My mistake. However, in my app qube called snap-fedora, bitwarden and telegram-desktop are not working, only teams is.
The exact same installation of QubesOS on the Laptop as for the Workstation here, works fine for all three snaps.
[user@snap-fedora ~]$ snap run bitwarden
/snap/bitwarden/67/bitwarden: error while loading shared libraries: libatk-1.0.so.0: cannot open shared object file: No such file or directory
[user@snap-fedora ~]$ snap remove bitwarden
bitwarden removed
[user@snap-fedora ~]$ snap install bitwarden
bitwarden 2022.5.0 from 8bit Solutions LLC (bitwarden✓) installed
A JavaScript error occurred in the main process
Uncaught Exception:
SystemError [ERR_SYSTEM_ERROR]: A system error occurred: uv_interface_addresses returned Unknown system error 1 (Unknown system error 1)
at Object.networkInterfaces (node:os:259:16)
at getIPType (/snap/bitwarden/67/resources/app.asar/main.js:31987:34)
at new Defaults (/snap/bitwarden/67/resources/app.asar/main.js:31962:21)
at new Parser (/snap/bitwarden/67/resources/app.asar/main.js:32016:14)
at Object.73853 (/snap/bitwarden/67/resources/app.asar/main.js:31257:19)
at __webpack_require__ (/snap/bitwarden/67/resources/app.asar/main.js:57309:42)
at Object.65186 (/snap/bitwarden/67/resources/app.asar/main.js:32081:14)
at Object.75898 (/snap/bitwarden/67/resources/app.asar/main.js:32051:13)
[1810:0604/063942.286315:ERROR:browser_main_loop.cc(269)] Gdk: gdk_atom_intern: assertion 'atom_name != NULL' failed
[1810:0604/063942.287096:ERROR:browser_main_loop.cc(269)] Gdk: gdk_atom_intern: assertion 'atom_name != NULL' failed
Gtk-Message: 06:39:42.404: Failed to load module "pk-gtk-module"
Gtk-Message: 06:39:42.425: Failed to load module "pk-gtk-module"
[1810:0604/063942.615841:ERROR:address_tracker_linux.cc(196)] Could not create NETLINK socket: Operation not permitted (1)
[1810:0604/063942.714577:ERROR:udev_watcher.cc(52)] Failed to initialize a udev monitor.
[1989:0604/063943.997044:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
[2004:0604/063944.019995:ERROR:address_tracker_linux.cc(196)] Could not create NETLINK socket: Operation not permitted (1)
[2011:0604/063944.231003:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
^C[user@snap-fedora ~]$ snap run telegram-desktop
(telegram-desktop:2036): Gdk-CRITICAL **: 06:42:39.820: gdk_atom_intern: assertion 'atom_name != NULL' failed
(telegram-desktop:2036): Gdk-CRITICAL **: 06:42:39.821: gdk_atom_intern: assertion 'atom_name != NULL' failed
Gtk-Message: 06:42:39.849: Failed to load module "canberra-gtk-module"
Gtk-Message: 06:42:39.849: Failed to load module "pk-gtk-module"
Gtk-Message: 06:42:39.855: Failed to load module "canberra-gtk-module"
Gtk-Message: 06:42:39.855: Failed to load module "pk-gtk-module"
[user@snap-fedora ~]$ snap run teams
If bitwarden was working half an hour ago and I reboot, then it ceases to just now on the more reliable Laptop. In my experience snaps are unstable. Can anyone reproduce this behaviour?
Are the developers aware, should I create an issue on github at best?
That said, snaps do not seem to work on a desktop workstation with non-integrated graphics i.e. a graphics card. Only teams under fedora-36 runs fine, bitwarden and telegram-desktop are not.
I found this not to be true. The solution seems to be to delete and then recreate the entire app-cube that holds the snaps followed by a fresh snap installation. If that also fails, then a reinstall of snapd in the template solves it.
