So, after a while of having no audio in HVMs if using sys-audio, I decided to have a look into the issue. Using Using sys-audio for Windows audio - #9 by disp584 as a starting point, I created a patch file that can be applied to init in /usr/libexec/xen/boot/qemu-stubdom-linux-full-rootfs.
--- init 2023-03-30 17:15:27.389013186 +0100
+++ init 2023-03-30 17:17:35.048015003 +0100
@@ -29,6 +29,7 @@
# add audiodev conf to cmdline and run pulseaudio
audio_model=$(echo "$dm_args" | sed -n '/^-soundhw/ {n;p}')
+audioid=$(xenstore-read "/global/qvm-hvm-audio-id" || echo "0")
if [ -n "$audio_model" ] ; then
model_args=
if [ "$audio_model" == "ich6" ] ; then
@@ -38,7 +39,7 @@
pa_args=$'-audiodev\npa,id=qemupa,server=unix:/tmp/pa.sock'$model_args;
pulseaudio --use-pid-file=no --daemonize=no --exit-idle-time=-1 --disable-shm=yes -n \
-L "module-native-protocol-unix auth-anonymous=1 socket=/tmp/pa.sock" \
- -L "module-vchan-sink domid=0" &
+ -L "module-vchan-sink domid=$audioid" &
fi
# Extract network parameters and remove them from dm_args
Following @disp584’s instructions, ensuring that commands are run as root…
- If patch is not already installed…
qubes-dom0-update patch - Make a working directory for the stubdom:
mkdir /tmp/stubroot - Copy the stubdom into the directory:
cp /usr/libexec/xen/boot/qemu-stubdom-linux-full-rootfs /tmp/stubroot/stubdom.gz - cd into the directory:
cd /tmp/stubroot - Decompress:
gzip -d stubdom.gz - Extract:
cpio -i -d -H newc --no-absolute-filenames < stubdom ; rm stubdom - Patch init:
patch < /path/to/downloaded/audioid.patch - Rebuild stubdom:
find . -print0 | cpio --null -ov --format=newc | gzip -9 > ../new-stubdom - (Optional) Make a backup of the original stubdom:
cp /usr/libexec/xen/boot/qemu-stubdom-linux-full-rootfs /usr/libexec/xen/boot/qemu-stubdom-linux-full-rootfs.BAK - Copy the new stubdom over the old one:
mv ../new-stubdom /usr/libexec/xen/boot/qemu-stubdom-linux-full-rootfs - Save the following below to a script and execute said script to update the requisite xen variable:
#!/bin/bash
audiodomain=$(qubes-prefs default_audiovm)
echo "Audio domain is $audiodomain"
ADxid=$(qvm-prefs "$audiodomain" xid)
echo "xid of audio domain is $ADxid"
if [ "$ADxid" -gt -1 ]; then
xenstore-write /global/qvm-hvm-audio-id "$ADxid"
xenstore-chmod /global/qvm-hvm-audio-id "r*w0"
else
echo "Not updating, AudioVM not running!"
fi
echo "Wrote $ADxid to /global/qvm-hvm-audio-id and reset perms to r*w0"
This should now allow audio to work correctly within HVMs. Unfortunately, attempts to make the script above execute automatically as a libvirt hook only caused the system to hang upon reboot or upon starting up any HVM. Even executing the script above in background results in the system hanging. I suspect this is due to QubesDB or whatever qubes-prefs/qvm-prefs uses hanging while a VM starts up. Also, this script assumes that “default_audiovm” is set to something other than dom0 via qubes-prefs default_audiovm.
So, any additions to this solution is welcome!
