Secureblue for Default TemplateVM and Dom0?
What is thought about this hardened Fedora distro:
It is a good candidate for sys-* VMs? For dom0? Has proper graphics
and DE support?
I would rather use Kicksecure:
Why? You prefer Debian based distro?
I use and trust Whonix (based on Kicksecure), therefore I trust @adrelanos as well.
This means you are placing more trust in Whonix, over secureblue?
Yes.
This is due to more trust in the lead developers of Whonix?
Yes.
There is a qubesOS kicksecure template? Or distro morph is the preferred
method.
Ok cool; there is also the distromorph:
Why is Fedora default dom0 distro and not Debian? The argument
made for this was superior graphics and desktop environment support in Fedora.
Is this true? If dom0 default was debian, you could distro morph to kicksecure.
Also, this is being actively worked on recently:
Template is here:
https://qubes.3isec.org/Templates/
Kicksecure-17 template is buggy at present. Apps will not show up and
crashes.
Distromorph in testing.
I am using debian minimal with kicksecure morphing CLI for all my tasks for long time (couple years).
any glitches with distromorphing?
unable to locate package “kicksecure-qubes-gui”
Secureblue is much more hardened than Kicksecure, which makes it a good fit for QubesOS which is security focused.
It is also Wayland reliant, and Wayland support in Qubes is a little way
off.
