For compartmentalization and security I normally multiply my Fedora TemplateVM into multiple specialized clones like so:
fedora-37 (untouched)
fedora-37-general (adds broadly useful, widely-used open source packages)
fedora-37-print (sketchy printer drivers)
fedora-37-talk (Zoom, Slack packages)
fedora-37-media (Commercial Russian video ripping software etc)
It is painful to manage these by hand since Fedora releases frequently. I have been using a text file with instructions to myself for configuring each clone of fedora.
This year I finally figured out how to use Salt for this purpose. Here is how I do it, in case anyone is looking for example files as a starting place to learn how to manage Qubes with salt. I am still a beginner myself. Feedback / ideas welcome.
If you need an even more basic example, see the one I posted last year, which introduces super rudimentary Salt concepts in relation to Qubes.
All files below live in dom0.
Top-level shell commands
This is the top-level shell script that runs all the salt sls files. Obviously you can extract the individual commands after else if you want to develop your own custom solution iteratively. I call this file with one argument, the number of the fedora version I am customizing, e.g. fedora-multiply.sh 37.
/home/user/bin/fedora-multiply.sh:
#!/usr/bin/bash
set -e #quit on error
if [ -z "$1" ]
then
echo "USAGE: fedora-multiply FVERSION"
else
sudo qubesctl state.apply fedora-clone-to-general pillar="{\"fedorav\": \"$1\"}"
sudo qubesctl --skip-dom0 --targets=fedora-$1-general state.apply fedora-general-configure
sudo qubesctl state.apply fedora-general-multiply pillar="{\"fedorav\": \"$1\"}"
sudo qubesctl --skip-dom0 --targets=fedora-$1-media state.apply fedora-media-configure
fi
Each command specifies an SLS file to apply after state.apply minus the .sls extension. So state.apply fedora-clone-to-general applies the file at /srv/salt/fedora-clone-to-general.sls.
You will notice some commands have --skip-dom0 --targets=fedora-.... These are dispatched from dom0 to run their SLS files on the VMs listed under --targets=. The commands that do not use these flags run their SLS files only on dom0.
Also, some commands have a pillar passed in as a JSON object with the key āfedoravā. This is the fedora version and is used to render jinja templates in the SLS files that name and identify the templateVMs.
Below are the SLS files.
Clone fedora to fedora-general
This one clones fedora-XX to fedora-XX-general and copies the open source IBM Plex font out of dom0 into the fedora-XX-general template as well, since I like that font ![]()
Note the first use of jinja templates, using the key/value (āfedoravā: ā37ā) we passed in on the command line (in /home/user/bin/fedora-multiply.sh) as a JSON object.
fedora-clone-to-general:
qvm.clone:
- source: fedora-{{ pillar['fedorav'] }}
- name: fedora-{{ pillar['fedorav'] }}-general
plex-to-fedora-general:
cmd.run:
- name: qvm-copy-to-vm fedora-{{ pillar['fedorav'] }}-general /home/user/Plex
Configure fedora-general
Configuring fedora-XX-general:
/srv/salt/fedora-general-configure.sls
fedora-general-enable-repos:
cmd.run:
- name: sudo dnf config-manager --set-enabled rpmfusion-free rpmfusion-free-updates rpmfusion-nonfree rpmfusion-nonfree-updates && sudo dnf upgrade -y --refresh #parameter
fedora-general-installs:
pkg.installed:
- pkgs:
- libreoffice
- keepassxc
- emacs
- libgnome-keyring
- inotify-tools
- seahorse
- seahorse-nautilus
- brasero
- xsel
- zbar
- evolution
- aspell
- aspell-en
- ruby
- pavucontrol
- bind-utils
- cloc
- onionshare
- gimp
- traceroute
- whois
- xclip
- geteltorito
- genisoimage
- java-17-openjdk
- postgresql
- python3-psycopg2
- postgresql-server
- postgresql-upgrade
- gpgme
- dnf-utils
- python3-gpg
- youtube-dl
- transmission
- zstd
- libzstd
- ffmpeg-libs
- ffmpeg
- vlc
install-plex:
cmd.run:
- name: sudo mv /home/user/QubesIncoming/dom0/Plex/IBM* /usr/share/fonts && sudo fc-cache -f -v
Clone fedora-general into specialized templates
Cloning fedora-XX-general into specialized templates like fedora-XX-print, fedora-XX-media, etc. Notice this first shuts down fedora-XX-general so that its new configuration is saved before it is cloned:
/srv/salt/fedora-general-multiply.sls
fedora-general-shutdown:
qvm.shutdown:
fedora-general-clone-to-talk:
qvm.clone:
- source: fedora-{{ pillar['fedorav'] }}-general
- name: fedora-{{ pillar['fedorav'] }}-talk
fedora-general-clone-to-media:
qvm.clone:
- name: fedora-{{ pillar['fedorav'] }}-media
fedora-general-clone-to-print:
qvm.clone:
- name: fedora-{{ pillar['fedorav'] }}-print
Configure a specialized template
I automate the setup of fedora-XX-media since it has many additional packages. This uses some more advanced/esoteric packaging options (much of which is to provide prerequisites for specialized media software I need to compile by hand).
/srv/salt/fedora-media-configure.sls
development-tools:
pkg.group_installed:
- name: development-tools
ctools:
- name: 'C Development Tools and Libraries'
installs:
pkg.installed:
- pkgs:
- gst-devtools
- HandBrake
- HandBrake-gui
- asunder
- fdkaac
- zlib-devel
- openssl-devel
- expat-devel
- ffmpeg
- ffmpeg-devel
- qt5-qtbase-devel
- pkgconf-pkg-config
- glibc-devel
- mesa-libGLU-devel
- mesa-libGL-devel
What I do manually
You will notice there is no Salt configuration for fedora-XX-print or fedora-XX-talk. Thatās because itās easier to install the very few additional packages in these templates by hand. They all need to be downloaded manually from various websites. The print driver even needs to be run via an interactive script that asks various configuration questions.
Gotchas
The Qubes-Salt page on qubes-os.org lists what it erroneously calls āAll Qubes-specific statesā; there is a presumably newer and definitely longer list of Qubes states on github.
As has been previously noted in this forum, the qubesctl command will always target dom0, even if you provide an explicit list of --targets=... that does not include dom0. To exclude dom0 as a target always pass the --skip-dom0 flag as I do above.
In my last example tutorial I used top files alongside SLS files. The purpose of top files is to map SLS files to particular machines. I find it easier to simply do these mappings by customizing my call to qubesctl with an explicit --targets=... command (with --skip-dom0 if needed) and then calling a particular SLS file via state.apply. I believe @unman suggested this approach in his reply to my last example tutorial. If you do try and use top files, be aware that each target in the top file can target one or more VMs but will still be run on dom0 regardless of whether this matches the target specification. You need to pass --skip-dom0 to thwart this behavior.
