Continuing the discussion from Draphio's Journey into the Qubes virtualization:
Starting a thread to discuss the above issue.
Hi @draphios
Welcome to Qubes. Glad you are pleased.
That [FAILED] Failed to start Load Kernel Modules message can be
safely ignored.
If you check the status as suggested, you see that it has (eventually)
loaded, and exited with status=SUCCESS.
This is in the FAQ
I had replied to the original explaining:
I assume my reply got lost in transition.
Iām not clear what there is left to discuss.
Thank you for pointing that guide.
