Sound Does Not Work on Lenovo X1 Carbon Gen 9th
Continuing the discussion from Running Qubes on Lenovo X1 Carbon Gen 9th:
Hey, would you mind telling me the exact steps you took to get sound output to work on the X1C9? I have the same hardware and am having some trouble here. Thank you
Disregard. I got it.
try this
sudo qubes-dom0-update alsa-sof-firmware
and reboot then.
What ended up solving it @davemyfree? (this helps other users in the same situation as you) :slight_smile:
sudo echo “options snd-intel-dspcfg dsp_driver=1” > /etc/modprobe.d/alsa.conf
Thats my solution, right!
Sorry, was busy this days. I “referred” the solution but should had clearer. Next time I will, promised;-)
Perfect. Thank you for sharing. Marked that as the solution
Do you have working microphone with your solution?.. With sof-firmware you could have it.
All I need is one mic.
Do I need to “reverse” the command I called earlier in order to have both working? If so, how might I go about it?
I guess you could try install package with sof-firmware and remove string with option from
If sof-firmware package is enough you will see internal microphone device in pavucontrol after reboot.
I don’t have X1C9 to test it, but it works with previous X1C7-8
I just reinstalled 4.1rc and the original solution doesnt work anymore. Any idea what I can change to get it going again?
Weird how it changed on me.
Look at point 2 in comment Support for Intel Tiger Lake Processors · Issue #6411 · QubesOS/qubes-issues · GitHub
With Gen 8 devices installing sof firmware with alsa-ucm package is enough, but Tiger Lake looks newer than fedora 32 packages.
I got it. User error.The above solution still works.
Hello. I have a Carbon X1 Gen8 that I can’t get the internal microphone to work on. I have 4.0.4 installed. Have u succeeded to get the internal microphone to work, and how? Thank you.
You need newer kernel and alsa-sof-firmware package. I guess it is time to move to 4.1.
I had installed the latest kernel via Dom0, in Qubes 4.0.4. Are you suggesting that it’s impossible to get the latest kernel in 4.0.4?
As for alsa-sof-firmware, qubes-dom0-update says “Unable to find match”. Should it be installed in a template instead of Dom0?
Kernel-latest seems ok, but fedora 25 too old to get firmware from repos.
Hi !
Just installed Qubes 4.1 (kernel latest : 5.16.18-2.fc32.qubes.x86_64) on a Lenovo ThinkPad X1 Carbon Gen 9 (20XW0055MB) and the solution worked perfectly ! I now can play music from qubes :smile:
Thank you very much !
Can anyone point me out how to do this. The latest kernel I have available is 5.15.63-1.fc32.qubes. I am on Qubes OS 4.1.1 installed a few months ago. Still unable to get that microphone working.
