@deeplow - pls feel free to put this in another thread if you think it shouldn’t be asked here - there are multiple saltstack threads & I wasn’t sure which was more appropriate.
This is the first time I’m attempting to use saltstack & having some problems. I want to use unman’s shaker cacher salt config to install a caching server. Can anyone point me in the right direction. I have copied the cacher directory from unman’s shaker repo to /srv/salt in dom0. I already have the debian-10-minimal template installed.
I get the following error when trying to apply the state - is there something I should run before this?
sudo qubesctl state.apply cacher.create
[ERROR ] Template was specified incorrectly: False
local:
Data failed to compile:
Specified SLS template-debian-10-minimal in saltenv base is not available on the salt master or through a configured fileserver
DOM0 configuration failed, not continuing
