Resolving `xterm: cannot load font -misc-fixed-medium-r-semicondensed--13-120-75-75-c-60-iso10646-1`
Frequently I see in journalctl output:
<date> <vm> qubes.StartApp+qubes-run-terminal-dom0[..]: xterm: cannot load font "-misc-fixed-medium-r-semicondensed--13-120-75-75-c-60-iso10646-1"
It’s harmless, just log noise. Comes of using xterm on reduced/minimal templates. Here’s the simplest way to make it go away (Debian):
root@template:~# apt install xfonts-base
root@template:~# fc-cache  # (might not be required)
I don’t (and xfonts-based is not installed).
How come?
I think there is no ready answer to that question, xterm font resolution is nontrivial as it’s laden with legacy and there are several places/ways fonts can be set. The default font face is fixed which is (always?) an alias for the big long font name/definition in the subject of this thread.
Best guess, and assuming you do use xterm (not some other terminal): you have a properly defined faceName X resource in your ~/.Xresources or some other place that overrides the default of fixed and references a font that is actually installed. In my work qubes that’s what I do, but in my system/utility qubes I don’t usually bother.
Top tip!
It’s a long time since I meddled with X fonts, but I do like a quiet log file.
Minor typo
Hazy memory: should that be “fc-cache”…?
Eek. Fixed, thanks :saluting_face:
@Euwiiwueir
I do.
In /etc/X11/Xresources/x11-common I have *faceName: Monospace bold.
$ fc-match monospace
DejaVuSansMono.ttf: "DejaVu Sans Mono" "Book"
$ find /usr/share/fonts
/usr/share/fonts
/usr/share/fonts/truetype
/usr/share/fonts/truetype/dejavu
/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf
/usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
/usr/share/fonts/truetype/dejavu/DejaVuSerif-Bold.ttf
/usr/share/fonts/truetype/dejavu/DejaVuSerif.ttf
/usr/share/fonts/truetype/dejavu/DejaVuSansMono-Bold.ttf
/usr/share/fonts/truetype/dejavu/DejaVuSans-Bold.ttf
