Starting windows 10 HVM gives an error `block device dom0:loopX not available`
I made a Windows 10 HVM and installed qubes windows tool. It starts and seem to sort of work. But after rebooting the computer, when I try qvm-start <windows 10 VM name>, I see an error like: block device dom0:loopX not available .
I can work around the error by runing qvm-start <Windows 10 qube name> --install-windows-tools for X times before qvm-start-gui --force-stubdomain .
For me, X is 27. I don’t know how to fix that. For now, I try to ignore the 27 notifications of error.
Use:
qvm-block detach <Windows 10 qube name>
I had the same problem today: when I tried to start Windows11-HVM, the following message appeared:
The command qvm-block detach <Windows 10 qube name> did not help.
The following command helped: qvm-block unassign <Windows 10 qube name>
Yes assign/unassign was introduced in Qubes R4.3 and you should use qvm-block unassign. But if you’re on Qubes R4.2 then qvm-block detach is the correct command.
