layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
System76
model: |
Galago Pro
bios: |
1.05.12-1
cpu: |
Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
cpu-short: |
FIXME
chipset: |
Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5904] (rev 02)
chipset-short: |
FIXME
gpu: |
Intel Corporation HD Graphics 620 [8086:5916] (rev 02) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
Intel Corporation Wireless 8265 / 8275 (rev 78)
memory: |
32548
scsi: |
usb: |
1
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.1
xen: |
4.14.3
kernel: |
5.10.90-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
QubesOS works fine.
It showed the common error “Unable to reset PCI device” error as described on: PCI troubleshooting — Qubes OS Documentation and followed the instructions as provided there which resolved the issue.
- Webcam works
- Mic works
- USB works
- wifi works
- CAT45 Network card works
- USB works
- Suspend works, if you wait the 30 seconds and let it turn off itself.
If you click yes to avoid the 30 second wait it goes to the login screen instead. Then at the top you need to select Suspend again to make it to Suspend. Not sure if related to the hardware.
Screen does not turn-off when machine is idle for a while but goes black instead. Screen backlight remains on. Have not found a solution for that but it is minor.
High Resolution screen causes everything to be extremely small and configuring this correctly takes time. See for the solution (thanks to the amazing @Sven) here: 4k font size dom0 vs vm - #9 by trounces
System76 Galago Models support CoreBoot automatically from the Galago Pro 3 and on which is awesome. But for the Galago Pro 2 you need to purchase some hardware to flash it manually (something I did not do yet but this is not recommended for the normal user). See: firmware-open/models/galp2 at master · system76/firmware-open · GitHub and firmware-open/docs/flashing.md at master · system76/firmware-open · GitHub (this manual flashing does not apply to the newer Galago’s which you can install coreboot on without flashing using any hardware).
- HCL_System76_Galago_Pro_2_N131BU.yml (952 Bytes) (should be
Qubes-HCL-System76-Galago_Pro-20220217-235200.yml)
