Syncthing is an awesome piece of software used to keep files in sync across multiple devices using end-to-end encryption without requiring port forwarding or leaving files on a third-party server.
This guide is intended to allow syncing of files in netvm-less qubes across two (or more) devices running Qubes. This could be used to sync bookmarks for split-browser, or for keeping a KeepassXC file up to date.
Requirements
You will need to install syncthing in the template
This relies on the previous guide for using qubes-sync with multiple qubes (https://forum.qubes-os.org/t/use-qubes-sync-with-multiple-clients-and-one-server/19780). It assumes this directory structure exists:
/rw/syncdir/
authorized_keys/
clientvm1/
writable/
clientvm2/
writable/
In this structure, all directories except writable are owned by root. Each writable folder is owned by a single user per client qube.
Set up syncthing
Run syncthing as root (this is used to manage file ownership correctly, and it’s not a security risk for an appvm):
sudo syncthing -home /rw/syncdir/syncthing-config
Add a new folder with the label “syncdir” and set the path to /rw/syncdir. Add these ignore patterns for this folder:
/authorized_keys/*
/sshd_config-addition
/syncthing-config
Enable “Copy Ownership From Parent” in Actions > Advanced > Folder “syncdir”
Add a new device and share the folder with it. Accept the share on the new device.
Once the folder has been synced to the new device, manually set permissions to the correct user for the new device. Do this for every /writable folder.
chown -R sync-$CLIENTNAME /rw/syncdir/$CLIENTNAME/writable
Start syncthing automatically
Append this to /rw/config/rc.local:
sudo syncthing -no-browser -home /rw/syncdir/syncthing-config
Set up split-browser sync
Create a new file /etc/split-browser/00-sync.bash in the template for split-browser
SB_DATA_DIR=${SB_DATA_DIR:-~/sync/split-browser}
Then copy any existing data to the sync folder in the split-browser appvm:
cp -r ~/.local/share/split-browser ~/sync/
