TL;DR: Some tweaking required, but no major showstoppers ![]()
1. Working out of the box:
- Installation
- Boot into system
- Graphics
- Keyboard
(via i8042/serio aka PS/2 → no need for USB input devices) - Touchpad
(also i8042/serio and i2c)
Hint: The touchpad has a physical click-switch. If you prefer tap-to-click, it can be enabled in the dom0 system settings. - Audio in and out
Note: Not Qubes-related, but the speaker quality is surprisingly bad, sounding like out of a tin can. Quick test seems to indicate at least 12dB attenuation below ~1kHz. - Webcam (via USB)
- Ethernet
- Wifi
- HDMI out
- Bluetooth (appears as USB device 8087_0033)
2. Not working:
- microSD cardreader
- The Installer does not assign it to any Qube.
- I can for example attach it to sys-usb, but I get the kernel message “probe with driver sdhci_pci failed with error -22”
- Workaround: Use external USB cardreader (-> no showstopper for me)
3. Tweaking needed:
Keyboard backlight
- You need Tuxedo’s kernel module
Security risk: Third-Party software in dom0 → you have to decide if you trust Tuxedo and Github well enough …- Get it here: TUXEDO Computers / Development / Packages / tuxedo-drivers · GitLab
- make package-rpm
- Install the generated rpm file and dkms in dom0
- → You now have the control interface in /sys/class/leds/white:kbd_backlight
→ and you now get X keyboard events KbdBrightnessUp, KbdBrightnessDown and KbdLightOnOff - As stated in Tuxedo’s README, you’re on your own how to make your desktop environment react to the keypresses and change the brightness.
- I used “System Settings” → “Keyboard” → “Shortcuts” to bind the keys to a small python script based on the Upower example from Keyboard backlight - ArchWiki. If you have a more out-of-the-box suggestion, please share it.
Suspending
(… you’ve all been waiting for this one, right?)-
Good news: S3 / Suspend-To-RAM / “deep” still works!
However, the kernel default is s2idle
→ You need to set kernel parameter “mem_sleep_default=deep”
(add that to GRUB_CMDLINE_LINUX in /etc/default/grub and regenerate your grub config: grub2-mkconfig -o /boot/grub2/grub.cfg) -
Note: I disabled Intel ME and Hyperthreading in the firmware setup.
→ All devices seem to resume properly, except …
- Ethernet
- The ethernet device is still there after resume, but it does no longer recognize the link
- Un- and reloading the module does NOT help
- Restarting sys-net DOES helps
- After some experiments I found a workaround:
- Force unload/reload of module r8169 upon suspend → add r8169 to /rw/config/suspend-module-blacklist
- Disable D3cold → /rw/config/rc.local writes 0 into /sys/class/net/ens…/device/d3cold_allowed
- → Ethernet is now usable after resume
- I am NO expert on these hardware-level issues, so I’d be thankful for feedback if this is a bad idea!
- Ethernet
4. Not (yet) tested:
- Fan control / CPU power management
(You can hear the fans permanently, but it’s definitely more of the “soft background breeze” quality, not “ready for takeoff”) - TPM / Trusted Boot
- Thunderbolt
5. HCL report card:
layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
TUXEDO
model: |
TUXEDO InfinityBook S Gen8
bios: |
1.07.10RTR1
cpu: |
13th Gen Intel(R) Core(TM) i7-1360P
cpu-short: |
FIXME
chipset: |
Intel Corporation Raptor Lake-P/U 4p+8e cores Host Bridge/DRAM Controller [8086:a707]
chipset-short: |
FIXME
gpu: |
Intel Corporation Raptor Lake-P [Iris Xe Graphics] [8086:a7a0] (rev 04) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
memory: |
32471
scsi: |
usb: |
3
certified:
'no'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.2.1
xen: |
4.17.4
kernel: |
6.9.2-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
