Clipboard sharing is part of qubes-gui-agent on linux vm side. It won’t work as we shut it down to disable seamless mode. The workaround is to use vnc or something like that instead of truly disabling seamless mode
Thanks! I will try this @unman guide Automatic startup of Gnome environement - #25 by unman tomorrow. Hopefully, it will work now with xfce
Wow, VNC works great! And it allows sharing the clipboard with other VMs!
