" == "_QUBES_VMNAME:  not found." ]]; then
	exit
else
  qvm-run $QUBE /usr/bin/qubes-run-terminal &
fi
  1. Make script executable
    sudo chmod +x /home/user/bin/open_terminal.sh
  2. Create shortcut
  3. In KDE:
    * SystemSettings->Shortcuts->“Custom Shortcuts”
    * Edit-New->Global Shortcut->Command/URL
    * Optionally Provide Name for action
    * Under “Trigger” enter keyboard combo
    * Under Action, enter path to script
    * Apply
  4. Xfce:
    * Settings->keyboard
    * On Application Shortcuts pane, select “Add”
    * Use chooser to select command
    * Define Keyboard combo
  5. The script at 1 is completely generic - you can use it for any
    commands- eg echo $QUBE|speak-ng -- will speak the name of the
    focussed qube.
    You can use one-liners of complex scripts as you will.
The first if statement tests for lack of QUBES_VMNAME - that is dom0.
Instead of exit call you can run program/script here.
  1. To have a root terminal use qvm-run -u root..
    You can, of course, have separate scripts and shortcuts for spawning root and
    user terminals, or run different applications by qube name using elif
    statements.
Thanks!
I will look at it as soon as I find time (so in half a year haha)
