Hello,
I have been unable to install Windows Tools in dom0 and it looks like no one is really sure why.
I think I probably need to just do a fresh reinstall yet again. Should I use 4.0 or 4.1?
Does anyone have any ideas on what is the best way to proceed?
I’m don’t know the answer but in the following are discussions about QWT suport in Qubes some people have talked about the stability in both releases. You answer may be there:
I have tried what happens in Qubes R4.1 (Version 20201014 Alpha) with Windows and QWT 4.0.1.3. So far, the following results are obtained:
For Windows 7 with QWT installed, the VM from R4.0 can be imported, but not started - error in libxenlight : Couldn't open /sys/bus/pci/drivers/pciback/allow_interrupt_control: File or directory not found The VM stays in an intrermediate state, shown as running or starting, but it cannot be shutdown or killed, claiming it were not running.
For Windows 1…
After a sleepless night, I came up with some considerations, and I hope I can start a discussion based on these ideas.
Currently, about three fourths of all desktop computer are using Windows as their operating system, despite serious security problems. Still about one sixth of them are still using Windows 7, although support for this version has been canceled last year. The majority of the Windows systems - about 80 % - are using Windows 10, which poses severe security risks: Each month, Micro…
