Send Window to 2nd Monitor Hotkey (With Minimal Software In Dom0)?
I’m using XFCE version of Qubes. As near as I can tell there is no built in hotkey to send a window to a 2nd monitor.
This hotkey is vital for my workflow.
I found this solution here:
It requires install of xdotool, wmctrl, and a 3rd party script in Dom0 (I believe).
I’m not to keen to be installing unkown software in dom0.
Anyone else run into this problem, and found a better solution?
I had this exact same issue with XFCE. After nearly an hour of digging through settings menus, I decided to abandon the DE entirely and switch to KDE, since it has native support for the feature as well as some other nice QoL stuff - full screen and window color inversion (super handy when using the Tor Browser) and a magnifier to name a few.
KDE link
Once you have it installed. go to System Settings > Shortcuts > Global Shortcuts > System Settings and search for Window to Next Screen and Window to Previous Screen.
Good luck!
I second the KDE recommendation but the official method for installing KDE in Qubes is currently broken for Qubes 4.1.
I was able to get KDE installed using these instructions:
Thanks for the tip.
So far I’m liking the snappiness of XFCE. Fast, low resource demands so far.
How much of that will I lose with KDE in your experience?
What else do I gain with KDE?
Is swapping back and for a pretty safe endeavor, without breaking my system, or losing my settings?
Thanks for the tip.
I don’t see much difference between the two, even on machines with low
resources. Sometimes I see KDE using less than XFCE.
You’ll lose almost nothing and gain a good deal - far easier to control
and customise, and works far better with Qubes - look at the thread
here
There are bugs - the sys-net icon is blank, or coloured in 4.1. The
stock menu is not customisable in 4.1 - this is a pain because it is
in 4.0, which is a core benefit.
I don’t use the menu a great deal,and I haven’t tried the new menu as yet.
It’s simple to switch back and forth - you just select one or other at
the login screen. You wont lose or break anything. (It’s possible to do
this while Qubes are running.)
Thanks. I just installed it. So far, a big, big improvement in user experience.
No significant differences in speed that I can tell.
From a newbie just getting started with Qubes, I can imagine that if Qubes made KDE the default, and not XFCE, it would see more new user adoption.
Unfortunately it would make a significantly larger iso. Currently, it fits to a (double-layer) DVD disk. AFAIK installing from a disk is generally more secure than from a (rewritable) USB stick.
moved to ‘User Support’
