Starlabs - Starbook mk VI intel
Here another HCL report for Starbook mk VI intel from Starlabs
Remarks
Kernel 6 required
I had issues at first when I installed Qubesos with kernel 5th serie and most of them were solved upgrading to 6th kernel (reported by other HCL).
Lack of GPU virtualization
The main remaining issue is lack of GPU support - The CPU is not sufficient even for displaying a 720p video at a comfortable refresh rate, at full-speed fan.
I thought of making graphics virtualization work to share a bit of GPU power with some App VMs.
I tried hard to make SR-IOV from 12th gen intel cpu work with Xen but never succeeded.
(Xorg.0.log - AIGLX: Screen 0 is not DRI2 capable)
Mouse hangs under high load
Another issue is the mouse refresh rate slowing down under high load (starting heavy App VM for example).
Previous HCL for this device :
layout:
  'hcl'
type:
  'laptop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  'unknown'
remap:
  'yes'
brand: |
  Star Labs
model: |
  StarBook
bios: |
  8.31
cpu: |
  12th Gen Intel(R) Core(TM) i7-1260P
cpu-short: |
  FIXME
chipset: |
  Intel Corporation Device [8086:4621] (rev 02)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation Device [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
memory: |
  65379
scsi: |
usb: |
  1
versions:
- works:
    'FIXME:yes|no|partial'
  qubes: |
    R4.1
  xen: |
    4.14.5
  kernel: |
    6.3.2-1
  remark: |
    FIXME
  credit: |
    FIXAUTHOR
  link: |
    FIXLINK
Qubes-HCL-Star_Labs-StarBook-20230615-233045.cpio.gz (7.9 KB)
Thank you @distopia for your HCL report, which is online now!
