sdhci_pci fails to probe in domU that has the device passed to it with:
sdhci-pci 0000:00:06.0: probe with driver sdhci-pci failed with error -22
The reader works fine in dom0.
I’ve disabled memory ballooning for this domU.
I’ve tried to enable permissive mode and no strict reset for the device.
HW: Novacustom NV41
DomU runs on Debian 12 template.
The same happens when using different kernels:
- dom0 supplied (6.10.10-1-fc37)
- domU supplied (linux-image-6.1.0-25-amd64 6.1.106-3)
- custom build vanilla Linux from recent master (ad46e8f95e93) with config mostly copied from Debian kernel (+dbg options enabled)
Running:
# echo 1 > /sys/bus/pci/devices/0000\:00\:06.0/remove
# echo 1 > /sys/bus/pci/rescan
dmesg:
[ 280.501056] pci 0000:00:06.0: PME# disabled
[ 280.501081] pci 0000:00:06.0: vgaarb: pci_notify
[ 280.501126] bus: 'pci': remove device 0000:00:06.0
[ 280.501130] PM: Removing info for pci:0000:00:06.0
[ 280.501303] device: 'wakeup4': device_unregister
[ 280.501367] pci 0000:00:06.0: vgaarb: pci_notify
[ 280.501386] pci 0000:00:06.0: device released
// Rescan triggered here
[ 297.517140] pci_bus 0000:00: scanning bus
[ 297.519837] pci 0000:00:06.0: [1217:8621] type 00 class 0x080501 PCIe Endpoint
[ 297.522243] pci 0000:00:06.0: BAR 0 [mem 0xf2012000-0xf2012fff]
[ 297.523691] pci 0000:00:06.0: BAR 1 [mem 0xf2013000-0xf2013fff]
[ 297.539615] device: '0000:00:06.0': device_add
[ 297.539656] device: 'wakeup4': device_add
[ 297.542821] bus: 'pci': add device 0000:00:06.0
[ 297.542872] PM: Adding info for pci:0000:00:06.0
[ 297.542881] pci 0000:00:06.0: vgaarb: pci_notify
[ 297.544617] pci_bus 0000:00: bus scan returning with max=00
[ 297.544643] pci 0000:00:06.0: BAR 0 [mem 0xf2000000-0xf2000fff]: assigned
[ 297.545591] pci 0000:00:06.0: BAR 1 [mem 0xf2001000-0xf2001fff]: assigned
[ 297.546302] pci 0000:00:06.0: bus: 'pci': __driver_probe_device: matched device with driver sdhci-pci
[ 297.546314] pci 0000:00:06.0: bus: 'pci': really_probe: probing driver sdhci-pci with device
[ 297.546323] sdhci-pci 0000:00:06.0: no default pinctrl state
[ 297.546335] sdhci-pci 0000:00:06.0: vgaarb: pci_notify
[ 297.546343] sdhci-pci 0000:00:06.0: runtime IRQ mapping not provided by arch
[ 297.546348] sdhci-pci 0000:00:06.0: SDHCI controller found [1217:8621] (rev 1)
[ 297.548460] sdhci-pci 0000:00:06.0: probe with driver sdhci-pci failed with error -22
[ 297.548640] sdhci-pci 0000:00:06.0: vgaarb: pci_notify
Logs from dom0:
/var/log/xen/console/guest-dev-upstream-dm.log:
[2024-10-04 04:14:17] from-vchan: {"execute":"device_add","id":2020372736,"arguments":{"driver":"xen-pci-passthrough","id":"pci-pt-2d_00.0","hostaddr":"0000:2d:00.0","permissive":true}}
[2024-10-04 04:14:17] [00:06.0] xen_pt_realize: Assigning real physical device 2d:00.0 to devfn 0x30
[2024-10-04 04:14:17] [00:06.0] xen_pt_register_regions: IO region 0 registered (size=0x00001000 base_addr=0x80500000 type: 0x0)
[2024-10-04 04:14:17] [00:06.0] xen_pt_register_regions: IO region 1 registered (size=0x00001000 base_addr=0x80501000 type: 0x0)
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x000e mismatch! Emulated=0x0080, host=0x0000, syncing to 0x0000.
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x0010 mismatch! Emulated=0x0000, host=0x80500000, syncing to 0x80500000.
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x0014 mismatch! Emulated=0x0000, host=0x80501000, syncing to 0x80501000.
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x006e mismatch! Emulated=0x0000, host=0x0043, syncing to 0x0003.
[2024-10-04 04:14:17] [00:06.0] xen_pt_pm_ctrl_reg_init_off: PCI power management control passthrough is off
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x004a mismatch! Emulated=0x0000, host=0x0180, syncing to 0x0080.
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x0084 mismatch! Emulated=0x0000, host=0x5908f80, syncing to 0x5908f80.
[2024-10-04 04:14:17] [00:06.0] xen_pt_config_reg_init: Offset 0x0092 mismatch! Emulated=0x0000, host=0x0011, syncing to 0x0011.
[2024-10-04 04:14:17] [00:06.0] xen_pt_pci_intx: intx=1
[2024-10-04 04:14:17] [00:06.0] xen_pt_realize: Real physical device 2d:00.0 registered successfully
[2024-10-04 04:14:17] from-unix: {"return": {}, "id": 2020372736}
Seems that somebody had the same issue but didn’t pursue it: HCL - Tuxedo InfinityBook S 15 - Gen8 (NS50AU) Unfortunately in my case USB card reader is useless.
Anybody got idea how to fix/debug this?
