Everytime I load qubes it says the sys net and firewall failed to load and when I fresh install it says it right off the bat I’ve been up all night troubleshooting this and I have nothing
The error I get is :
Qubes sys-net has failed to start :qrexec-daemon startup failed (date) qrexec-daemon [8356] : qrexec-daemon.c:144:sigchld_parent_handler: connection to the VM failed
I’ve seen people with similar problems but the explanation on how to fix it wasn’t clear and just confused me I’m assuming it’s something to do with the network controller since when I get rid of it the error isn’t there but not very helpful without wifi lol . The controller is a 8821ce I saw that come up a lot
But…
With new laptop now which does not have an ethernetport we still have the prolem « dkms » (which is a requierement to do your point 3) is not installed by default (except if I am wrong). Then it will be dificult to install this required this module.
You can use USB-Ethernet or USB-Wifi adapter.
Or you can download the required packages from another OS and move them to sys-net template using USB drive to install them there.
