Setting an Animated Interactive Wallpaper / Video Wallpaper for dom0 from an AppVM [No Dom0 Modifications]
Rundown
This guide is for all Qubers who enjoy customization including using animated / interactive wallpapers while still operating within a reasonably secure operating system. Qubes OS normally discourages desktop-level visual modifications that interact with dom0, but using the method below, you can safely run a live wallpaper inside an AppVM while maintaining strong isolation.
If you’ve ever wanted your desktop to feel more alive without compromising Qubes security principles, this guide is for you.
Requirements:
To follow this guide, you’ll need:
:check_mark: An AppVM (any name you prefer)
This VM will run your wallpaper player.
Optional (not required): For smoother playback, an AppVM that already has a GPU assigned to it can take advantage of hardware video decoding in mpv. This is purely a performance optimization and not necessary for the guide.
:check_mark: A TemplateVM
Used for installing packages (mpv, firejail) needed by your AppVM.
Recommended templates for this guide: Fedora or Debian.
Optional (Recommended): Use a minimal template if your willing to deal with slightly more work for better performance.
:check_mark: A video file to use as your wallpaper
Place it in the AppVM as ~/wallpaper.[Video extension].
:check_mark: dom0 packages
Use the preinstalled window-management utility in dom0 (wmctrl) or update it if needed.
Disclaimer:
This is a community made guide, please check for mistakes in commands (I’m not good at typing).
Information was up to date as of making. 12/11/25
I’m new to qubes, not to linux, so for debuging i might not be the best to ask questions to.
Dom0 Security disclaimer:
This method requires running a script in dom0. The script is intentionally minimal and restricted to safe operations (setting window geometry and adjusting _NET_WM_WINDOW_TYPE). It does not import or execute untrusted content, modify dom0 configuration, or alter system-level behavior.
However, dom0 is the most security-sensitive domain in Qubes OS. Always inspect scripts line-by-line before running them and never copy unknown or unsanitized files into dom0.
Installation:
1. Prepare a template & AppVM.
Use/Make a template containing Debian/Fedora, Depending on the video and hardware adjust memory, VCPU’s, and storage capacity. DO NOT give this AppVM Internet.
2. Install Essential Packages.
Dom0 Package:
sudo qubes-dom0-update wmctrl
Template Package:
#Debian
sudo apt install mpv firejail
#Fedora
sudo dnf install mpv firejail
3. Place Video File in AppVM.
Transfer your video from qube of choice.
4. Create Live Video Wallpaper script in Dom0.
You can write this script manually if you’re paranoid (Not really recommended)
OR
Import it after sanitation Using:
qvm-run --pass-io [VM with file] 'cat /home/user/Desktop/script.txt' > /home/[dom0 usr]/Desktop/wallpaper.txt
Script (DO NOT RUN WITH SUDO):
#!/usr/bin/env bash
set -euo pipefail
echo "===== QUBES WALLPAPER V1.2 By Pro42good ====="
echo "Run 'wmctrl -l' in dom0 and copy the WINID of the video window."
echo
read -rp "Enter WINID: " WINID
read -rp "Width  (default 1920): " WIDTH
read -rp "Height (default 1080): " HEIGHT
WIDTH=${WIDTH:-1920}
HEIGHT=${HEIGHT:-1080}
echo
echo "[*] Ensuring the window is visible (un-minimizing)..."
wmctrl -i -r "$WINID" -b remove,hidden,shaded
wmctrl -i -r "$WINID" -b remove,maximized_vert,maximized_horz
echo "[*] Applying geometry..."
wmctrl -i -r "$WINID" -e "0,0,0,${WIDTH},${HEIGHT}"
echo "[*] Removing decorations using SPLASH window type..."
xprop -id "$WINID" -f _NET_WM_WINDOW_TYPE 32a \
    -set _NET_WM_WINDOW_TYPE "_NET_WM_WINDOW_TYPE_SPLASH" \
    >/dev/null 2>&1 || true
echo "[*] Fixing leftover top gap by reapplying geometry..."
echo "[*] Making sticky, skipping taskbar/pager..."
wmctrl -i -r "$WINID" -b add,sticky,skip_taskbar,skip_pager
echo "[*] Refreshing compositor..."
wmctrl -i -r "$WINID" -b add,fullscreen
sleep 0.2
wmctrl -i -r "$WINID" -b remove,fullscreen
echo
echo "===== COMPLETE ====="
echo "Youre Wallpaper is now set!"
echo "If you're having any issues, say something in Qubes forums for this wallpaper guide."
echo "Mouse Input is supported, Keyboard input is NOT supported."
echo "To close the wallpaper, shut the AppVM off."
5. You’re Done!
Yep, that’s it. You have the script, no more packages or scripts required.
Usage:
  1. Inside dom0 run wmctrl -l and take note of the output.
  2. Open Terminal inside of wallpaper AppVM.
  3. Take note of wmctrl -l result in dom0 again.
  4. Inside your AppVM for wallpapers load your video/app using firejail for extra security.
#For videos
firejail mpv --loop --hwdec=no --vo=x11  --no-border -no-input-cursor --no-osc --no-input-default-bindings --ontop=no --geometry=100%x100% --fullscreen /Directory
#Optional mpv flags
--no-audio #No audio, might help performance on rich video formats
--vf=fps=30 #Caps FPS
--hwdec=auto #Automatically enables hardware decode
--no-deband #Removes mpv anti-deband, might better performance
--scale=bilinear #Reduce video scaling [Cheaper]
--scale=nearest #Max Reduction of video scaling [Cheapest]
--hwdec=auto-safe #Force Hardware decode while safe.
--hwdec=vaapi #Force Intel & AMD Hardware decode (Even if the VM doesn't want to use them)
--hwdec=vdpau #Force Nvidia Hardware decode
--vf=scale=X-Res:Y-Res #Downscale, I just found out this DOES NOT improve performance.
Technically Running without firejail gains performance at the cost of security
  1. Run wmctrl -l again and look for the newest addition to the list compared to the last 2 times.
  2. Run the script from dom0.
cd [Where stored]
bash wallpaper.txt
  1. Insert the wallpaper window ID
    The wallpaper Window ID looks something like this 0x052001dc.
  2. Enter Screen Resolution, and You’re Done!
Extra technical documentation:
This method works because it relies on window properties that XFWM will reliably apply to Qubes-proxied windows, while avoiding the behaviors that cause those windows to be dropped or mispositioned. Since AppVM windows are not native X11 clients but are instead rendered inside the VM and forwarded to dom0 via qubes-guid, dom0 window managers do not receive complete frame-control metadata. As a result, many standard X11 decoration hints—particularly _MOTIF_WM_HINTS—are ignored, and attempts to adjust stacking (e.g., using _NET_WM_STATE_BELOW, lower, or above) can cause the compositor to treat the window as non-visible. When that happens, qubes-guid simply stops drawing the window, which appears to “vanish.”
To work around this, the guide uses _NET_WM_WINDOW_TYPE_SPLASH. Unlike other types (e.g., DOCK or NORMAL), SPLASH is one of the few window categories that XFWM consistently applies to proxied Qubes windows without forcing them into a reserved-strut configuration or onto an always-on-top layer. SPLASH removes decorations and border frames but keeps the window at a standard stacking level. This allows the wallpaper window to behave like any other application: when other windows receive focus, they naturally appear above it without the need for forced stacking rules that would otherwise break Qubes’ compositor assumptions.
After switching the window type to SPLASH, dom0 must reapply the window geometry. This is because XFWM initially calculates frame extents based on the original decorated window, and simply removing decorations does not recalculate those extents. Reapplying geometry forces XFWM to interpret the window as borderless from the start, eliminating the leftover top gap. The result is a stable, decoration-free, correctly placed fullscreen window that remains behind other windows in normal use—effectively functioning as a wallpaper—while remaining fully compliant with Qubes’ security model and avoiding unsupported manipulations of proxied window layers.
This approach works because it aligns with how Qubes OS expects proxied windows to behave, rather than trying to force them into roles (like true desktop backgrounds or lowered system layers) that the GUI virtualization layer does not support.
Issues
  1. On version 1.1 if you had the video maximized it would still have the top border, fixed on 1.2.
  2. This is not compatable with transparent panels. (Aka where your tabs are displayed)
For the skeptics:
Live Demonstration + Nano showing code:
Uh at some point in time there was a YT video here but I scrubbed my accounts so it’s gone.
Please forgive me for the bad quality, im not good at using qubes and I don’t know how to record
@Pro42good Was here
Could you provide some screenshots/a video?
Here’s the video, Sorry it’s on youtube, i just can’t upload it on the forum for some reason, also sorry for the bad quality, i have no idea how to record dom0.
I could provide another video if you want to see a wallpaper with more movement.
If you check the original post now there’s a live demo, with a wallpaper that moves way more.
Hi, I find your contribution interesting. I have a question: Is it necessary for the AppVM to be constantly active?
Very Sadly Yes, though you can use a minimal AppVM with my method as long as you continue to use the base script, and you can also limit FPS with a mpv flag such as --vf=fps=30 to limit performance loss.
Thank you! awesome
I noticed this construct on the mpv command line, which appears in the youtube video too. As far as I can tell after a quick glance through the mpv and firejail man pages, only the “–ontop=no” is a documented parameter for mpv (with double dash). Did you have a reason for including the single-dash version too? or is it a test/typo that made it into “production”? :slight_smile:
Good effort, btw. I like it! :heart:
Thanks for pointing that out, I did not notice that earlier. I was running on very little sleep and missed it during cleanup. (Still little sleep)
You’re right, the single-dash version is not a valid mpv option and shouldn’t be there. It’s a typo that made it into the post, not intentional. I’m correcting it now.
Appreciate you taking the time to look closely, and thanks for the kind words!
